[mapserver-commits] r9046 - branches/branch-5-4/mapserver
Thu May 28 13:01:06 EDT 2009
Author: pramsey
Date: 2009-05-28 13:01:05 -0400 (Thu, 28 May 2009)
New Revision: 9046
   branches/branch-5-4/mapserver/HISTORY.TXT
   branches/branch-5-4/mapserver/mappostgis.c
Fix filter error in multi-clause filters (#2937)
Modified: branches/branch-5-4/mapserver/HISTORY.TXT
--- branches/branch-5-4/mapserver/HISTORY.TXT	2009-05-28 17:00:45 UTC (rev 9045)
+++ branches/branch-5-4/mapserver/HISTORY.TXT	2009-05-28 17:01:05 UTC (rev 9046)
@@ -14,6 +14,8 @@
 Current Version:
+- Fix filter error in multi-clause filters (#2937)
 - Fix memory leak in SQL building (#2997)
 - Change the dll mapping rules to support the recent MONO versions
Modified: branches/branch-5-4/mapserver/mappostgis.c
--- branches/branch-5-4/mapserver/mappostgis.c	2009-05-28 17:00:45 UTC (rev 9045)
+++ branches/branch-5-4/mapserver/mappostgis.c	2009-05-28 17:01:05 UTC (rev 9046)
@@ -1197,10 +1197,13 @@
     /* Populate strFilter, if necessary. */
     if ( layer->filter.string ) {
-        strFilter = strdup(layer->filter.string);
+        static char *strFilterTemplate = "(%s)";
+        strFilter = (char*)malloc(strlen(strFilterTemplate) + strlen(layer->filter.string));
+        sprintf(strFilter, strFilterTemplate, layer->filter.string);
         strFilterLength = strlen(strFilter);
     /* Populate strUid, if necessary. */
     if ( uid ) {
         static char *strUidTemplate = "\"%s\" = %ld";
