[mapserver-commits] r9527 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Nov 5 11:03:13 EST 2009
Author: aboudreault
Date: 2009-11-05 11:03:13 -0500 (Thu, 05 Nov 2009)
New Revision: 9527
trunk/mapserver/HISTORY.TXT
trunk/mapserver/maporaclespatial.c
Fixed buffer overflow in oracle spatial driver with large sql data (#2694)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-11-05 00:39:47 UTC (rev 9526)
+++ trunk/mapserver/HISTORY.TXT 2009-11-05 16:03:13 UTC (rev 9527)
@@ -14,6 +14,7 @@
Current Version (SVN trunk):
+- Fixed buffer overflow in oracle spatial driver with large sql data (#2694)
Version 5.6.0-beta5 (2009-11-04):
Modified: trunk/mapserver/maporaclespatial.c
--- trunk/mapserver/maporaclespatial.c 2009-11-05 00:39:47 UTC (rev 9526)
+++ trunk/mapserver/maporaclespatial.c 2009-11-05 16:03:13 UTC (rev 9527)
@@ -62,6 +62,7 @@
#define VERSION_10g 3
#define TOLERANCE 0.001
#define NULLERRCODE 1405
+#define TABLE_NAME_SIZE 2000
typedef
struct
@@ -173,7 +174,7 @@
static int TRY( msOracleSpatialHandler *hand, sword status );
static int ERROR( char *routine, msOracleSpatialHandler *hand, msOracleSpatialDataHandler *dthand );
static void msSplitLogin( char *connection, mapObj *map, char *username, char *password, char *dblink );
-static int msSplitData( char *data, char *geometry_column_name, char *table_name, char* unique, char *srid, int *function, int * version);
+static int msSplitData( char *data, char *geometry_column_name, char **table_name, char* unique, char *srid, int *function, int * version);
static void msOCICloseConnection( void *layerinfo );
static msOracleSpatialHandler *msOCISetHandlers( char *username, char *password, char *dblink );
static int msOCISetDataHandlers( msOracleSpatialHandler *hand, msOracleSpatialDataHandler *dthand );
@@ -326,7 +327,7 @@
/* break layer->data into geometry_column_name, table_name and srid */
-static int msSplitData( char *data, char *geometry_column_name, char *table_name, char *unique, char *srid, int *function, int *version )
+static int msSplitData( char *data, char *geometry_column_name, char **table_name, char *unique, char *srid, int *function, int *version )
char *tok_from = "from";
char *tok_using = "using";
@@ -337,9 +338,10 @@
char tok_function[11] = "";
int parenthesis, i;
char *src = data, *tgt;
+ int table_name_size = TABLE_NAME_SIZE;
/* clearup */
- *geometry_column_name = *table_name = 0;
+ *geometry_column_name = **table_name = 0;
/* bad 'data' */
if (data == NULL)
@@ -361,8 +363,9 @@
return 0;
/* parsing 'table_name' or '(SELECT stmt)' */
+ i = 0;
for( ;*src && isspace( *src ); src++ ); /* skip blanks */
- for( tgt=table_name, parenthesis=0; *src; src++, tgt++ )
+ for( tgt=*table_name, parenthesis=0; *src; src++, tgt++, ++i )
if (*src == '(')
parenthesis++;
@@ -370,6 +373,11 @@
parenthesis--;
else if (parenthesis==0 && isspace( *src ))
break; /* stop on spaces */
+ /* double the size of the table_name array if necessary */
+ if (i == table_name_size) {
+ table_name_size *= 2;
+ *table_name = (char *) realloc(*table_name,sizeof(char *) * table_name_size);
*tgt = *src;
*tgt = 0;
