[mapserver-commits] r9503 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Oct 23 00:39:53 EDT 2009
Author: sdlime
Date: 2009-10-23 00:39:51 -0400 (Fri, 23 Oct 2009)
New Revision: 9503
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapserv.c
trunk/mapserver/maptemplate.h
Allow CGI mapshape and imgshape variables to consume WKT strings. (#3185)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-10-22 20:37:44 UTC (rev 9502)
+++ trunk/mapserver/HISTORY.TXT 2009-10-23 04:39:51 UTC (rev 9503)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- Allow CGI mapshape and imgshape variables to consume WKT strings (#3185)
- Added support for nautical miles unit (#3173)
- Fixed encoding metadata ignored by a few wcs/wfs 1.1 and sos requests (#3182)
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c 2009-10-22 20:37:44 UTC (rev 9502)
+++ trunk/mapserver/mapserv.c 2009-10-23 04:39:51 UTC (rev 9503)
@@ -1,5 +1,5 @@
- * $Id$
+ * $id: mapserv.c 9470 2009-10-16 16:09:31Z sdlime $
* Project: MapServer
* Purpose: MapServer CGI mainline.
@@ -526,41 +526,64 @@
continue;
- if(strcasecmp(mapserv->request->ParamNames[i],"mapshape") == 0) { /* query shape */
- lineObj line={0,NULL};
- char **tmp=NULL;
- int n, j;
+ ** Query shape consisting of map or image coordinates. It's almost identical processing so we'll do either in this block...
+ if(strcasecmp(mapserv->request->ParamNames[i], "mapshape") == 0 || strcasecmp(mapserv->request->ParamNames[i], "imgshape") == 0) {
+ if(strcasecmp(mapserv->request->ParamNames[i],"mapshape") == 0)
+ QueryCoordSource = FROMUSERSHAPE;
+ else
+ QueryCoordSource = FROMIMGSHAPE;
+ if(strchr(mapserv->request->ParamValues[i], '(') != NULL) { /* try WKT */
+ if((mapserv->map->query.shape = msShapeFromWKT(mapserv->request->ParamValues[i])) == NULL) {
+ msSetError(MS_WEBERR, "WKT parse failed for mapshape/imgshape.", "loadForm()");
+ writeError();
+ } else {
+ lineObj line={0,NULL};
+ char **tmp=NULL;
+ int n, j;
- tmp = msStringSplit(mapserv->request->ParamValues[i], ' ', &n);
+ tmp = msStringSplit(mapserv->request->ParamValues[i], ' ', &n);
- if((line.point = (pointObj *)malloc(sizeof(pointObj)*(n/2))) == NULL) {
- msSetError(MS_MEMERR, NULL, "loadForm()");
- writeError();
- line.numpoints = n/2;
+ if(n%2 != 0 || n<8) { /* n must be even and be at least 8 */
+ msSetError(MS_WEBERR, "Malformed polygon geometry for mapshape/imgshape.", "loadForm()");
+ writeError();
- msInitShape(&(mapserv->SelectShape));
- mapserv->SelectShape.type = MS_SHAPE_POLYGON;
+ line.numpoints = n/2;
+ if((line.point = (pointObj *)malloc(sizeof(pointObj)*line.numpoints)) == NULL) {
+ msSetError(MS_MEMERR, NULL, "loadForm()");
+ writeError();
- for(j=0; j<n/2; j++) {
- line.point[j].x = atof(tmp[2*j]);
- line.point[j].y = atof(tmp[2*j+1]);
+ if((mapserv->map->query.shape = (shapeObj *) malloc(sizeof(shapeObj))) == NULL) {
+ writeError();
+ msInitShape(mapserv->map->query.shape);
+ mapserv->map->query.shape->type = MS_SHAPE_POLYGON;
+ for(j=0; j<line.numpoints; j++) {
+ line.point[j].x = atof(tmp[2*j]);
+ line.point[j].y = atof(tmp[2*j+1]);
#ifdef USE_PROJ
- if(mapserv->map->projection.proj && !pj_is_latlong(mapserv->map->projection.proj)
- && (line.point[j].x >= -180.0 && line.point[j].x <= 180.0)
- && (line.point[j].y >= -90.0 && line.point[j].y <= 90.0)) {
