[mapserver-commits] r9461 - trunk/mapserver
Wed Oct 14 19:36:47 EDT 2009
Author: dmorissette
Date: 2009-10-14 19:36:46 -0400 (Wed, 14 Oct 2009)
New Revision: 9461
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/MIGRATION_GUIDE.TXT
Note about r9434 (#3024)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2009-10-14 20:37:02 UTC (rev 9460)
+++ trunk/mapserver/HISTORY.TXT	2009-10-14 23:36:46 UTC (rev 9461)
@@ -15,6 +15,11 @@
 Current Version (SVN trunk):
+- Fixed problem of text/html WMS GetFeatureInfo which was returning HTML
+  image map output instead of the expected text/html template output.
+  This was done by changing the imagemap outputformat to use the
+  "text/html; driver=imagemap" mime type (#3024)
 - more resolution fixes for resolution scaling (symbolscale case) (#3157)
 - Make sure layer extents are saved when a mapfile is written (#2969)
Modified: trunk/mapserver/MIGRATION_GUIDE.TXT
--- trunk/mapserver/MIGRATION_GUIDE.TXT	2009-10-14 20:37:02 UTC (rev 9460)
+++ trunk/mapserver/MIGRATION_GUIDE.TXT	2009-10-14 23:36:46 UTC (rev 9461)
@@ -28,7 +28,24 @@
 The axis order in previous versions of the WFS specifications was to always use easting (x or lon ) and northing (y or lat).  WMS 1.1 specifies that, depending on the particular SRS, the x axis may or may not be oriented West-to-East, and the y axis may or may not be oriented South-to-North. The WFS portrayal operation shall account for axis order. This affects some of the EPSG codes that were commonly used such as ESPG:4326.  The current implementation makes sure that coordinates returned to the server for the GetFeature request reflect the inverse axis orders for EPSG codes between 4000 and 5000.
+Change of mime-type for the imagemap outputformat
+RFC 36 added support for templated outptformats, but this new feature
+was not available for WMS GetFeatureInfo ouptut (see ticket #3024).
+In MapServer 5.6 this has been resolved by implementing lookup of output
+formats for query templates by mime-type. However this caused a conflict
+for the text/html mime-type between the actual text/html query
+templates and the preconfigured imagemap outputformat which also used the
+text/html mime-type.
+In order to resolve this conflict, the mime-type of the imagemap outputformat
+has been changed to "text/html; driver=imagemap". This is unlikely to cause
+much side-effects to existing applications, but the change is documented here
+just in case.
 MapServer 5.2 to 5.4 Migration Guide
