[mapserver-commits] r9392 - trunk/docs/en/development/rfc
Tue Oct 6 15:45:18 EDT 2009
Author: dmorissette
Date: 2009-10-06 15:45:18 -0400 (Tue, 06 Oct 2009)
New Revision: 9392
   trunk/docs/en/development/rfc/ms-rfc-55.txt
Updated RFC target release to 6.0. Added note about limitation for MINSIZE, MAXSIZE, MINWIDTH and MAXWIDTH params in v5.6.
Modified: trunk/docs/en/development/rfc/ms-rfc-55.txt
--- trunk/docs/en/development/rfc/ms-rfc-55.txt	2009-10-06 19:40:53 UTC (rev 9391)
+++ trunk/docs/en/development/rfc/ms-rfc-55.txt	2009-10-06 19:45:18 UTC (rev 9392)
@@ -7,10 +7,10 @@
 :Date: 2009/03/09
 :Authors: Daniel Morissette
 :Contact: dmorissette at mapgears.com
-:Last Edited: 2009/04/03
+:Last Edited: 2009/10/06
 :Status: Adopted (2009/03/16) and Implemented.
-:Version: MapServer 6.0
-:Id: $Id: ms-rfc-55.txt 8875 2009-04-03 12:45:00Z dmorissette $
+:Version: MapServer 5.6
+:Id: $Id: ms-rfc-55.txt 9391 2009-10-06 19:40:53Z dmorissette $
 Overview
@@ -145,6 +145,13 @@
 by default) only when the RESOLUTION is set to the default 72 or equal
 to the DEFRESOLUTION setting.
+The implementation of this feature in v5.6 has a limitation: the STYLE's
+MINSIZE, MAXSIZE, MINWIDTH and MAXWIDTH parameters are not automatically
+adjusted to reflect the resolution change. This is because we cannot easily
+access the defresolution/resolution ratio at the level where those parameters
+are handled, and with the new rendering API in 6.0 this will no longer be
+an issue.
 Files Impacted
@@ -162,6 +169,8 @@
 * http://trac.osgeo.org/mapserver/ticket/2948
+* http://trac.osgeo.org/mapserver/ticket/3153
 Voting History