@@ -1881,7 +1889,8 @@
int function = 0;
int version = 0;
char query_str[6000];
- char table_name[2000], geom_column_name[100], unique[100], srid[100];
+ char *table_name;
+ char geom_column_name[100], unique[100], srid[100];
OCIDefine *adtp = NULL;
OCIDefine **items = NULL;
OCINumber oci_number;
@@ -1913,8 +1922,9 @@
sthand = (msOracleSpatialStatement *)layerinfo->orastmt2;
+ table_name = (char *) malloc(sizeof(char) * TABLE_NAME_SIZE);
/* parse geom_column_name and table_name */
- if (!msSplitData( layer->data, geom_column_name, table_name, unique, srid, &function, &version))
+ if (!msSplitData( layer->data, geom_column_name, &table_name, unique, srid, &function, &version))
msSetError( MS_ORACLESPATIALERR,
"Error parsing OracleSpatial DATA variable. Must be:"
@@ -1924,6 +1934,7 @@
"Your data statement: %s",
"msOracleSpatialLayerWhichShapes()", layer->data );
+ free(table_name);
return MS_FAILURE;
@@ -1944,6 +1955,7 @@
if (sthand->items == NULL)
msSetError( MS_ORACLESPATIALERR,"Cannot allocate layerinfo->items buffer","msOracleSpatialLayerWhichShapes()" );
+ free(table_name);
return MS_FAILURE;
@@ -1951,6 +1963,7 @@
if (items == NULL)
msSetError( MS_ORACLESPATIALERR,"Cannot allocate items buffer","msOracleSpatialLayerWhichShapes()" );
+ free(table_name);
return MS_FAILURE;
memset(items ,0,sizeof(OCIDefine *)*(layer->numitems+1));
@@ -2057,6 +2070,7 @@
/* clean items */
free(items);
+ free(table_name);
return MS_FAILURE;
@@ -2066,6 +2080,7 @@
/* clean items */
free(items);
+ free(table_name);
return MS_SUCCESS;
@@ -2343,7 +2358,8 @@
int version = 0;
int existgeom;
int count_item, flk_len, success, i;
- char query_str[6000], table_name[2000], geom_column_name[100], unique[100], srid[100];
+ char *table_name;
+ char query_str[6000], geom_column_name[100], unique[100], srid[100];
OCIParam *pard = (OCIParam *) 0;
msOracleSpatialLayerInfo *layerinfo = (msOracleSpatialLayerInfo *) layer->layerinfo;
@@ -2366,7 +2382,8 @@
sthand = (msOracleSpatialStatement *) layerinfo->orastmt;
- if (!msSplitData(layer->data, geom_column_name, table_name, unique, srid, &function, &version))
+ if (!msSplitData(layer->data, geom_column_name, &table_name, unique, srid, &function, &version))
"Error parsing OracleSpatial DATA variable. Must be: "
@@ -2376,11 +2393,11 @@
"msOracleSpatialLayerGetItems()", layer->data );
+ free(table_name);
return MS_FAILURE;
sprintf( query_str, "SELECT * FROM %s", table_name );
success = TRY( hand, OCIStmtPrepare( sthand->stmthp, hand->errhp, (text *)query_str, (ub4)strlen(query_str), (ub4)OCI_NTV_SYNTAX, (ub4)OCI_DESCRIBE_ONLY) )
&& TRY( hand, OCIStmtExecute( hand->svchp, sthand->stmthp, hand->errhp, (ub4)QUERY_SIZE, (ub4)0, (OCISnapshot *)NULL, (OCISnapshot *)NULL, (ub4)OCI_DESCRIBE_ONLY ) )
@@ -2392,6 +2409,7 @@
if (!success)
msSetError( MS_QUERYERR, "Cannot retrieve column list", "msOracleSpatialLayerGetItems()" );
+ free(table_name);
return MS_FAILURE;
@@ -2402,6 +2420,7 @@
if (layer->items == NULL)
msSetError( MS_ORACLESPATIALERR,"Cannot allocate items", "msOracleSpatialLayerGetItems()" );
+ free(table_name);
return MS_FAILURE;
