[mapserver-commits] r9416 - trunk/mapserver
Thu Oct 8 12:53:47 EDT 2009
Author: aboudreault
Date: 2009-10-08 12:53:47 -0400 (Thu, 08 Oct 2009)
New Revision: 9416
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapdraw.c
   trunk/mapserver/mapprimitive.c
   trunk/mapserver/mapserver.h
[Thu Oct  8 11:24:28 2009].761606 point_repeat: 1, line_length: 460.059, total_length: 460.059, point_position: 230.029, point_distance: 0
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2009-10-08 16:50:29 UTC (rev 9415)
+++ trunk/mapserver/HISTORY.TXT	2009-10-08 16:53:47 UTC (rev 9416)
@@ -15,6 +15,8 @@
 Version 5.6.0-beta3 (2009-10-07):
+- Fixed label placement using ANGLE AUTO are not always positioned correctly (#3160)
 - Enable output of geometry in GML GetFeatureInfo if wms_geometries and
   wms_geom_type are specified (#2989)
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c	2009-10-08 16:50:29 UTC (rev 9415)
+++ trunk/mapserver/mapdraw.c	2009-10-08 16:53:47 UTC (rev 9416)
@@ -1578,7 +1578,7 @@
         if(layer->class[c]->label.autofollow == MS_TRUE ) {
           annopaths = msPolylineLabelPath(image,&annoshape, minfeaturesize, &(map->fontset), shape->text, &(layer->class[c]->label), layer->scalefactor, &numpaths, &regularLines, &numRegularLines);
         } else {
-          annopoints = msPolylineLabelPoint(&annoshape, minfeaturesize, (layer->class[c]->label).repeatdistance, &angles, &lengths, &numpoints);
+            annopoints = msPolylineLabelPoint(&annoshape, minfeaturesize, (layer->class[c]->label).repeatdistance, &angles, &lengths, &numpoints, layer->class[c]->label.autoangle);
         msFreeShape(&annoshape);
@@ -1642,7 +1642,7 @@
         if (numRegularLines > 0)
-          annopoints = msPolylineLabelPointExtended(shape, minfeaturesize, (layer->class[c]->label).repeatdistance, &angles, &lengths, &numpoints, regularLines, numRegularLines);
+          annopoints = msPolylineLabelPointExtended(shape, minfeaturesize, (layer->class[c]->label).repeatdistance, &angles, &lengths, &numpoints, regularLines, numRegularLines, MS_FALSE);
           for (i = 0; i < numpoints; i++)
@@ -1680,7 +1680,7 @@
               angles = NULL;
               lengths = NULL;
-            annopoints = msPolylineLabelPoint(shape, minfeaturesize, (layer->class[c]->label).repeatdistance, &angles, &lengths, &numpoints);
+            annopoints = msPolylineLabelPoint(shape, minfeaturesize, (layer->class[c]->label).repeatdistance, &angles, &lengths, &numpoints, layer->class[c]->label.autoangle);
           for (i = 0; i < numpoints; i++) {
@@ -1903,7 +1903,7 @@
       if(layer->class[c]->label.autofollow == MS_TRUE) {
       } else {
@@ -2003,7 +2003,7 @@
@@ -2038,7 +2038,7 @@
             angles = NULL;
             lengths = NULL;
Modified: trunk/mapserver/mapprimitive.c
--- trunk/mapserver/mapprimitive.c	2009-10-08 16:50:29 UTC (rev 9415)
+++ trunk/mapserver/mapprimitive.c	2009-10-08 16:53:47 UTC (rev 9416)
@@ -1304,16 +1304,17 @@
  * max_line_index: out parameter, the index of the longest lineString of the multiLineString.
  * max_line_length: out parameter, the length of the longest lineString of the multiLineString.
  * total_length: out parameter, the total length of the MultiLineString
+ * segment_index: out parameter, the index of the longest lineString of the multiLineString.
-void msPolylineComputeLineSegments(shapeObj *shape, double ***segment_lengths, double **line_lengths, int *max_line_index, double *max_line_length, double *total_length)
+void msPolylineComputeLineSegments(shapeObj *shape, double ***segment_lengths, double **line_lengths, int *max_line_index, double *max_line_length, int *segment_index, double *total_length)
-  int i, j, segment_index, temp_segment_index;
+  int i, j, temp_segment_index;
   double segment_length, max_segment_length;
   (*segment_lengths) = (double **) malloc(sizeof(double *) * shape->numlines);
   (*line_lengths) = (double *) malloc(sizeof(double) * shape->numlines);
-  temp_segment_index = segment_index = *max_line_index = 0;
+  temp_segment_index = *segment_index = *max_line_index = 0;
   *total_length = 0;
   *max_line_length = 0;
@@ -1338,7 +1339,7 @@
     if((*line_lengths)[i] > *max_line_length) {
       *max_line_length = (*line_lengths)[i];
       *max_line_index = i;
-      segment_index = temp_segment_index;
+      *segment_index = temp_segment_index;
