[mapserver-commits] r9552 - trunk/msautotest/wxs
svn at osgeo.org
svn at osgeo.org
Tue Nov 17 12:31:48 EST 2009
Author: tomkralidis
Date: 2009-11-17 12:31:45 -0500 (Tue, 17 Nov 2009)
New Revision: 9552
trunk/msautotest/wxs/wms_sld_proj.map
update line feeds
Modified: trunk/msautotest/wxs/wms_sld_proj.map
--- trunk/msautotest/wxs/wms_sld_proj.map 2009-11-16 21:13:59 UTC (rev 9551)
+++ trunk/msautotest/wxs/wms_sld_proj.map 2009-11-17 17:31:45 UTC (rev 9552)
@@ -1,152 +1,152 @@
-# Test WMS SLD
-# REQUIRES: INPUT=GDAL OUTPUT=PNG SUPPORTS=WMS
-# Generate map image with a new line symbology for the road layer.
-# RUN_PARMS: wms_get_map_sld_proj.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&ERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-68.125,42,-58.375,48.5&FORMAT=image/png&WIDTH=300&HEIGHT=200&STYLES=&LAYERS=road&sld_body=%3CStyledLayerDescriptor+version%3D%221.0.0%22%3E%3CNamedLayer%3E%3CName%3Eroad%3C%2FName%3E%3CUserStyle%3E%3CTitle%3Exxx%3C%2FTitle%3E%3CFeatureTypeStyle%3E%3CRule%3E%3Cogc%3AFilter+xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%3Cogc%3ABBOX%3E%3Cogc%3APropertyName%3Egeometry%3C%2Fogc%3APropertyName%3E%3Cgml%3ABox+xmlns%3Agml%3D%22http%3A%2F%2Fwww.opengis.net%2Fgml%22+srsName%3D%22EPSG%3A42304%22%3E%3Cgml%3Acoordinates+decimal%3D%22.%22+cs%3D%22%2C%22+ts%3D%22+%22%3E2232483.6411927%2C-311301.67674655+2564568.0551077%2C703794.34706916%3C%2Fgml%3Acoordinates%3E%3C%2Fgml%3ABox%3E%3C%2Fogc%3ABBOX%3E%3C%2Fogc%3AFilter%3E%3CLineSymbolizer%3E%3CGeometry%3E%3CPropertyName%3Ecenter-line%3C%2FPropertyName%3E%3C%2FGeometry%3E%3CStroke%3E%3CCssParameter+name%3D%22stroke%22%3E%23000000%3C%2FCssParameter%3E%3C%2FStroke%3E%3C%2FLineSymbolizer%3E%3C%2FRule%3E%3C%2FFeatureTypeStyle%3E%3C%2FUserStyle%3E%3C%2FNamedLayer%3E%3C%2FStyledLayerDescriptor%3E" > [RESULT_DEMIME]
-MAP
-NAME WMS_SLD
-STATUS ON
-SIZE 400 300
-EXTENT 2018000 -73300 3410396 647400
-UNITS METERS
-IMAGECOLOR 255 255 255
-SHAPEPATH ./data
-SYMBOLSET etc/symbols.sym
-FONTSET etc/fonts.txt
-OUTPUTFORMAT
- NAME GDPNG
- DRIVER "GD/PNG"
- MIMETYPE "image/png"
- IMAGEMODE RGB
- EXTENSION "png"
-END
-# Start of web interface definition
-WEB
- IMAGEPATH "/tmp/ms_tmp/"
- IMAGEURL "/ms_tmp/"
- METADATA
- "wms_title" "Test simple wms"
- "wms_onlineresource" "http://localhost/path/to/wms_simple?"
- "wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
- "ows_schemas_location" "http://ogc.dmsolutions.ca"
- END
-END
-PROJECTION
-# "init=./data/epsg2:42304"
- "init=epsg:42304"
-END
-# Start of layer definitions
-LAYER
- NAME province
- DATA province
- METADATA
- "wms_title" "province"
- "wms_description" "province"
- "wms_result_fields" "NAME_E YEAR_EST AREA_KMSQ"
- END
- TYPE POINT
- STATUS ON
- PROJECTION
- "init=epsg:42304"
- END
- DUMP TRUE
- CLASSITEM "Name_e"
- CLASS
- NAME "Province"
- COLOR 200 255 0
- OUTLINECOLOR 120 120 120
- END
-END # Layer
-LAYER
- NAME popplace
- DATA popplace
- METADATA
- "wms_title" "popplace"
- "wms_description" "Cities of I.P.E."
- "wms_result_fields" "NAME"
- "gml_NAME_alias" "NAME_ALIAS"
- END
- TYPE POINT
- STATUS ON
- PROJECTION
- "init=epsg:42304"
- END
- DUMP TRUE
- LabelItem "Name"
- CLASSITEM "Capital"
- CLASS
- EXPRESSION /./
- SYMBOL 2
- SIZE 8
- NAME "Cities"
- LABEL
- COLOR 0 0 0
- FONT Vera
- TYPE truetype
- SIZE 8
- POSITION AUTO
- PARTIALS FALSE
- OUTLINECOLOR 255 255 255
- END
- COLOR 0 0 0
- END
-END # Layer
-LAYER
- NAME road
- DATA road
- METADATA
- "wms_title" "road"
- "wms_description" "Roads of I.P.E."
