[mapserver-commits] r9383 - trunk/mapserver
Tue Oct 6 12:20:15 EDT 2009
Author: aboudreault
Date: 2009-10-06 12:20:15 -0400 (Tue, 06 Oct 2009)
New Revision: 9383
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapagg.cpp
   trunk/mapserver/mapgd.c
   trunk/mapserver/mapimagemap.c
   trunk/mapserver/maplabel.c
   trunk/mapserver/mappdf.c
   trunk/mapserver/mapprimitive.c
   trunk/mapserver/maprendering.c
   trunk/mapserver/mapsvg.c
   trunk/mapserver/mapswf.c
   trunk/mapserver/mapsymbol.c
Fixed some style properties are not scaled with resolution (#3153)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2009-10-06 16:19:09 UTC (rev 9382)
+++ trunk/mapserver/HISTORY.TXT	2009-10-06 16:20:15 UTC (rev 9383)
@@ -13,6 +13,9 @@
 Current Version (SVN trunk):
+- Fixed some style properties are not scaled with resolution (#3153)
 - Fixed anchor point of vertically stacked bar graphs
 - Fixed TEXT property cannot be removed in the CLASS object. PHP/Mapscript (#3063)
Modified: trunk/mapserver/mapagg.cpp
--- trunk/mapserver/mapagg.cpp	2009-10-06 16:19:09 UTC (rev 9382)
+++ trunk/mapserver/mapagg.cpp	2009-10-06 16:20:15 UTC (rev 9383)
@@ -1040,12 +1040,12 @@
         size = size*scalefactor;
     } else
         size = style->size*scalefactor;
-    size = MS_MAX(size, style->minsize);
-    size = MS_MIN(size, style->maxsize);
+    size = MS_MAX(size, (style->minsize*scalefactor));
+    size = MS_MIN(size, (style->maxsize*scalefactor));
     width = style->width*scalefactor;
-    width = MS_MAX(width, style->minwidth);
-    width = MS_MIN(width, style->maxwidth);
+    width = MS_MAX(width, (style->minwidth*scalefactor));
+    width = MS_MIN(width, (style->maxwidth*scalefactor));
     angle = (style->angle) ? style->angle : 0.0;
     angle_radians = angle*MS_DEG_TO_RAD;
@@ -1203,15 +1203,15 @@
         size = MS_NINT(size*scalefactor);
     } else
         size = MS_NINT(style->size*scalefactor);
     if (symbol->sizey)
         d = size/symbol->sizey; /* compute the scaling factor (d) on the unrotated symbol */
     else
         d = 1;
     width = MS_NINT(style->width*scalefactor);
@@ -1477,8 +1477,8 @@
   else
       size = style->size;
-  if(size*scalefactor > style->maxsize) scalefactor = (float)style->maxsize/(float)size;
-  if(size*scalefactor < style->minsize) scalefactor = (float)style->minsize/(float)size;
+  if(size*scalefactor > (style->maxsize*scalefactor)) scalefactor = (float)style->maxsize/(float)size;
+  if(size*scalefactor < (style->minsize*scalefactor)) scalefactor = (float)style->minsize/(float)size;
   gap = MS_ABS(symbol->gap)* (int) scalefactor;
   label.size = (size * scalefactor);
   // label.minsize = style->minsize;
@@ -1571,12 +1571,12 @@
         size = style->size;
     size = (size*scalefactor);
     width = (style->width*scalefactor);
     ox = style->offsetx * scalefactor;
     oy = style->offsety * scalefactor;
@@ -1760,12 +1760,12 @@
     } else
     angle_radians = style->angle*MS_DEG_TO_RAD;
@@ -1979,8 +1979,8 @@
         double size;
         size = label->size*scalefactor;
-        size = MS_MAX(size, label->minsize);
-        size = MS_MIN(size, label->maxsize);
+        size = MS_MAX(size, (label->minsize*scalefactor));
+        size = MS_MIN(size, (label->maxsize*scalefactor));
         outlinewidth = label->outlinewidth*scalefactor;
         shadowsizex = label->shadowsizex*scalefactor;
         shadowsizey = label->shadowsizey*scalefactor;
@@ -2069,8 +2069,8 @@
         char s[11]; /* UTF-8 characters can be up to 6 bytes wide, entities 10 (&thetasym;) */
Modified: trunk/mapserver/mapgd.c
--- trunk/mapserver/mapgd.c	2009-10-06 16:19:09 UTC (rev 9382)
+++ trunk/mapserver/mapgd.c	2009-10-06 16:20:15 UTC (rev 9383)
@@ -72,8 +72,8 @@
     } else
@@ -600,12 +600,12 @@
     size = style->size;
   gdImageSetThickness(hatch, width);
   /* normalize the angle (180 to 0, 0 is east, 90 is north 180 is west) */
@@ -1072,12 +1072,12 @@
     size = style->size;
   if(style->symbol >= symbolset->numsymbols || style->symbol < 0) return; /* no such symbol, 0 is OK */
   if(fc < 0) return; /* nothing to do */
@@ -1284,12 +1284,12 @@
   } else
@@ -1504,12 +1504,12 @@