- msProjectPoint(&(mapserv->map->latlon), &(mapserv->map->projection), &line.point[j]); /* point is a in lat/lon */
+ if(QueryCoordSource == FROMUSERSHAPE && mapserv->map->projection.proj && !pj_is_latlong(mapserv->map->projection.proj)
+ && (line.point[j].x >= -180.0 && line.point[j].x <= 180.0)
+ && (line.point[j].y >= -90.0 && line.point[j].y <= 90.0)) {
+ msProjectPoint(&(mapserv->map->latlon), &(mapserv->map->projection), &line.point[j]); /* point is a in lat/lon */
#endif
- if(msAddLine(&mapserv->SelectShape, &line) == -1) writeError();
+ if(msAddLine(mapserv->map->query.shape, &line) == -1) writeError();
- msFree(line.point);
- msFreeCharArray(tmp, n);
+ msFree(line.point);
+ msFreeCharArray(tmp, n);
- QueryCoordSource = FROMUSERSHAPE;
continue;
@@ -645,36 +668,6 @@
continue;
- if(strcasecmp(mapserv->request->ParamNames[i],"imgshape") == 0) { /* shape given in image coordinates */
- char **tmp=NULL;
- int n, j;
- writeError();
- msInitShape(&mapserv->SelectShape);
- QueryCoordSource = FROMIMGSHAPE;
- continue;
if(strcasecmp(mapserv->request->ParamNames[i],"ref.x") == 0) { /* mouse click in reference image, in pieces */
mapserv->RefPnt.x = getNumeric(mapserv->request->ParamValues[i]);
if((mapserv->RefPnt.x > (2*mapserv->map->maxsize)) || (mapserv->RefPnt.x < (-2*mapserv->map->maxsize))) {
@@ -1722,15 +1715,13 @@
if((status = msCalculateScale(mapserv->map->extent, mapserv->map->units, mapserv->map->width, mapserv->map->height, mapserv->map->resolution, &mapserv->map->scaledenom)) != MS_SUCCESS) writeError();
/* convert from image to map coordinates here (see setCoordinate) */
- for(i=0; i<mapserv->SelectShape.numlines; i++) {
- for(j=0; j<mapserv->SelectShape.line[i].numpoints; j++) {
- mapserv->SelectShape.line[i].point[j].x = MS_IMAGE2MAP_X(mapserv->SelectShape.line[i].point[j].x, mapserv->map->extent.minx, mapserv->map->cellsize);
- mapserv->SelectShape.line[i].point[j].y = MS_IMAGE2MAP_Y(mapserv->SelectShape.line[i].point[j].y, mapserv->map->extent.maxy, mapserv->map->cellsize);
+ for(i=0; i<mapserv->map->query.shape->numlines; i++) {
+ for(j=0; j<mapserv->map->query.shape->line[i].numpoints; j++) {
+ mapserv->map->query.shape->line[i].point[j].x = MS_IMAGE2MAP_X(mapserv->map->query.shape->line[i].point[j].x, mapserv->map->extent.minx, mapserv->map->cellsize);
+ mapserv->map->query.shape->line[i].point[j].y = MS_IMAGE2MAP_Y(mapserv->map->query.shape->line[i].point[j].y, mapserv->map->extent.maxy, mapserv->map->cellsize);
- mapserv->map->query.shape = (shapeObj *) malloc(sizeof(shapeObj));
- msInitShape(mapserv->map->query.shape);
- msCopyShape(&(mapserv->SelectShape), mapserv->map->query.shape);
mapserv->map->query.type = MS_QUERY_BY_SHAPE;
break;
case FROMUSERPNT:
@@ -1750,9 +1741,6 @@
break;
case FROMUSERSHAPE:
setExtent(mapserv);
break;
default: /* from an extent of some sort */
Modified: trunk/mapserver/maptemplate.h
--- trunk/mapserver/maptemplate.h 2009-10-22 20:37:44 UTC (rev 9502)
+++ trunk/mapserver/maptemplate.h 2009-10-23 04:39:51 UTC (rev 9503)
@@ -79,7 +79,7 @@
int UseShapes; /* are results of a query to be used in calculating an extent of some sort */
- shapeObj SelectShape, resultshape;
+ shapeObj resultshape;
rectObj RawExt;
More information about the mapserver-commits