@@ -2411,6 +2430,7 @@
if (sthand->items_query == NULL)
msSetError( MS_ORACLESPATIALERR,"Cannot allocate items buffer", "msOracleSpatialLayerGetItems()" );
+ free(table_name);
return MS_FAILURE;
@@ -2438,6 +2458,7 @@
if (flk == NULL)
msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the items", "msOracleSpatialLayerGetItems()" );
+ free(table_name);
return MS_FAILURE;
else
@@ -2453,6 +2474,7 @@
if (layer->items[count_item] == NULL)
msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the items buffer", "msOracleSpatialLayerGetItems()" );
+ free(table_name);
return MS_FAILURE;
else
@@ -2477,15 +2499,18 @@
if (!(existgeom))
msSetError (MS_ORACLESPATIALERR, "No geometry column, check stmt", "msOracleSpatialLayerGetItems()" );
+ free(table_name);
return MS_FAILURE;
+ free(table_name);
return msOracleSpatialLayerInitItemInfo( layer );
int msOracleSpatialLayerGetShape( layerObj *layer, shapeObj *shape, long record )
+ char *table_name;
int success, i;
int function = 0;
int version = 0;
@@ -2549,7 +2574,8 @@
memset(items ,0,sizeof(OCIDefine *)*layer->numitems);
- if (!msSplitData( layer->data, geom_column_name, table_name, unique, srid, &function, &version ))
+ if (!msSplitData( layer->data, geom_column_name, &table_name, unique, srid, &function, &version ))
@@ -2565,6 +2591,8 @@
/* clean items */
free(items);
+ free(table_name);
return MS_FAILURE;
@@ -2583,6 +2611,8 @@
/* clean items */
free(items);
+ free(table_name);
return MS_FAILURE;
else
@@ -2624,6 +2654,8 @@
/* clean items */
free(items);
+ free(table_name);
return MS_FAILURE;
@@ -2650,6 +2682,8 @@
/* clean items */
free(items);
+ free(table_name);
return MS_FAILURE;
@@ -2664,6 +2698,8 @@
/* clean items */
free(items);
+ free(table_name);
return (MS_DONE);
@@ -2683,6 +2719,8 @@
/* clean items */
free(items);
+ free(table_name);
return MS_FAILURE;
@@ -2702,6 +2740,8 @@
/* clean items */
free(items);
+ free(table_name);
return MS_FAILURE;
else
@@ -2734,6 +2774,8 @@
/* clean items */
free(items);
+ free(table_name);
return MS_FAILURE;
osShapeBounds(shape);
@@ -2745,12 +2787,15 @@
/* clean items */
free(items);
+ free(table_name);
return (MS_SUCCESS);
int msOracleSpatialLayerGetExtent(layerObj *layer, rectObj *extent)
+ char *table_name;
int success, i;
int function = 0;
int version = 0;
@@ -2800,7 +2845,8 @@
@@ -2812,6 +2858,8 @@
/* clean items */
free(items);
+ free(table_name);
return MS_FAILURE;
@@ -2853,6 +2901,8 @@
/* clean items */
free(items);
+ free(table_name);
return MS_FAILURE;
@@ -2876,6 +2926,8 @@
/* clean items */
free(items);
+ free(table_name);
return MS_FAILURE;
@@ -2912,6 +2964,7 @@
if (shape.values == NULL)
msSetError( MS_ORACLESPATIALERR, "No memory avaliable to allocate the values.", "msOracleSpatialLayerGetExtent()" );
+ free(table_name);
return MS_FAILURE;
@@ -2928,6 +2981,8 @@
/* clean items */
free(items);
+ free(table_name);
return MS_FAILURE;
else
@@ -2950,6 +3005,8 @@
/* clean items */
free(items);
+ free(table_name);
return MS_FAILURE;
@@ -2970,6 +3027,8 @@
/* clean items */
free(items);
+ free(table_name);
return(MS_SUCCESS);
More information about the mapserver-commits
