[mapserver-commits] r9390 - branches/branch-5-4/docs/development/rfc
Tue Oct 6 15:38:20 EDT 2009
Author: dmorissette
Date: 2009-10-06 15:38:20 -0400 (Tue, 06 Oct 2009)
New Revision: 9390
   branches/branch-5-4/docs/development/rfc/ms-rfc-55.txt
Added note about limitation for MINSIZE, MAXSIZE, MINWIDTH and MAXWIDTH params in v5.6
Modified: branches/branch-5-4/docs/development/rfc/ms-rfc-55.txt
--- branches/branch-5-4/docs/development/rfc/ms-rfc-55.txt	2009-10-06 19:37:56 UTC (rev 9389)
+++ branches/branch-5-4/docs/development/rfc/ms-rfc-55.txt	2009-10-06 19:38:20 UTC (rev 9390)
@@ -7,7 +7,7 @@
 :Date: 2009/03/09
 :Authors: Daniel Morissette
 :Contact: dmorissette at mapgears.com
-:Last Edited: 2009/09/04
+:Last Edited: 2009/10/06
 :Status: Adopted (2009/03/16) and Implemented.
 :Version: MapServer 5.6
 :Id: $Id$
@@ -145,6 +145,13 @@
 by default) only when the RESOLUTION is set to the default 72 or equal
 to the DEFRESOLUTION setting.
+The implementation of this feature in v5.6 has a limitation: the STYLE's
+MINSIZE, MAXSIZE, MINWIDTH and MAXWIDTH parameters are not automatically
+adjusted to reflect the resolution change. This is because we cannot easily
+access the defresolution/resolution ratio at the level where those parameters
+are handled, and with the new rendering API in 6.0 this will no longer be
+an issue.
 Files Impacted
@@ -162,6 +169,8 @@
 * http://trac.osgeo.org/mapserver/ticket/2948
+* http://trac.osgeo.org/mapserver/ticket/3153
 Voting History
