[mapserver-commits] r9055 - branches/branch-5-4/mapserver
svn at osgeo.org
svn at osgeo.org
Thu May 28 23:29:48 EDT 2009
Author: sdlime
Date: 2009-05-28 23:29:47 -0400 (Thu, 28 May 2009)
New Revision: 9055
branches/branch-5-4/mapserver/mapraster.c
Fixed world file reader to avoid the chance for a buffer overflow. (#3027)
Modified: branches/branch-5-4/mapserver/mapraster.c
--- branches/branch-5-4/mapserver/mapraster.c 2009-05-28 22:32:00 UTC (rev 9054)
+++ branches/branch-5-4/mapserver/mapraster.c 2009-05-29 03:29:47 UTC (rev 9055)
@@ -333,34 +333,69 @@
#endif
+/* resetExtension() */
+/* Adapted from GDAL's CPLResetExtension(). */
+static char *resetExtension( const char *pszFilename, const char *pszNewExt )
+ char *pszResult = (char*) malloc(strlen(pszFilename) + 1 + strlen(pszNewExt) + 1);
+ size_t i;
+ strcpy(pszResult, pszFilename);
+ /* First, try and strip off any existing extension. */
+ for( i = strlen(pszResult) - 1; i > 0; i-- ) {
+ if( pszResult[i] == '.' ) {
+ pszResult[i] = '\0';
+ break;
+ if( pszResult[i] == '/' || pszResult[i] == '\\' || pszResult[i] == ':' )
+ break;
+ /* Append the new extension. */
+ strcat(pszResult, ".");
+ strcat(pszResult, pszNewExt);
+ return pszResult;
/* readWorldFile() */
/* Function to read georeferencing information for an image */
/* from an ESRI world file. */
-static int readWorldFile(char *filename, double *ulx, double *uly, double *cx, double *cy) {
+static int readWorldFile(const char *filename, double *ulx, double *uly, double *cx, double *cy) {
FILE *stream;
char *wld_filename;
int i=0;
char buffer[BUFLEN];
- wld_filename = strdup(filename);
- strcpy(strrchr(wld_filename, '.'), ".wld");
+ wld_filename = resetExtension(filename, "wld");
stream = fopen(wld_filename, "r");
+ free(wld_filename);
if(!stream) {
- strcpy(strrchr(wld_filename, '.'), ".tfw");
+ wld_filename = resetExtension(filename, "tfw");
if(!stream) {
- strcpy(strrchr(wld_filename, '.'), ".jgw");
+ wld_filename = resetExtension(filename, "jgw");
if(!stream) {
- strcpy(strrchr(wld_filename, '.'), ".gfw");
+ wld_filename = resetExtension(filename, "gfw");
if(!stream) {
msSetError(MS_IOERR, "Unable to open world file for reading.", "readWorldFile()");
- free(wld_filename);
return(-1);
@@ -389,7 +424,6 @@
fclose(stream);
return(0);
More information about the mapserver-commits
