[mapserver-commits] r9509 - trunk/mapserver
Sat Oct 24 00:45:34 EDT 2009
Author: sdlime
Date: 2009-10-24 00:45:32 -0400 (Sat, 24 Oct 2009)
New Revision: 9509
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapshape.c
Fixed memory leak with shapefiles associated with one-pass query implementation. (#3188)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2009-10-23 17:59:43 UTC (rev 9508)
+++ trunk/mapserver/HISTORY.TXT	2009-10-24 04:45:32 UTC (rev 9509)
@@ -13,6 +13,9 @@
 Current Version (SVN trunk):
+- Fixed memory leak with shapefiles associated with one-pass query implementation (#3188)
 - Fix abs/fabs usage that prevented angle follow labels to be discarded if they
   were too wrapped on themselves
Modified: trunk/mapserver/mapshape.c
--- trunk/mapserver/mapshape.c	2009-10-23 17:59:43 UTC (rev 9508)
+++ trunk/mapserver/mapshape.c	2009-10-24 04:45:32 UTC (rev 9509)
@@ -2292,10 +2292,18 @@
 int msTiledSHPCloseVT(layerObj *layer)
-	msTiledSHPClose(layer);
-	return MS_SUCCESS;
+  msTiledSHPClose(layer);
+  return MS_SUCCESS;
+void msTiledSHPLayerFreeItemInfo(layerObj *layer)
+  if(layer->iteminfo) {
+    free(layer->iteminfo);
+    layer->iteminfo = NULL;
 int msTiledSHPLayerInitItemInfo(layerObj *layer)
   msTiledSHPLayerInfo *tSHP=NULL;
@@ -2306,6 +2314,7 @@
     return MS_FAILURE;
+  msTiledSHPLayerFreeItemInfo(layer);
   layer->iteminfo = (int *) msDBFGetItemIndexes(tSHP->shpfile->hDBF, layer->items, layer->numitems);
   if(!layer->iteminfo) return(MS_FAILURE);
@@ -2343,14 +2352,6 @@
   return MS_SUCCESS;
-void msTiledSHPLayerFreeItemInfo(layerObj *layer)
-  if(layer->iteminfo) {
-    free(layer->iteminfo);
-    layer->iteminfo = NULL;
 int msTiledSHPLayerIsOpen(layerObj *layer)
   if(layer->layerinfo)
@@ -2387,6 +2388,14 @@
 /* SHAPEFILE Layer virtual table functions */
+void msShapeFileLayerFreeItemInfo(layerObj *layer)
 int msShapeFileLayerInitItemInfo(layerObj *layer)
   shapefileObj *shpfile = shpfile = layer->layerinfo;
@@ -2396,6 +2405,7 @@
   /* iteminfo needs to be a bit more complex, a list of indexes plus the length of the list */
+  msShapeFileLayerFreeItemInfo(layer);
   layer->iteminfo = (int *) msDBFGetItemIndexes(shpfile->hDBF, layer->items, layer->numitems);
   if( ! layer->iteminfo) {
     return MS_FAILURE;
@@ -2404,16 +2414,6 @@
   return MS_SUCCESS;
-void msShapeFileLayerFreeItemInfo(layerObj *layer)
 int msShapeFileLayerOpen(layerObj *layer)
   char szPath[MS_MAXPATHLEN];
