[mapserver-commits] r9454 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Tue Oct 13 16:57:56 EDT 2009
Author: aboudreault
Date: 2009-10-13 16:57:54 -0400 (Tue, 13 Oct 2009)
New Revision: 9454
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapgd.c
trunk/mapserver/maplabel.c
Added resolution scaling of some properties for GD driver (#3157)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-10-13 20:06:23 UTC (rev 9453)
+++ trunk/mapserver/HISTORY.TXT 2009-10-13 20:57:54 UTC (rev 9454)
@@ -15,6 +15,8 @@
Current Version (SVN trunk):
+- Added resolution scaling of some properties for GD driver (#3157)
- Modified GD functions API to be consistent with all others drivers (#3157)
- OGC Filter: strip all namespaces (not only ogc, gml) (#1350)
Modified: trunk/mapserver/mapgd.c
--- trunk/mapserver/mapgd.c 2009-10-13 20:06:23 UTC (rev 9453)
+++ trunk/mapserver/mapgd.c 2009-10-13 20:57:54 UTC (rev 9454)
@@ -72,8 +72,8 @@
size = MS_NINT(size*scalefactor);
} else
size = MS_NINT(style->size*scalefactor);
- size = MS_MAX(size, style->minsize);
- size = MS_MIN(size, style->maxsize);
+ size = MS_MAX(size, style->minsize*img->resolutionfactor);
+ size = MS_MIN(size, style->maxsize*img->resolutionfactor);
gap = MS_ABS(symbol->gap)* (int) scalefactor;
@@ -602,12 +602,12 @@
size = style->size;
width = MS_NINT(style->width*scalefactor);
- width = MS_MAX(width, style->minwidth);
- width = MS_MIN(width, style->maxwidth);
+ width = MS_MAX(width, style->minwidth*img->resolutionfactor);
+ width = MS_MIN(width, style->maxwidth*img->resolutionfactor);
gdImageSetThickness(hatch, width);
/* normalize the angle (180 to 0, 0 is east, 90 is north 180 is west) */
@@ -1074,12 +1074,12 @@
size = style->size;
if(style->symbol >= symbolset->numsymbols || style->symbol < 0) return; /* no such symbol, 0 is OK */
if(fc < 0) return; /* nothing to do */
@@ -1286,12 +1286,12 @@
} else
angle = (style->angle) ? style->angle : 0.0;
angle_radians = angle*MS_DEG_TO_RAD;
@@ -1506,12 +1506,12 @@
} else
@@ -1746,16 +1746,16 @@
size = style->size;
/* TODO: Don't get this modification, is it needed elsewhere? */
- /* if(size*scalefactor > style->maxsize) scalefactor = (float)style->maxsize/(float)size; */
- /* if(size*scalefactor < style->minsize) scalefactor = (float)style->minsize/(float)size; */
+ /* if(size*scalefactor > style->maxsize*img->resolutionfactor) scalefactor = (float)style->maxsize/(float)size; */
+ /* if(size*scalefactor < style->minsize*img->resolutionfactor) scalefactor = (float)style->minsize/(float)size; */
@@ -1942,7 +1942,7 @@
/* and scale the pattern */
int n=0;
for(i=0; i<symbol->patternlength; i++) {
- symbol_pattern[i] = symbol->pattern[i];
+ symbol_pattern[i] = symbol->pattern[i]*img->resolutionfactor;
n += symbol_pattern[i];
style = (int *) malloc (n * sizeof(int));
@@ -2027,12 +2027,12 @@
} else
@@ -2874,8 +2874,8 @@
if(label->outlinecolor.pen == MS_PEN_UNSET) msImageSetPenGD(img->img.gd, &(label->outlinecolor));
if(label->shadowcolor.pen == MS_PEN_UNSET) msImageSetPenGD(img->img.gd, &(label->shadowcolor));
- shadowsizex = label->shadowsizex;
- shadowsizey = label->shadowsizey;
+ shadowsizex = label->shadowsizex*img->resolutionfactor;
+ shadowsizey = label->shadowsizey*img->resolutionfactor;
if(label->type == MS_TRUETYPE) {
char *error=NULL, *font=NULL;
@@ -2884,8 +2884,8 @@
double size;
size = label->size*scalefactor;
- size = MS_MAX(size, label->minsize);
- size = MS_MIN(size, label->maxsize);
+ size = MS_MAX(size, label->minsize*img->resolutionfactor);
+ size = MS_MIN(size, label->maxsize*img->resolutionfactor);
#ifdef USE_GD_FT
if(!fontset) {
@@ -3006,10 +3006,10 @@
char s[11]; /* UTF-8 characters can be up to 6 bytes wide, html entities 10 */
#ifdef USE_GD_FT
if(!fontset) {
Modified: trunk/mapserver/maplabel.c
--- trunk/mapserver/maplabel.c 2009-10-13 20:06:23 UTC (rev 9453)
+++ trunk/mapserver/maplabel.c 2009-10-13 20:57:54 UTC (rev 9454)
@@ -1082,8 +1082,8 @@
else
size = style->size;
- if(size*scalefactor > style->maxsize) scalefactor = (float)style->maxsize/(float)size;
- if(size*scalefactor < style->minsize) scalefactor = (float)style->minsize/(float)size;
+ if(size*scalefactor > style->maxsize*img->resolutionfactor) scalefactor = (float)style->maxsize/(float)size;
+ if(size*scalefactor < style->minsize*img->resolutionfactor) scalefactor = (float)style->minsize/(float)size;
label.size = size ;/* "* scalefactor" removed: this is already scaled in msDrawTextGD()*/
/* label.minsize = style->minsize; */
More information about the mapserver-commits
