[mapserver-commits] r9008 - trunk/mapserver
Thu May 7 16:59:38 EDT 2009
Author: dmorissette
Date: 2009-05-07 16:59:38 -0400 (Thu, 07 May 2009)
New Revision: 9008
   trunk/mapserver/configure
   trunk/mapserver/configure.in
Fixed detection of freetype when installed in non-system directory (#3008)
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure	2009-05-07 20:55:10 UTC (rev 9007)
+++ trunk/mapserver/configure	2009-05-07 20:59:38 UTC (rev 9008)
@@ -5256,12 +5256,12 @@
   { echo "$as_me:$LINENO: result:         using libfreetype from $FT_LIB" >&5
 echo "${ECHO_T}        using libfreetype from $FT_LIB" >&6; }
-  if test ""$FT_LIBDIR"" != "/usr/lib"; then
+  if test ""$FT_LIB"" != "/usr/lib"; then
-  if test -z ""$FT_LIBDIR"" || echo ""$FT_LIBDIR"" | grep '^/' >/dev/null ; then
-    ai_p=""$FT_LIBDIR""
+  if test -z ""$FT_LIB"" || echo ""$FT_LIB"" | grep '^/' >/dev/null ; then
+    ai_p=""$FT_LIB""
   else
-    ai_p="`pwd`/"$FT_LIBDIR""
+    ai_p="`pwd`/"$FT_LIB""
   fi
@@ -5277,8 +5277,7 @@
   fi
-else
-    { echo "$as_me:$LINENO: checking for FT_Init_FreeType in -lfreetype" >&5
+elif test -z "$FT_LIBDIR" -a -z "$FT_BIN" ; then     { echo "$as_me:$LINENO: checking for FT_Init_FreeType in -lfreetype" >&5
 echo $ECHO_N "checking for FT_Init_FreeType in -lfreetype... $ECHO_C" >&6; }
 if test "${ac_cv_lib_freetype_FT_Init_FreeType+set}" = set; then
   echo $ECHO_N "(cached) $ECHO_C" >&6
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in	2009-05-07 20:55:10 UTC (rev 9007)
+++ trunk/mapserver/configure.in	2009-05-07 20:59:38 UTC (rev 9008)
@@ -164,8 +164,8 @@
 if test -n "$FT_LIBDIR" -a -z "$FT_BIN" ; then
   FT_LIB="-L$FT_LIBDIR $FT_TYPE"
   AC_MSG_RESULT([        using libfreetype from $FT_LIB])
-  AC_ADD_RUNPATH("$FT_LIBDIR")
-else
+  AC_ADD_RUNPATH("$FT_LIB")
+elif test -z "$FT_LIBDIR" -a -z "$FT_BIN" ; then dnl replaced else by elif
   dnl check for lib in system libs
   AC_CHECK_LIB(freetype, FT_Init_FreeType, FT_LIB="-lfreetype",,)
