[mapserver-commits] r9558 - in trunk/mapserver: . mapscript/php3
mapscript/swiginc
svn at osgeo.org
svn at osgeo.org
Fri Nov 20 13:11:51 EST 2009
Author: sdlime
Date: 2009-11-20 13:11:50 -0500 (Fri, 20 Nov 2009)
New Revision: 9558
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapgeos.c
trunk/mapserver/mapscript/php3/mapscript_i.c
trunk/mapserver/mapscript/php3/php_mapscript.c
trunk/mapserver/mapscript/php3/php_mapscript.h
trunk/mapserver/mapscript/swiginc/shape.i
trunk/mapserver/mapserver.h
Added simplfy and topologyPreservingSimplify to MapScript (#2753)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-11-20 14:12:06 UTC (rev 9557)
+++ trunk/mapserver/HISTORY.TXT 2009-11-20 18:11:50 UTC (rev 9558)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- Added simplfy and topologyPreservingSimplify to MapScript (#2753)
- Fixed Oracle FastCGI memory leak (#3187)
- layer->project flag not being reset properly for drawquerylayer (#673 #2079)
Modified: trunk/mapserver/mapgeos.c
--- trunk/mapserver/mapgeos.c 2009-11-20 14:12:06 UTC (rev 9557)
+++ trunk/mapserver/mapgeos.c 2009-11-20 18:11:50 UTC (rev 9558)
@@ -667,6 +667,50 @@
#endif
+shapeObj *msGEOSSimplify(shapeObj *shape, double tolerance)
+#ifdef USE_GEOS
+ GEOSGeom g1, g2;
+ if(!shape)
+ return NULL;
+ if(!shape->geometry) /* if no geometry for the shape then build one */
+ shape->geometry = (GEOSGeom) msGEOSShape2Geometry(shape);
+ g1 = (GEOSGeom) shape->geometry;
+ if(!g1) return NULL;
+ g2 = GEOSSimplify(g1, tolerance);
+ return msGEOSGeometry2Shape(g2);
+#else
+ msSetError(MS_GEOSERR, "GEOS support is not available.", "msGEOSTopologyPreservingSimplifier()");
+ return NULL;
+#endif
+shapeObj *msGEOSTopologyPreservingSimplify(shapeObj *shape, double tolerance)
+#ifdef USE_GEOS
+ GEOSGeom g1, g2;
+ if(!shape)
+ return NULL;
+ g2 = GEOSTopologyPreserveSimplify(g1, tolerance);
+#else
+ return NULL;
+#endif
shapeObj *msGEOSConvexHull(shapeObj *shape)
#ifdef USE_GEOS
Modified: trunk/mapserver/mapscript/php3/mapscript_i.c
--- trunk/mapserver/mapscript/php3/mapscript_i.c 2009-11-20 14:12:06 UTC (rev 9557)
+++ trunk/mapserver/mapscript/php3/mapscript_i.c 2009-11-20 18:11:50 UTC (rev 9558)
@@ -1080,6 +1080,18 @@
return msGEOSBuffer(self, width);
+shapeObj *shapeObj_simplify(shapeObj *self, double tolerance)
+ return msGEOSSimplify(self, tolerance);
+shapeObj *shapeObj_topologypreservingsimplify(shapeObj *self, double tolerance)
+ return msGEOSTopologyPreservingSimplify(self, tolerance);
shapeObj *shapeObj_convexHull(shapeObj *self)
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c 2009-11-20 14:12:06 UTC (rev 9557)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c 2009-11-20 18:11:50 UTC (rev 9558)
@@ -303,6 +303,8 @@
/*geos related functions*/
DLEXPORT void php3_ms_shape_buffer(INTERNAL_FUNCTION_PARAMETERS);
+DLEXPORT void php3_ms_shape_topologypreservingsimplify(INTERNAL_FUNCTION_PARAMETERS);
+DLEXPORT void php3_ms_shape_simplify(INTERNAL_FUNCTION_PARAMETERS);
DLEXPORT void php3_ms_shape_convexhull(INTERNAL_FUNCTION_PARAMETERS);
DLEXPORT void php3_ms_shape_boundary(INTERNAL_FUNCTION_PARAMETERS);
DLEXPORT void php3_ms_shape_Union(INTERNAL_FUNCTION_PARAMETERS);
@@ -907,6 +909,8 @@
{"getpointusingmeasure", php3_ms_shape_getpointusingmeasure, NULL},
{"getmeasureusingpoint", php3_ms_shape_getmeasureusingpoint, NULL},
{"buffer", php3_ms_shape_buffer, NULL},
+ {"topologypreservingsimplify", php3_ms_shape_topologypreservingsimplify, NULL},