- END
- TYPE LINE
- STATUS ON
- PROJECTION
- "init=epsg:42304"
- END
- DUMP TRUE
- CLASS
- NAME "Roads"
- SYMBOL 0
- COLOR 220 0 0
- END
-END # Layer
-END # Map File
+# Test WMS SLD
+# REQUIRES: INPUT=GDAL OUTPUT=PNG SUPPORTS=WMS
+# Generate map image with a new line symbology for the road layer.
+# RUN_PARMS: wms_get_map_sld_proj.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&ERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-68.125,42,-58.375,48.5&FORMAT=image/png&WIDTH=300&HEIGHT=200&STYLES=&LAYERS=road&sld_body=%3CStyledLayerDescriptor+version%3D%221.0.0%22%3E%3CNamedLayer%3E%3CName%3Eroad%3C%2FName%3E%3CUserStyle%3E%3CTitle%3Exxx%3C%2FTitle%3E%3CFeatureTypeStyle%3E%3CRule%3E%3Cogc%3AFilter+xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%3Cogc%3ABBOX%3E%3Cogc%3APropertyName%3Egeometry%3C%2Fogc%3APropertyName%3E%3Cgml%3ABox+xmlns%3Agml%3D%22http%3A%2F%2Fwww.opengis.net%2Fgml%22+srsName%3D%22EPSG%3A42304%22%3E%3Cgml%3Acoordinates+decimal%3D%22.%22+cs%3D%22%2C%22+ts%3D%22+%22%3E2232483.6411927%2C-311301.67674655+2564568.0551077%2C703794.34706916%3C%2Fgml%3Acoordinates%3E%3C%2Fgml%3ABox%3E%3C%2Fogc%3ABBOX%3E%3C%2Fogc%3AFilter%3E%3CLineSymbolizer%3E%3CGeometry%3E%3CPropertyName%3Ecenter-line%3C%2FPropertyName%3E%3C%2FGeometry%3E%3CStroke%3E%3CCssParameter+name%3D%22stroke%22%3E%23000000%3C%2FCssParameter%3E%3C%2FStroke%3E%3C%2FLineSymbolizer%3E%3C%2FRule%3E%3C%2FFeatureTypeStyle%3E%3C%2FUserStyle%3E%3C%2FNamedLayer%3E%3C%2FStyledLayerDescriptor%3E" > [RESULT_DEMIME]
+MAP
+NAME WMS_SLD
+STATUS ON
+SIZE 400 300
+EXTENT 2018000 -73300 3410396 647400
+UNITS METERS
+IMAGECOLOR 255 255 255
+SHAPEPATH ./data
+SYMBOLSET etc/symbols.sym
+FONTSET etc/fonts.txt
+OUTPUTFORMAT
+ NAME GDPNG
+ DRIVER "GD/PNG"
+ MIMETYPE "image/png"
+ IMAGEMODE RGB
+ EXTENSION "png"
+END
+# Start of web interface definition
+WEB
+ IMAGEPATH "/tmp/ms_tmp/"
+ IMAGEURL "/ms_tmp/"
+ METADATA
+ "wms_title" "Test simple wms"
+ "wms_onlineresource" "http://localhost/path/to/wms_simple?"
+ "wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
+ "ows_schemas_location" "http://ogc.dmsolutions.ca"
+ END
+END
+PROJECTION
+# "init=./data/epsg2:42304"
+ "init=epsg:42304"
+END
+# Start of layer definitions
+LAYER
+ NAME province
+ DATA province
+ METADATA
+ "wms_title" "province"
+ "wms_description" "province"
+ "wms_result_fields" "NAME_E YEAR_EST AREA_KMSQ"
+ END
+ TYPE POINT
+ STATUS ON
+ PROJECTION
+ "init=epsg:42304"
+ END
+ DUMP TRUE
+ CLASSITEM "Name_e"
+ CLASS
+ NAME "Province"
+ COLOR 200 255 0
+ OUTLINECOLOR 120 120 120
+ END
+END # Layer
+LAYER
+ NAME popplace
+ DATA popplace
+ METADATA
+ "wms_title" "popplace"
+ "wms_description" "Cities of I.P.E."
+ "wms_result_fields" "NAME"
+ "gml_NAME_alias" "NAME_ALIAS"
+ END
+ TYPE POINT
+ STATUS ON
+ PROJECTION
+ "init=epsg:42304"
+ END
+ DUMP TRUE
+ LabelItem "Name"
+ CLASSITEM "Capital"
+ CLASS
+ EXPRESSION /./
+ SYMBOL 2
+ SIZE 8
+ NAME "Cities"
+ LABEL
+ COLOR 0 0 0
+ FONT Vera
+ TYPE truetype
+ SIZE 8
+ POSITION AUTO
+ PARTIALS FALSE
+ OUTLINECOLOR 255 255 255
+ END
+ COLOR 0 0 0
+ END
+END # Layer
+LAYER
+ NAME road
+ DATA road
+ METADATA
+ "wms_title" "road"
+ "wms_description" "Roads of I.P.E."
+ END
+ TYPE LINE
+ STATUS ON
+ PROJECTION
+ "init=epsg:42304"
+ END
+ DUMP TRUE
+ CLASS
+ NAME "Roads"
+ SYMBOL 0
+ COLOR 220 0 0
+ END
+END # Layer
+END # Map File
More information about the mapserver-commits
