[mapserver-commits] r9458 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Oct 14 15:38:21 EDT 2009
Author: sdlime
Date: 2009-10-14 15:38:17 -0400 (Wed, 14 Oct 2009)
New Revision: 9458
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapfile.c
Make sure layer extent (if set) is written when a mapfile is saved. Also made sure all extent and feature points writing in mapfile.c uses the same printf format to avoid scientific notation. (#2969)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-10-14 17:49:18 UTC (rev 9457)
+++ trunk/mapserver/HISTORY.TXT 2009-10-14 19:38:17 UTC (rev 9458)
@@ -15,6 +15,8 @@
Current Version (SVN trunk):
+- Make sure layer extents are saved when a mapfile is written (#2969)
- Fixed CurvePolygons from oracle not drawn (#2772)
- Fixed raster queries (broken by RFC 52 changes) (#3166)
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c 2009-10-14 17:49:18 UTC (rev 9457)
+++ trunk/mapserver/mapfile.c 2009-10-14 19:38:17 UTC (rev 9458)
@@ -743,7 +743,7 @@
for(i=0; i<shape->numlines; i++) {
fprintf(stream, " POINTS\n");
for(j=0; j<shape->line[i].numpoints; j++)
- fprintf(stream, " %g %g\n", shape->line[i].point[j].x, shape->line[i].point[j].y);
+ fprintf(stream, " %.15g %.15g\n", shape->line[i].point[j].x, shape->line[i].point[j].y);
fprintf(stream, " END\n");
@@ -3429,6 +3429,9 @@
if(layer->debug) fprintf(stream, " DEBUG %d\n", layer->debug);
if(layer->dump) fprintf(stream, " DUMP TRUE\n");
+ if(layer->extent.minx != -1 && layer->extent.maxx != -1 && layer->extent.miny != -1 && layer->extent.maxy != -1)
+ fprintf(stream, " EXTENT %.15g %.15g %.15g %.15g\n", layer->extent.minx, layer->extent.miny, layer->extent.maxx, layer->extent.maxy);
if(layer->filter.string) {
fprintf(stream, " FILTER ");
@@ -3648,7 +3651,7 @@
fprintf(stream, " REFERENCE\n");
fprintf(stream, " COLOR %d %d %d\n", ref->color.red, ref->color.green, ref->color.blue);
- fprintf(stream, " EXTENT %g %g %g %g\n", ref->extent.minx, ref->extent.miny, ref->extent.maxx, ref->extent.maxy);
+ fprintf(stream, " EXTENT %.15g %.15g %.15g %.15g\n", ref->extent.minx, ref->extent.miny, ref->extent.maxx, ref->extent.maxy);
fprintf(stream, " IMAGE \"%s\"\n", ref->image);
fprintf(stream, " OUTLINECOLOR %d %d %d\n", ref->outlinecolor.red, ref->outlinecolor.green, ref->outlinecolor.blue);
fprintf(stream, " SIZE %d %d\n", ref->width, ref->height);
@@ -4310,7 +4313,7 @@
if(web->error) fprintf(stream, " ERROR \"%s\"\n", web->error);
if(MS_VALID_EXTENT(web->extent))
- fprintf(stream, " EXTENT %g %g %g %g\n", web->extent.minx, web->extent.miny, web->extent.maxx, web->extent.maxy);
+ fprintf(stream, " EXTENT %.15g %.15g %.15g %.15g\n", web->extent.minx, web->extent.miny, web->extent.maxx, web->extent.maxy);
if(web->footer) fprintf(stream, " FOOTER \"%s\"\n", web->footer);
if(web->header) fprintf(stream, " HEADER \"%s\"\n", web->header);
More information about the mapserver-commits
