[mapserver-commits] r9407 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Oct 8 00:36:25 EDT 2009
Author: warmerdam
Date: 2009-10-08 00:36:24 -0400 (Thu, 08 Oct 2009)
New Revision: 9407
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapwcs.c
Fix WCS crash with use of datasets that aren't physical files (#2901).
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-10-08 03:37:34 UTC (rev 9406)
+++ trunk/mapserver/HISTORY.TXT 2009-10-08 04:36:24 UTC (rev 9407)
@@ -47,7 +47,9 @@
- Fix WCS coverage metadata handling if size/resolution missing (#2683).
+- Fix WCS crash with use of datasets that aren't physical files (#2901).
Version 5.6.0-beta2 (2009-10-01):
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c 2009-10-08 03:37:34 UTC (rev 9406)
+++ trunk/mapserver/mapwcs.c 2009-10-08 04:36:24 UTC (rev 9407)
@@ -2024,8 +2024,9 @@
msGDALInitialize();
+ msTryBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, layer->data);
msAcquireLock( TLOCK_GDAL );
- hDS = GDALOpen(msTryBuildPath3(szPath, layer->map->mappath, layer->map->shapepath, layer->data) , GA_ReadOnly );
+ hDS = GDALOpen( szPath, GA_ReadOnly );
if( hDS == NULL ) {
msReleaseLock( TLOCK_GDAL );
msSetError( MS_IOERR, "%s", "msWCSGetCoverageMetadata()", CPLGetLastErrorMsg() );
More information about the mapserver-commits
