[mapserver-commits] r9413 - trunk/docs/de/ogc
Thu Oct 8 08:45:51 EDT 2009
Author: assefa
Date: 2009-10-08 08:45:50 -0400 (Thu, 08 Oct 2009)
New Revision: 9413
   trunk/docs/de/ogc/wfs_server.txt
add a note on wfs 1.1 axis orientation
Modified: trunk/docs/de/ogc/wfs_server.txt
--- trunk/docs/de/ogc/wfs_server.txt	2009-10-08 12:45:32 UTC (rev 9412)
+++ trunk/docs/de/ogc/wfs_server.txt	2009-10-08 12:45:50 UTC (rev 9413)
@@ -210,6 +210,11 @@
 and never set the wfs_srs metadata at the layer level and things will work fine for
 most cases.
+Axis Orientation in WFS 1.1
+The axis order in previous versions of the WFS specifications was to always use easting (x or lon ) and northing (y or lat).  WMS 1.1 specifies that, depending on the particular SRS, the x axis may or may not be oriented West-to-East, and the y axis may or may not be oriented South-to-North. The WFS portrayal operation shall account for axis order. This affects some of the EPSG codes that were commonly used such as ESPG:4326.  The current implementation makes sure that coordinates returned to the server for the GetFeature request reflect the inverse axis orders for EPSG codes between 4000 and 5000.
 Test Your WFS Server