+ {"simplify", php3_ms_shape_simplify, NULL},
{"convexhull", php3_ms_shape_convexhull, NULL},
{"boundary", php3_ms_shape_boundary, NULL},
{"containsshape", php3_ms_shape_contains_geos, NULL},
@@ -12062,7 +12066,90 @@
+ * shape->topologypreservingsimplify(tolerance)
+/* {{{ proto int shape.topologypreservingsimplify(double tolerance)
+ Given a shape and a tolerance, return a simplified shape object using
+ underlying GEOS library*/
+ pval *pThis, *pTolerance;
+ shapeObj *self = NULL;
+ shapeObj *return_shape = NULL;
+ HashTable *list=NULL;
+ pThis = getThis();
+ if (pThis == NULL ||
+ getParameters(ht, 1, &pTolerance) !=SUCCESS)
+ WRONG_PARAM_COUNT;
+ convert_to_double(pTolerance);
+ self = (shapeObj *)_phpms_fetch_handle2(pThis,
+ PHPMS_GLOBAL(le_msshape_ref),
+ PHPMS_GLOBAL(le_msshape_new),
+ list TSRMLS_CC);
+ if (self == NULL)
+ RETURN_FALSE;
+ return_shape = shapeObj_topologypreservingsimplify(self,
+ pTolerance->value.dval);
+ if (return_shape == NULL)
+ RETURN_FALSE;
+ _phpms_build_shape_object(return_shape,
+ PHPMS_GLOBAL(le_msshape_new), NULL,
+ list, return_value TSRMLS_CC);
+ * shape->simplify(tolerance)
+/* {{{ proto int shape.simplify(double tolerance)
+ list TSRMLS_CC);
+ if (self == NULL)
+ RETURN_FALSE;
+ return_shape = shapeObj_simplify(self, pTolerance->value.dval);
+ RETURN_FALSE;
* shape->convexhull()
/* {{{ proto int shape.convexhull()
Modified: trunk/mapserver/mapscript/php3/php_mapscript.h
--- trunk/mapserver/mapscript/php3/php_mapscript.h 2009-11-20 14:12:06 UTC (rev 9557)
+++ trunk/mapserver/mapscript/php3/php_mapscript.h 2009-11-20 18:11:50 UTC (rev 9558)
@@ -261,6 +261,8 @@
pointObj *shapeObj_getmeasureusingpoint(shapeObj *self, pointObj *point);
shapeObj *shapeObj_buffer(shapeObj *self, double width);
+shapeObj *shapeObj_simplify(shapeObj *self, double tolerance);
+shapeObj *shapeObj_topologypreservingsimplify(shapeObj *self, double tolerance);
shapeObj *shapeObj_convexHull(shapeObj *self);
shapeObj *shapeObj_boundary(shapeObj *self);
int shapeObj_contains_geos(shapeObj *self, shapeObj *poshape);
Modified: trunk/mapserver/mapscript/swiginc/shape.i
--- trunk/mapserver/mapscript/swiginc/shape.i 2009-11-20 14:12:06 UTC (rev 9557)
+++ trunk/mapserver/mapscript/swiginc/shape.i 2009-11-20 18:11:50 UTC (rev 9558)
@@ -123,6 +123,12 @@
%newobject buffer;
shapeObj *buffer(double width) { return msGEOSBuffer(self, width); }
+ %newobject simplify;
+ shapeObj *simplify(double tolerance) { return msGEOSSimplify(self, tolerance); }
+ %newobject topologyPreservingSimplify;
+ shapeObj *topologyPreservingSimplify(double tolerance) { return msGEOSTopologyPreservingSimplify(self, tolerance); }
%newobject convexHull;
shapeObj *convexHull() { return msGEOSConvexHull(self); }
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2009-11-20 14:12:06 UTC (rev 9557)
+++ trunk/mapserver/mapserver.h 2009-11-20 18:11:50 UTC (rev 9558)
@@ -2346,6 +2346,8 @@
MS_DLL_EXPORT char *msGEOSShapeToWKT(shapeObj *shape);
MS_DLL_EXPORT shapeObj *msGEOSBuffer(shapeObj *shape, double width);
+MS_DLL_EXPORT shapeObj *msGEOSSimplify(shapeObj *shape, double tolerance);
+MS_DLL_EXPORT shapeObj *msGEOSTopologyPreservingSimplify(shapeObj *shape, double tolerance);
MS_DLL_EXPORT shapeObj *msGEOSConvexHull(shapeObj *shape);
MS_DLL_EXPORT shapeObj *msGEOSBoundary(shapeObj *shape);
MS_DLL_EXPORT pointObj *msGEOSGetCentroid(shapeObj *shape);
More information about the mapserver-commits