   } else
@@ -1748,12 +1748,12 @@
   /* if(size*scalefactor < style->minsize) scalefactor = (float)style->minsize/(float)size; */
@@ -2025,12 +2025,12 @@
   } else
@@ -2882,8 +2882,8 @@
     double size;
 #ifdef USE_GD_FT
     if(!fontset) {
@@ -3004,8 +3004,8 @@
     char s[11]; /* UTF-8 characters can be up to 6 bytes wide, html entities 10 */
Modified: trunk/mapserver/mapimagemap.c
--- trunk/mapserver/mapimagemap.c	2009-10-06 16:19:09 UTC (rev 9382)
+++ trunk/mapserver/mapimagemap.c	2009-10-06 16:20:15 UTC (rev 9383)
@@ -989,8 +989,8 @@
   else
   if(style->symbol > symbolset->numsymbols || style->symbol < 0) return; /* no such symbol, 0 is OK */
 /* if(fc<0 && oc<0) return; // nothing to do */
@@ -1197,8 +1197,8 @@
   else
   if (suppressEmpty && p->numvalues==0) return;/* suppress area with empty title */
@@ -1410,8 +1410,8 @@
   else
 /* DEBUG_IF printf ("a"); */
 /* if(fc==-1 && oc!=-1) { // use msDrawLineSymbolIM() instead (POLYLINE) */
Modified: trunk/mapserver/maplabel.c
--- trunk/mapserver/maplabel.c	2009-10-06 16:19:09 UTC (rev 9382)
+++ trunk/mapserver/maplabel.c	2009-10-06 16:20:15 UTC (rev 9383)
@@ -779,8 +779,8 @@
     char *font=NULL;
     font = msLookupHashTable(&(fontset->fonts), label->font);
     if(!font) {
Modified: trunk/mapserver/mappdf.c
--- trunk/mapserver/mappdf.c	2009-10-06 16:19:09 UTC (rev 9382)
+++ trunk/mapserver/mappdf.c	2009-10-06 16:20:15 UTC (rev 9383)
@@ -806,8 +806,8 @@
     else
Modified: trunk/mapserver/mapprimitive.c
--- trunk/mapserver/mapprimitive.c	2009-10-06 16:19:09 UTC (rev 9382)
+++ trunk/mapserver/mapprimitive.c	2009-10-06 16:20:15 UTC (rev 9383)
@@ -1622,8 +1622,8 @@
   if(!font) {
Modified: trunk/mapserver/maprendering.c
--- trunk/mapserver/maprendering.c	2009-10-06 16:19:09 UTC (rev 9382)
+++ trunk/mapserver/maprendering.c	2009-10-06 16:20:15 UTC (rev 9383)
@@ -102,8 +102,8 @@
     if(MS_VALID_COLOR(s->outlinecolor)) {
         s->outlinewidth =  src->width * scalefactor;
-        s->outlinewidth = MS_MAX(s->outlinewidth, src->minwidth);
-        s->outlinewidth = MS_MIN(s->outlinewidth, src->maxwidth);
+        s->outlinewidth = MS_MAX(s->outlinewidth, (src->minwidth*scalefactor));
+        s->outlinewidth = MS_MIN(s->outlinewidth, (src->maxwidth*scalefactor));
     } else {
         s->outlinewidth = 0;
@@ -417,9 +417,9 @@
             /* store a reference to the renderer to be used for freeing */
             symbol->renderer = renderer;
-			width = style->width * scalefactor;
-            width = MS_MIN(width,style->maxwidth);
-            width = MS_MAX(width,style->minwidth);
+            width = style->width * scalefactor;
             if(style->offsety==-99) {
 				offsetLine = msOffsetPolyline(p,style->offsetx * width,-99);
@@ -588,8 +588,8 @@
 			    if (symbol->sizey)
 			    	scaling = size / symbol->sizey; /* compute the scaling factor (d) on the unrotated symbol */
Modified: trunk/mapserver/mapsvg.c
--- trunk/mapserver/mapsvg.c	2009-10-06 16:19:09 UTC (rev 9382)
+++ trunk/mapserver/mapsvg.c	2009-10-06 16:20:15 UTC (rev 9383)
@@ -542,15 +542,15 @@
       size = style->size;
     /* TODO: Don't get this modification, is it needed elsewhere? */
@@ -756,8 +756,8 @@
     else
     /* scale the symbol pattern */
     if (symbol->patternlength > 0)
@@ -1074,8 +1074,8 @@
         /* position, offset, angle, buffer, antialias, wrap, encoding */
         if(!fontset) {
             msSetError(MS_TTFERR, "No fontset defined.", "msDrawTextSVG()");
@@ -1360,12 +1360,12 @@
     } else
Modified: trunk/mapserver/mapswf.c
--- trunk/mapserver/mapswf.c	2009-10-06 16:19:09 UTC (rev 9382)
+++ trunk/mapserver/mapswf.c	2009-10-06 16:20:15 UTC (rev 9383)
@@ -1476,8 +1476,8 @@
     else
     if(style->symbol > symbolset->numsymbols || style->symbol < 0) /* no such symbol, 0 is OK */
@@ -1983,15 +1983,15 @@
       return;
@@ -2115,13 +2115,13 @@
     else
         return;
Modified: trunk/mapserver/mapsymbol.c
--- trunk/mapserver/mapsymbol.c	2009-10-06 16:19:09 UTC (rev 9382)
+++ trunk/mapserver/mapsymbol.c	2009-10-06 16:20:15 UTC (rev 9383)
@@ -745,8 +745,8 @@
   else
   switch(symbolset->symbol[style->symbol]->type) {
