[mapserver-commits] r9450 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Oct 13 11:46:22 EDT 2009
Author: assefa
Date: 2009-10-13 11:46:14 -0400 (Tue, 13 Oct 2009)
New Revision: 9450
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapsvg.c
Use decimal values for size and width in SVG output format (#2835)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-10-13 15:24:45 UTC (rev 9449)
+++ trunk/mapserver/HISTORY.TXT 2009-10-13 15:46:14 UTC (rev 9450)
@@ -14,6 +14,7 @@
Current Version (SVN trunk):
+- Use decimal values for size and width in SVG output format (#2835)
- Correct invalid test when loading movies in an swf ouput (#2524)
Modified: trunk/mapserver/mapsvg.c
--- trunk/mapserver/mapsvg.c 2009-10-13 15:24:45 UTC (rev 9449)
+++ trunk/mapserver/mapsvg.c 2009-10-13 15:46:14 UTC (rev 9450)
@@ -314,7 +314,7 @@
/* Draws an svg line element. */
static void imagePolyline(FILE *fp, int bCompressed, shapeObj *p,
- colorObj *color, int size,
+ colorObj *color, double size,
int symbolstylelength, int *symbolstyle, int bFullRes)
int i, j, k;
@@ -344,11 +344,11 @@
pszDashArray = msStringConcatenate(pszDashArray, szTmp);
- msIO_fprintfgz(fp, bCompressed, "<polyline fill=\"none\" stroke=\"#%02x%02x%02x\" stroke-width=\"%d\" stroke-dasharray=\"%s\" points=\"",color->red, color->green,
+ msIO_fprintfgz(fp, bCompressed, "<polyline fill=\"none\" stroke=\"#%02x%02x%02x\" stroke-width=\"%0.2f\" stroke-dasharray=\"%s\" points=\"",color->red, color->green,
color->blue,size, pszDashArray);
else
- msIO_fprintfgz(fp, bCompressed,"<polyline fill=\"none\" stroke=\"#%02x%02x%02x\" stroke-width=\"%d\" points=\"",color->red, color->green, color->blue,size);
+ msIO_fprintfgz(fp, bCompressed,"<polyline fill=\"none\" stroke=\"#%02x%02x%02x\" stroke-width=\"%0.2f\" points=\"",color->red, color->green, color->blue,size);
if (bFullRes)
msIO_fprintfgz(fp, bCompressed, "%.2f,%.2f", p->line[i].point[0].x, p->line[i].point[0].y);
@@ -515,7 +515,7 @@
/* int styleDashed[100]; */
int ox, oy;
double size;
- int width;
+ double width;
/* gdPoint points[MS_MAXVECTORPOINTS]; */
symbolObj *symbol;
int bFullRes;
@@ -536,7 +536,7 @@
"TRUE") == 0)
bFullRes = 1;
if(style->size == -1) {
- size = (int)msSymbolGetDefaultSize( symbolset->symbol[style->symbol] );
+ size = (double)msSymbolGetDefaultSize( symbolset->symbol[style->symbol] );
else
size = style->size;
@@ -544,11 +544,11 @@
/* TODO: Don't get this modification, is it needed elsewhere? */
if(size*scalefactor > style->maxsize) scalefactor = (float)style->maxsize/(float)size;
if(size*scalefactor < style->minsize) scalefactor = (float)style->minsize/(float)size;
- size = MS_NINT(size*scalefactor);
+ size = size*scalefactor;
size = MS_MAX(size, style->minsize);
size = MS_MIN(size, style->maxsize);
- width = MS_NINT(style->width*scalefactor);
+ width = style->width*scalefactor;
width = MS_MAX(width, style->minwidth);
width = MS_MIN(width, style->maxwidth);
@@ -557,7 +557,7 @@
if (!MS_VALID_COLOR( style->color))
return;
- if(size < 1) return; /* size too small */
+ if(size < 0) return; /* size too small */
/* TODO : do we need offset ?? */
ox = MS_NINT(style->offsetx*scalefactor);
@@ -570,7 +570,7 @@
for (i=0; i<symbol->patternlength; i++)
- symbol_pattern[i] = symbol->pattern[i]*scalefactor;
+ symbol_pattern[i] = MS_NINT(symbol->pattern[i]*scalefactor);
@@ -585,7 +585,7 @@