@@ -1347,15 +1348,15 @@
 ** If no repeatdistance, find center of longest segment in polyline p. The polyline must have been converted
 ** to image coordinates before calling this function.
-pointObj** msPolylineLabelPoint(shapeObj *p, int min_length, int repeat_distance, double ***angles, double ***lengths, int *numpoints)
+pointObj** msPolylineLabelPoint(shapeObj *p, int min_length, int repeat_distance, double ***angles, double ***lengths, int *numpoints, int center_on_longest_segment)
-  return msPolylineLabelPointExtended(p, min_length, repeat_distance, angles, lengths, numpoints, NULL, 0);
+  return msPolylineLabelPointExtended(p, min_length, repeat_distance, angles, lengths, numpoints, NULL, 0, center_on_longest_segment);
-pointObj** msPolylineLabelPointExtended(shapeObj *p, int min_length, int repeat_distance, double ***angles, double ***lengths, int *numpoints, int *regularLines, int numlines)
+pointObj** msPolylineLabelPointExtended(shapeObj *p, int min_length, int repeat_distance, double ***angles, double ***lengths, int *numpoints, int *regularLines, int numlines, int center_on_longest_segment)
   double total_length, max_line_length;
-  int i,j, max_line_index, labelpoints_index, labelpoints_size;
+  int i,j, max_line_index, segment_index, labelpoints_index, labelpoints_size;
   double** segment_lengths;
   double* line_lengths;
   pointObj** labelpoints;
@@ -1368,22 +1369,22 @@
   (*angles) = (double **) malloc(sizeof(double *) * labelpoints_size);
   (*lengths) = (double **) malloc(sizeof(double *) * labelpoints_size);
-  msPolylineComputeLineSegments(p, &segment_lengths, &line_lengths, &max_line_index, &max_line_length, &total_length);
+  msPolylineComputeLineSegments(p, &segment_lengths, &line_lengths, &max_line_index, &max_line_length, &segment_index, &total_length);
   if (repeat_distance > 0) {
     for(i=0; i<p->numlines; i++)
       if (numlines > 0) {
         for (j=0; j<numlines; j++)
           if (regularLines[j] == i) {
-            msPolylineLabelPointLineString(p, min_length, repeat_distance, angles, lengths, segment_lengths, i, line_lengths[i], total_length, &labelpoints_index, &labelpoints_size, &labelpoints);
+              msPolylineLabelPointLineString(p, min_length, repeat_distance, angles, lengths, segment_lengths, i, line_lengths[i], total_length, segment_index, &labelpoints_index, &labelpoints_size, &labelpoints, center_on_longest_segment);
             break;
       } else {
   else
-    msPolylineLabelPointLineString(p, min_length, repeat_distance, angles, lengths, segment_lengths, max_line_index, max_line_length, total_length, &labelpoints_index, &labelpoints_size, &labelpoints);
+      msPolylineLabelPointLineString(p, min_length, repeat_distance, angles, lengths, segment_lengths, max_line_index, max_line_length, total_length, segment_index, &labelpoints_index, &labelpoints_size, &labelpoints, center_on_longest_segment);
   *numpoints = labelpoints_index;
@@ -1400,7 +1401,7 @@
 void msPolylineLabelPointLineString(shapeObj *p, int min_length, int repeat_distance, double ***angles, double ***lengths, double** segment_lengths,
-                                    int line_index, double line_length, double total_length, int* labelpoints_index, int* labelpoints_size, pointObj ***labelpoints)
+                                    int line_index, double line_length, double total_length, int segment_index, int* labelpoints_index, int* labelpoints_size, pointObj ***labelpoints, int center_on_longest_segment)
   int i, j, k, l, n, index, point_repeat;
   double t, tmp_length, theta, fwd_length, point_distance;
@@ -1448,19 +1449,13 @@
     do {
-      j=0;
-      fwd_length = 0;
-      while (fwd_length < point_position) {
-        fwd_length += segment_lengths[i][j++];
       if (*labelpoints_index == *labelpoints_size) {
         *labelpoints_size *= 2;
         (*labelpoints) = (pointObj **) realloc(*labelpoints,sizeof(pointObj *) * (*labelpoints_size));
         (*angles) = (double **) realloc(*angles,sizeof(double *) * (*labelpoints_size));
         (*lengths) = (double **) realloc(*lengths,sizeof(double *) * (*labelpoints_size));
       index = (*labelpoints_index)++;
       (*labelpoints)[index] = (pointObj *) malloc(sizeof(pointObj));
       (*angles)[index] = (double *) malloc(sizeof(double));
@@ -1470,15 +1465,27 @@
         *(*lengths)[index] = line_length;
       else
