[mapserver-commits] r9419 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Thu Oct 8 14:04:12 EDT 2009
Author: dmorissette
Date: 2009-10-08 14:04:12 -0400 (Thu, 08 Oct 2009)
New Revision: 9419
trunk/mapserver/mapgml.c
Restore previous behavior of outputing a bounding box by default in GML GetFeatureInfo output (#2989)
Modified: trunk/mapserver/mapgml.c
--- trunk/mapserver/mapgml.c 2009-10-08 16:57:59 UTC (rev 9418)
+++ trunk/mapserver/mapgml.c 2009-10-08 18:04:12 UTC (rev 9419)
@@ -1286,7 +1286,8 @@
msFree(value);
/* write the feature geometry and bounding box */
- if(geometryList && geometryList->numgeometries > 0 && strcasecmp(geometryList->geometries[0].name, "none") != 0) {
+ if(!(geometryList && geometryList->numgeometries == 1 && strcasecmp(geometryList->geometries[0].name, "none") == 0)) {
+// if(geometryList && geometryList->numgeometries > 0 && strcasecmp(geometryList->geometries[0].name, "none") != 0) {
#ifdef USE_PROJ
if(msOWSGetEPSGProj(&(map->projection), &(map->web.metadata), namespaces, MS_TRUE)) { /* use the map projection first */
More information about the mapserver-commits