symbol->patternlength, symbol_pattern, bFullRes);
else
imagePolyline(image->img.svg->stream, image->img.svg->compressed,
- p, &style->color, (int)size,
+ p, &style->color, size,
return;
@@ -609,14 +609,13 @@
static void imageFillPolygon(FILE *fp, int bCompressed,
shapeObj *p, colorObj *psFillColor,
- colorObj *psOutlineColor, int size,
+ colorObj *psOutlineColor, double size,
int i, j, k,max;
char *pszDashArray = NULL;
char szTmp[100];
if (!fp || !p || (psFillColor==NULL && psOutlineColor==NULL) || size <0 )
return;
@@ -659,7 +658,7 @@
psOutlineColor->red, psOutlineColor->green,
psOutlineColor->blue,
size, pszDashArray);*/
- msIO_fprintfgz(fp, bCompressed, "<path fill=\"#%02x%02x%02x\" stroke=\"#%02x%02x%02x\" stroke-width=\"%d\" %s d=\"",
+ msIO_fprintfgz(fp, bCompressed, "<path fill=\"#%02x%02x%02x\" stroke=\"#%02x%02x%02x\" stroke-width=\"%0.2f\" %s d=\"",
psFillColor->red, psFillColor->green,
psFillColor->blue,
@@ -672,7 +671,7 @@
- msIO_fprintfgz(fp, bCompressed, "<path stroke=\"#%02x%02x%02x\" stroke-width=\"%d\" %s style=\"fill:none\" d=\"",
+ msIO_fprintfgz(fp, bCompressed, "<path stroke=\"#%02x%02x%02x\" stroke-width=\"%0.2f\" %s style=\"fill:none\" d=\"",
@@ -728,7 +727,7 @@
colorObj sFc;
colorObj sOc;
symbolObj *symbol;
- int size;
+ double size;
int bFullRes = 0;
int symbol_pattern[MS_MAXPATTERNLENGTH], i;
@@ -751,10 +750,10 @@
else
- size = MS_NINT(style->size*scalefactor);
+ size = style->size*scalefactor;
@@ -764,14 +763,14 @@
if(style->symbol > symbolset->numsymbols || style->symbol < 0) /* no such symbol, 0 is OK */
return;
- if(size < 1) /* size too small */
+ if(size < 0) /* size too small */
return;
sFc.red = style->color.red;
@@ -1205,10 +1204,10 @@
if(msGetLabelSize(image, cachePtr->text, labelPtr, &r, &(map->fontset), layerPtr->scalefactor, MS_TRUE,NULL) == -1)
return(-1);
- label_offset_x = labelPtr->offsetx*layerPtr->scalefactor;
- label_offset_y = labelPtr->offsety*layerPtr->scalefactor;
- label_buffer = labelPtr->buffer*layerPtr->scalefactor;
- label_mindistance = labelPtr->mindistance*layerPtr->scalefactor;
+ label_offset_x = MS_NINT(labelPtr->offsetx*layerPtr->scalefactor);
+ label_offset_y = MS_NINT(labelPtr->offsety*layerPtr->scalefactor);
+ label_buffer = MS_NINT(labelPtr->buffer*layerPtr->scalefactor);
+ label_mindistance = MS_NINT(labelPtr->mindistance*layerPtr->scalefactor);
if(labelPtr->autominfeaturesize && ((r.maxx-r.minx) > cachePtr->featuresize))
continue; /* label too large relative to the feature */
@@ -1330,7 +1329,7 @@
char szTmp[100];
symbolObj *symbol=NULL;
double size,d;
- int width;
+ double width;
int x,y,rx,ry;
char *pszFill = NULL, *pszStroke=NULL;
int bFillSetToNone = 0;
@@ -1363,7 +1362,7 @@
@@ -1533,7 +1532,7 @@
msIO_fprintfgz(image->img.svg->stream,
- "<polygon %s %s stroke-width=\"%d\" points=\"",
+ "<polygon %s %s stroke-width=\"%0.2f\" points=\"",
pszFill, pszStroke, width);
for (i=0; i<k;i++)
@@ -1560,7 +1559,7 @@
for (i=0; i<k;i++)
@@ -1594,7 +1593,7 @@
newpnt.y = MS_NINT(d*symbol->points[j].y + offset_y);
- "<line x1=\"%d\" y1=\"%d\" x2=\"%d\" y2=\"%d\" %s %s stroke-width=\"%d\" stroke-linecap=\"round\"/>\n",
+ "<line x1=\"%d\" y1=\"%d\" x2=\"%d\" y2=\"%d\" %s %s stroke-width=\"%0.2f\" stroke-linecap=\"round\"/>\n",
(int)oldpnt.x, (int)oldpnt.y, (int)newpnt.x, (int)newpnt.y,
oldpnt = newpnt;
More information about the mapserver-commits
