[mapserver-commits] r9436 - trunk/docs/en/input
svn at osgeo.org
svn at osgeo.org
Fri Oct 9 17:49:13 EDT 2009
Author: warmerdam
Date: 2009-10-09 17:49:13 -0400 (Fri, 09 Oct 2009)
New Revision: 9436
trunk/docs/en/input/raster.txt
Added docs for LOAD_WHOLE_IMAGE and LOAD_FULL_RES_IMAGE.
Modified: trunk/docs/en/input/raster.txt
--- trunk/docs/en/input/raster.txt 2009-10-09 21:37:58 UTC (rev 9435)
+++ trunk/docs/en/input/raster.txt 2009-10-09 21:49:13 UTC (rev 9436)
@@ -534,6 +534,24 @@
PROCESSING "RESAMPLE=NEAREST"
PROCESSING "RESAMPLE=AVERAGE"
PROCESSING "RESAMPLE=BILINEAR"
+**LOAD_FULL_RES_IMAGE=YES/NO**
+ This option affects how image data is loaded for the resampler when
+ reprojecting or otherwise going through complex resampling (as opposed
+ to the fast default image decimation code path). This forces the source
+ image to be loaded at full resolution if turned on (default is NO). This
+ helps work around problems with default image resolution selection in
+ when radical warping is being done. It can result in very slow processing
+ if the source image is large.
+**LOAD_WHOLE_IMAGE=YES/NO**
+ This option affects how image data is loaded for the resampler (as above).
+ This option, if turned on, will cause the whole source image to be loaded
+ and helps make up for problem identifying the area required, usually due
+ to radical image reprojection near a dateline or projection "horizon".
+ The default is NO. Turning this on can dramatically affect rendering
+ performance and memory requirements.
Raster Query
More information about the mapserver-commits
