[mapserver-commits] r9396 - in trunk/mapserver/xmlmapfile: . tests
Wed Oct 7 10:29:38 EDT 2009
Author: tomkralidis
Date: 2009-10-07 10:29:38 -0400 (Wed, 07 Oct 2009)
New Revision: 9396
   trunk/mapserver/xmlmapfile/mapfile.xsl
   trunk/mapserver/xmlmapfile/tests/layerset.xml
   trunk/mapserver/xmlmapfile/tests/mapfile-test.xml
   trunk/mapserver/xmlmapfile/tests/symbolset.xml
update namespaces and schema pointers (#2872)
Modified: trunk/mapserver/xmlmapfile/mapfile.xsl
--- trunk/mapserver/xmlmapfile/mapfile.xsl	2009-10-07 08:47:37 UTC (rev 9395)
+++ trunk/mapserver/xmlmapfile/mapfile.xsl	2009-10-07 14:29:38 UTC (rev 9396)
@@ -2,6 +2,7 @@
 <xsl:stylesheet version="1.0"
                 xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
                 xmlns:dyn="http://exslt.org/dynamic"
+                xmlns:ms="http://www.mapserver.org/mapserver"
                 extension-element-prefixes="dyn">
 <xsl:output  method="text"/>
Modified: trunk/mapserver/xmlmapfile/tests/layerset.xml
--- trunk/mapserver/xmlmapfile/tests/layerset.xml	2009-10-07 08:47:37 UTC (rev 9395)
+++ trunk/mapserver/xmlmapfile/tests/layerset.xml	2009-10-07 14:29:38 UTC (rev 9396)
@@ -1,5 +1,5 @@
-<LayerSet xmlns="http://mapserver.gis.umn.edu/mapserver" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver mapfile.xsd">
+<LayerSet xmlns="http://www.mapserver.org/mapserver" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.mapserver.org/mapserver ../mapfile.xsd">
   <Layer name="layer1" type="CHART" status="DEFAULT">
     <Class name="class1Layer1" status="ON">
       <backgroundColor red="244" green="43" blue="22"/>
Modified: trunk/mapserver/xmlmapfile/tests/mapfile-test.xml
--- trunk/mapserver/xmlmapfile/tests/mapfile-test.xml	2009-10-07 08:47:37 UTC (rev 9395)
+++ trunk/mapserver/xmlmapfile/tests/mapfile-test.xml	2009-10-07 14:29:38 UTC (rev 9396)
@@ -1,5 +1,5 @@
-<Map name="xmlmapfile" xmlns="http://mapserver.gis.umn.edu/mapserver" status="ON" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver mapfile.xsd" version="5.6.0">
+<Map name="xmlmapfile" xmlns="http://www.mapserver.org/mapserver" status="ON" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.mapserver.org/mapserver ../mapfile.xsd" version="5.6.0">
 	<angle>10</angle>
 	<Config>
 		<item name="CGI_CONTEXT_URL">http://mapgears.com/context/mapgears.xml</item>
Modified: trunk/mapserver/xmlmapfile/tests/symbolset.xml
--- trunk/mapserver/xmlmapfile/tests/symbolset.xml	2009-10-07 08:47:37 UTC (rev 9395)
+++ trunk/mapserver/xmlmapfile/tests/symbolset.xml	2009-10-07 14:29:38 UTC (rev 9396)
@@ -1,5 +1,5 @@
-<SymbolSet xmlns="http://mapserver.gis.umn.edu/mapserver" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver mapfile.xsd">
+<SymbolSet xmlns="http://www.mapserver.org/mapserver" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.mapserver.org/mapserver ../mapfile.xsd">
 	<Symbol name="mySymbol2" type="CARTOLINE">
 		<antialias>FALSE</antialias>
 		<character>C</character>
@@ -32,4 +32,4 @@
           </Points>
           <transparent>123</transparent>
         </Symbol>
-</SymbolSet>
\ No newline at end of file
+</SymbolSet>
