[mapserver-commits] r9017 - branches/branch-5-4/mapserver
svn at osgeo.org
svn at osgeo.org
Fri May 15 07:43:56 EDT 2009
Author: dmorissette
Date: 2009-05-15 07:43:56 -0400 (Fri, 15 May 2009)
New Revision: 9017
branches/branch-5-4/mapserver/HISTORY.TXT
branches/branch-5-4/mapserver/maphttp.c
Added CURL_CA_BUNDLE env. var. (#3007)
Modified: branches/branch-5-4/mapserver/HISTORY.TXT
--- branches/branch-5-4/mapserver/HISTORY.TXT 2009-05-15 11:34:38 UTC (rev 9016)
+++ branches/branch-5-4/mapserver/HISTORY.TXT 2009-05-15 11:43:56 UTC (rev 9017)
@@ -14,6 +14,12 @@
Current Version:
+- Added CURL_CA_BUNDLE env. var. to enable using HTTPS services in WMS/WFS
+ client connections (#3007)
+- Fixed a problem with an error message with mode=legendicon, wrong string
+ being output.
- Fixed detection of freetype when installed in non-system directory (#3008)
- Fixed detection of libpng + zlib headers with experimental-png enabled (#3010)
@@ -30,7 +36,8 @@
- Fix Getlegendgraphic when sizeunit is set (#2983)
-- Fix mapogcfilter.c not to cause syntax error if PROJ.4 is not compiled in (#2987)
+- Fix mapogcfilter.c not to cause syntax error if PROJ.4 is not compiled
+ in (#2987)
Version 5.4.0 (2009-04-22):
Modified: branches/branch-5-4/mapserver/maphttp.c
--- branches/branch-5-4/mapserver/maphttp.c 2009-05-15 11:34:38 UTC (rev 9016)
+++ branches/branch-5-4/mapserver/maphttp.c 2009-05-15 11:43:56 UTC (rev 9017)
@@ -267,6 +267,7 @@
CURLM *multi_handle;
CURLMsg *curl_msg;
char debug = MS_FALSE;
+ const char *pszCurlCABundle = NULL;
if (numRequests == 0)
return MS_SUCCESS; /* Nothing to do */
@@ -291,9 +292,17 @@
if (nTimeout <= 0)
nTimeout = 30;
+ /* Check if we've got a CURL_CA_BUNDLE env. var.
+ * If set then the value is the full path to the ca-bundle.crt file
+ * e.g. CURL_CA_BUNDLE=/usr/local/share/curl/curl-ca-bundle.crt
+ pszCurlCABundle = getenv("CURL_CA_BUNDLE");
if (debug)
msDebug("HTTP: Starting to prepare HTTP requests.\n");
+ if (pszCurlCABundle)
+ msDebug("Using CURL_CA_BUNDLE=%s\n", pszCurlCABundle);
/* Alloc a curl-multi handle, and add a curl-easy handle to it for each
@@ -394,7 +403,11 @@
/* Set timeout.*/
curl_easy_setopt(http_handle, CURLOPT_TIMEOUT, nTimeout );
+ /* Pass CURL_CA_BUNDLE if set */
+ curl_easy_setopt(http_handle, CURLOPT_CAINFO, pszCurlCABundle );
/* Set proxying settings */
if (pasReqInfo[i].pszProxyAddress != NULL
&& strlen(pasReqInfo[i].pszProxyAddress) > 0)
More information about the mapserver-commits
