[mapserver-commits] r9003 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue May 5 16:47:22 EDT 2009
Author: hobu
Date: 2009-05-05 16:47:22 -0400 (Tue, 05 May 2009)
New Revision: 9003
trunk/mapserver/mapsde.c
oops, try again on #3001 and actually use NCLOB instead of CLOB
Modified: trunk/mapserver/mapsde.c
--- trunk/mapserver/mapsde.c 2009-05-05 20:43:48 UTC (rev 9002)
+++ trunk/mapserver/mapsde.c 2009-05-05 20:47:22 UTC (rev 9003)
@@ -607,10 +607,15 @@
msSDELayerInfo *sde;
SE_BLOB_INFO blobval;
#ifdef SE_CLOB_TYPE
SE_CLOB_INFO clobval;
#endif
+#ifdef SE_NCLOB_TYPE
+ SE_NCLOB_INFO nclobval;
+#endif
#ifdef SE_NSTRING_TYPE
SE_WCHAR* wide=NULL;
#endif
@@ -800,10 +805,32 @@
"SE_stream_get_clob()");
return(MS_FAILURE);
- break;
+ break;
#endif
+#ifdef SE_CLOB_TYPE
+ case SE_NCLOB_TYPE:
+ status = SE_stream_get_nclob(sde->connPoolInfo->stream, (short) (i+1), &nclobval);
+ if(status == SE_SUCCESS) {
+ shape->values[i] = (char *)malloc(sizeof(char)*nclobval.nclob_length);
+ shape->values[i] = memcpy( shape->values[i],
+ nclobval.nclob_buffer,
+ nclobval.nclob_length);
+ SE_nclob_free(&nclobval);
+ else if (status == SE_NULL_VALUE) {
+ shape->values[i] = strdup(MS_SDE_NULLSTRING);
+ else {
+ sde_error( status,
+ "sdeGetRecord()",
+ "SE_stream_get_nclob()");
+ return(MS_FAILURE);
+ break;
+#endif
case SE_BLOB_TYPE:
status = SE_stream_get_blob(sde->connPoolInfo->stream, (short) (i+1), &blobval);
More information about the mapserver-commits