         *(*lengths)[index] = total_length;
-      k = j;
-      if (j == p->line[i].numpoints-1)
+      /* if there is only 1 label to place... put it in the middle of the current segment (as old behavior) */
+      if (center_on_longest_segment && (point_repeat == 1))
+        j = segment_index;
+        (*labelpoints)[index]->x = (p->line[i].point[j].x + p->line[i].point[j-1].x)/2.0;
+        (*labelpoints)[index]->y = (p->line[i].point[j].y + p->line[i].point[j-1].y)/2.0;
+      } else {
+        j=0;
+        fwd_length = 0;
+        while (fwd_length < point_position) {
+          fwd_length += segment_lengths[i][j++];
         k = j-1;
-      t = 1 - (fwd_length - point_position) / segment_lengths[i][j-1];
-      (*labelpoints)[index]->x = t * (p->line[i].point[k+1].x - p->line[i].point[k].x) + p->line[i].point[k].x;
-      (*labelpoints)[index]->y = t * (p->line[i].point[k+1].y - p->line[i].point[k].y) + p->line[i].point[k].y;
+        t = 1 - (fwd_length - point_position) / segment_lengths[i][j-1];
+        (*labelpoints)[index]->x = t * (p->line[i].point[k+1].x - p->line[i].point[k].x) + p->line[i].point[k].x;
+        (*labelpoints)[index]->y = t * (p->line[i].point[k+1].y - p->line[i].point[k].y) + p->line[i].point[k].y;
       theta = asin(MS_ABS(p->line[i].point[j].x - p->line[i].point[j-1].x)/sqrt((pow((p->line[i].point[j].x - p->line[i].point[j-1].x),2.0) + pow((p->line[i].point[j].y - p->line[i].point[j-1].y),2.0))));
       if(p->line[i].point[j-1].x < p->line[i].point[j].x) { /* i.e. to the left */
@@ -1524,7 +1531,7 @@
   labelpaths = (labelPathObj **) malloc(sizeof(labelPathObj *) * labelpaths_size);
   (*regular_lines) = (int *) malloc(sizeof(int) * regular_lines_size);
   if (label->repeatdistance > 0)
     for(i=0; i<p->numlines; i++) {
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2009-10-08 16:50:29 UTC (rev 9415)
+++ trunk/mapserver/mapserver.h	2009-10-08 16:53:47 UTC (rev 9416)
@@ -1873,12 +1873,12 @@
 MS_DLL_EXPORT void msTransformShapeToPixel(shapeObj *shape, rectObj extent, double cellsize);
 MS_DLL_EXPORT void msTransformPixelToShape(shapeObj *shape, rectObj extent, double cellsize);
 MS_DLL_EXPORT void msImageCartographicPolyline(gdImagePtr im, shapeObj *p, styleObj *style, symbolObj *symbol, int c, double size, double scalefactor);
-MS_DLL_EXPORT void msPolylineComputeLineSegments(shapeObj *shape, double ***segment_lengths, double **line_lengths, int *max_line_index, double *max_line_length, double *total_length);
-MS_DLL_EXPORT pointObj** msPolylineLabelPoint(shapeObj *p, int min_length, int repeat_distance, double ***angles, double ***lengths, int *numpoints);
-MS_DLL_EXPORT pointObj** msPolylineLabelPointExtended(shapeObj *p, int min_length, int repeat_distance, double ***angles, double ***lengths, int *numpoints, int *regularLines, int numlines);
+MS_DLL_EXPORT void msPolylineComputeLineSegments(shapeObj *shape, double ***segment_lengths, double **line_lengths, int *max_line_index, double *max_line_length, int *segment_index, double *total_length);
+MS_DLL_EXPORT pointObj** msPolylineLabelPoint(shapeObj *p, int min_length, int repeat_distance, double ***angles, double ***lengths, int *numpoints, int center_on_longest_segment);
+MS_DLL_EXPORT pointObj** msPolylineLabelPointExtended(shapeObj *p, int min_length, int repeat_distance, double ***angles, double ***lengths, int *numpoints, int *regularLines, int numlines, int center_on_longest_segment);
 MS_DLL_EXPORT void msPolylineLabelPointLineString(shapeObj *p, int min_length, int repeat_distance, double ***angles, double ***lengths, double** segment_lengths,
-                                                  int* labelpoints_index, int* labelpoints_size, pointObj ***labelpoints);
+                                                  int* labelpoints_index, int* labelpoints_size, pointObj ***labelpoints, int center_on_longest_segment);
 MS_DLL_EXPORT labelPathObj** msPolylineLabelPath(imageObj *img, shapeObj *p, int min_length, fontSetObj *fontset, char *string, labelObj *label, double scalefactor, int *numpaths, int** regular_lines, int* num_regular_Lines);
 MS_DLL_EXPORT void msPolylineLabelPathLineString(imageObj *img, shapeObj *p, int min_length, fontSetObj *fontset, char *string, labelObj *label, double scalefactor,
                                                  int line_index, double** segment_lengths, double line_length, double total_length,
