[mapserver-commits] r9380 - branches/branch-5-4/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Oct 5 15:37:33 EDT 2009
Author: aboudreault
Date: 2009-10-05 15:37:31 -0400 (Mon, 05 Oct 2009)
New Revision: 9380
branches/branch-5-4/mapserver/HISTORY.TXT
branches/branch-5-4/mapserver/mapdraw.c
Backport in 5.4: Fixed use of minfeaturesize auto with curved labels (#3151)
Modified: branches/branch-5-4/mapserver/HISTORY.TXT
--- branches/branch-5-4/mapserver/HISTORY.TXT 2009-10-05 17:25:12 UTC (rev 9379)
+++ branches/branch-5-4/mapserver/HISTORY.TXT 2009-10-05 19:37:31 UTC (rev 9380)
@@ -14,6 +14,8 @@
Current Version:
+- Fixed use of minfeaturesize auto with curved labels (#3151)
- Useful error message for case where PK is missing and data is
subselect (#3124)
Modified: branches/branch-5-4/mapserver/mapdraw.c
--- branches/branch-5-4/mapserver/mapdraw.c 2009-10-05 17:25:12 UTC (rev 9379)
+++ branches/branch-5-4/mapserver/mapdraw.c 2009-10-05 19:37:31 UTC (rev 9380)
@@ -1517,7 +1517,7 @@
labelObj label = layer->class[c]->label;
if(layer->labelcache) {
- if(msAddLabel(map, layer->index, c, shape, NULL, annopath, shape->text, length, &label) != MS_SUCCESS) return(MS_FAILURE);
+ if(msAddLabel(map, layer->index, c, shape, NULL, annopath, shape->text, -1, &label) != MS_SUCCESS) return(MS_FAILURE);
} else {
/* FIXME: Not sure how this should work with the label path yet */
@@ -1799,7 +1799,7 @@
} else {
/* FIXME: need to call msDrawTextLineGD() from here eventually */
/* msDrawLabel(image, label_line->point[0], shape->text, &label, &map->fontset, layer->scalefactor); */
@@ -2359,7 +2359,8 @@
if(msGetLabelSize(image,cachePtr->text, labelPtr, &r, &(map->fontset), layerPtr->scalefactor, MS_TRUE,NULL) == -1)
return(-1);
- if(labelPtr->autominfeaturesize && ((r.maxx-r.minx) > cachePtr->featuresize))
+ /* if cachePtr->featuresize is set to -1, this check has been done in msPolylineLabelPath() */
+ if(labelPtr->autominfeaturesize && (cachePtr->featuresize != -1) && ((r.maxx-r.minx) > cachePtr->featuresize))
continue; /* label too large relative to the feature */
marker_offset_x = marker_offset_y = 0; /* assume no marker */
More information about the mapserver-commits
