[mapserver-commits] r9507 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Oct 23 12:09:37 EDT 2009
Author: tbonfort
Date: 2009-10-23 12:09:37 -0400 (Fri, 23 Oct 2009)
New Revision: 9507
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapprimitive.c
Fix abs/fabs usage that prevented angle follow labels to be discarded if they were too wrapped on themselves
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-10-23 15:44:17 UTC (rev 9506)
+++ trunk/mapserver/HISTORY.TXT 2009-10-23 16:09:37 UTC (rev 9507)
@@ -13,6 +13,8 @@
Current Version (SVN trunk):
+- Fix abs/fabs usage that prevented angle follow labels to be discarded if they
+ were too wrapped on themselves
- Allow CGI mapshape and imgshape variables to consume WKT strings (#3185)
Modified: trunk/mapserver/mapprimitive.c
--- trunk/mapserver/mapprimitive.c 2009-10-23 15:44:17 UTC (rev 9506)
+++ trunk/mapserver/mapprimitive.c 2009-10-23 16:09:37 UTC (rev 9507)
@@ -1860,7 +1860,7 @@
/* If the difference between subsequent angles is > 80% of 180deg
bail because the line likely overlaps itself. */
- if ( k > 2 && abs(theta - labelpath->angles[k-2]) > 0.4 * MS_PI ) {
+ if ( k > 2 && fabs(theta - labelpath->angles[k-2]) > 0.4 * MS_PI ) {
goto LABEL_FAILURE;
More information about the mapserver-commits
