[mapserver-commits] r9570 - tags/rel-5-6-0-rc1/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Nov 27 16:26:12 EST 2009
Author: dmorissette
Date: 2009-11-27 16:26:12 -0500 (Fri, 27 Nov 2009)
New Revision: 9570
tags/rel-5-6-0-rc1/mapserver/configure
tags/rel-5-6-0-rc1/mapserver/configure.in
tags/rel-5-6-0-rc1/mapserver/mapgeos.c
Backport and repackage release: Avoid build error with GEOS 2.2.x caused by missing GEOSSimplify() (#2753)
Modified: tags/rel-5-6-0-rc1/mapserver/configure
--- tags/rel-5-6-0-rc1/mapserver/configure 2009-11-27 21:16:01 UTC (rev 9569)
+++ tags/rel-5-6-0-rc1/mapserver/configure 2009-11-27 21:26:12 UTC (rev 9570)
@@ -10919,6 +10919,12 @@
GEOS_ENABLED=-DUSE_GEOS
+ if test 300000 -le $ac_geos_version ; then
+ echo "$as_me:$LINENO: result: GEOS >= 3.0.0 found. Adding -DGEOS_HAS_SIMPLIFY" >&5
+echo "${ECHO_T}GEOS >= 3.0.0 found. Adding -DGEOS_HAS_SIMPLIFY" >&6
+ GEOS_ENABLED="$GEOS_ENABLED -DGEOS_HAS_SIMPLIFY"
+ fi
GEOS_INCDIR=`$GEOS_CONFIG --includes`
GEOS_INC="-I$GEOS_INCDIR"
GEOS_LIB="`$GEOS_CONFIG --libs`_c"
Modified: tags/rel-5-6-0-rc1/mapserver/configure.in
--- tags/rel-5-6-0-rc1/mapserver/configure.in 2009-11-27 21:16:01 UTC (rev 9569)
+++ tags/rel-5-6-0-rc1/mapserver/configure.in 2009-11-27 21:26:12 UTC (rev 9570)
@@ -1319,6 +1319,12 @@
+ dnl GEOS 3.0+ required for GEOSSimplify
+ AC_MSG_RESULT([GEOS >= 3.0.0 found. Adding -DGEOS_HAS_SIMPLIFY])
+ fi
Modified: tags/rel-5-6-0-rc1/mapserver/mapgeos.c
--- tags/rel-5-6-0-rc1/mapserver/mapgeos.c 2009-11-27 21:16:01 UTC (rev 9569)
+++ tags/rel-5-6-0-rc1/mapserver/mapgeos.c 2009-11-27 21:26:12 UTC (rev 9570)
@@ -669,7 +669,7 @@
shapeObj *msGEOSSimplify(shapeObj *shape, double tolerance)
-#ifdef USE_GEOS
+#if defined(USE_GEOS) && defined(GEOS_HAS_SIMPLIFY)
GEOSGeom g1, g2;
if(!shape)
@@ -684,14 +684,14 @@
g2 = GEOSSimplify(g1, tolerance);
return msGEOSGeometry2Shape(g2);
#else
- msSetError(MS_GEOSERR, "GEOS support is not available.", "msGEOSTopologyPreservingSimplifier()");
+ msSetError(MS_GEOSERR, "GEOS Simplify support is not available.", "msGEOSTopologyPreservingSimplifier()");
return NULL;
#endif
shapeObj *msGEOSTopologyPreservingSimplify(shapeObj *shape, double tolerance)
-#ifdef USE_GEOS
GEOSGeom g1, g2;
if(!shape)
@@ -706,7 +706,7 @@
g2 = GEOSTopologyPreserveSimplify(g1, tolerance);
#else
return NULL;
#endif
More information about the mapserver-commits
