[mapserver-commits] r9326 - trunk/mapserver
Mon Sep 21 12:15:25 EDT 2009
Author: assefa
Date: 2009-09-21 12:15:24 -0400 (Mon, 21 Sep 2009)
New Revision: 9326
   trunk/mapserver/mapogcsos.c
Remove unnecessary msLayerOpen/Close #3069
Modified: trunk/mapserver/mapogcsos.c
--- trunk/mapserver/mapogcsos.c	2009-09-21 15:22:18 UTC (rev 9325)
+++ trunk/mapserver/mapogcsos.c	2009-09-21 16:15:24 UTC (rev 9326)
@@ -1539,8 +1539,7 @@
                              /*check if the attribute specified in the procedure_item is available
                                on the layer*/
                              iItemPosition = -1;
-                             if (msLayerOpen(lpTmp) == MS_SUCCESS &&
-                                 msLayerGetItems(lpTmp) == MS_SUCCESS &&
+                             if (msLayerGetItems(lpTmp) == MS_SUCCESS &&
                                  lpTmp->resultcache && lpTmp->resultcache->numresults > 0)
                                  for(k=0; k<lpTmp->numitems; k++)
@@ -1606,7 +1605,6 @@
                                    if (papsProcedures[k] != NULL)
                                      msFree(papsProcedures[k]);
                                  msFree(papsProcedures);
-                                 msLayerClose(lpTmp);
                              else
@@ -1966,7 +1964,7 @@
               /*check if the attribute specified in the procedure_item is available */
               /*on the layer*/
               iItemPosition = -1;
-              if (msLayerOpen(lp) == MS_SUCCESS && msLayerGetItems(lp) == MS_SUCCESS && lp->resultcache && lp->resultcache->numresults > 0) {
+              if (msLayerGetItems(lp) == MS_SUCCESS && lp->resultcache && lp->resultcache->numresults > 0) {
                 for(k=0; k<lp->numitems; k++) {
                   if (strcasecmp(lp->items[k], pszProcedureItem) == 0) {
                     iItemPosition = k;
@@ -2001,7 +1999,6 @@
                   if (bLayerFound)
                     break;
-                msLayerClose(lp);
                if (bLayerFound == 0) {
                  msSetError(MS_SOSERR, "Invalid procedure value %s", "msSOSGetCapabilities()", sosparams->pszProcedure);
@@ -2445,115 +2442,111 @@
        for (i=0; i<map->numlayers; i++)
           if (GET_LAYER(map, i)->resultcache && GET_LAYER(map, i)->resultcache->numresults > 0)
-             if(msLayerOpen((GET_LAYER(map, i))) == MS_SUCCESS)
                 msLayerGetItems((GET_LAYER(map, i)));
                 pszTmp = msOWSLookupMetadata(&(map->web.metadata), "SO", "maxfeatures");
                 if (pszTmp != NULL)
-                 n1 = atoi(pszTmp);
+                  n1 = atoi(pszTmp);
                 else
-                 n1 = 0;
+                  n1 = 0;
                 if (sosparams->pszResultModel == NULL || strcasecmp(sosparams->pszResultModel, "om:Measurement") == 0)
-                    for(j=0; j<GET_LAYER(map, i)->resultcache->numresults; j++)
-                        msSOSAddMemberNode(psNsGml, psNsOm, psNsSwe, psNsXLink, psNsMs, psRootNode, map, (GET_LAYER(map, i)), j, script_url, opLayerName);
-                        if (j == n1-1)
-                          break;
+                      for(j=0; j<GET_LAYER(map, i)->resultcache->numresults; j++)
+                            msSOSAddMemberNode(psNsGml, psNsOm, psNsSwe, psNsXLink, psNsMs, psRootNode, map, (GET_LAYER(map, i)), j, script_url, opLayerName);
+                            if (j == n1-1)
+                              break;
                 else /*assuming here that pszResultModel = observation */
-                    /*layer does not define a procedure_item: this means one procedure per
-                      layer defined using sos_procedure)*/
-                    if (msOWSLookupMetadata(&(GET_LAYER(map, i)->metadata), "S", "procedure_item") == NULL)
-                        pszProcedure = msOWSLookupMetadata(&(lp->metadata), "S", "procedure");
-                        psObservationNode = msSOSAddMemberNodeObservation(psNsGml, psNsSos, psNsOm, psNsSwe, psNsXLink, psRootNode, map, (GET_LAYER(map, i)),
-        pszProcedure);
-                        /*add a result node*/
-                        psResultNode = xmlNewChild(psObservationNode, NULL, BAD_CAST "result", NULL);
+                      /*layer does not define a procedure_item: this means one procedure per
+                        layer defined using sos_procedure)*/
+                      if (msOWSLookupMetadata(&(GET_LAYER(map, i)->metadata), "S", "procedure_item") == NULL)
-                            /*add a block separator*/
-                            if (j > 0)
-                                pszBlockSep = msOWSLookupMetadata(&(map->web.metadata), "S",
-        "encoding_blockSeparator");
-                                 if (pszBlockSep)
-                                   xmlNodeAddContent(psResultNode, BAD_CAST pszBlockSep);
-                                 else
-                                   xmlNodeAddContent(psResultNode, BAD_CAST "\n");
-                            pszResult = msSOSReturnMemberResult((GET_LAYER(map, i)), j, NULL);
-                            if (pszResult)
-                                xmlNodeAddContent(psResultNode, BAD_CAST pszResult);
-                                msFree(pszResult);
+                            pszProcedure = msOWSLookupMetadata(&(lp->metadata), "S", "procedure");
+                            psObservationNode = msSOSAddMemberNodeObservation(psNsGml, psNsSos, psNsOm, psNsSwe, psNsXLink, psRootNode, map, (GET_LAYER(map, i)),
+        pszProcedure);
+                            /*add a result node*/
+                            psResultNode = xmlNewChild(psObservationNode, NULL, BAD_CAST "result", NULL);
+                                  /*add a block separator*/
+                                  if (j > 0)
+                                        pszBlockSep = msOWSLookupMetadata(&(map->web.metadata), "S",
+        "encoding_blockSeparator");
+                                        if (pszBlockSep)
+                                          xmlNodeAddContent(psResultNode, BAD_CAST pszBlockSep);
+                                        else
+                                          xmlNodeAddContent(psResultNode, BAD_CAST "\n");
+                                  pszResult = msSOSReturnMemberResult((GET_LAYER(map, i)), j, NULL);
+                                  if (pszResult)
+                                        xmlNodeAddContent(psResultNode, BAD_CAST pszResult);
+                                        msFree(pszResult);
-                    /*this is the case where procedure_item is used. Needs more management since
-                     the same data on a layer contains different procedures (procedures are
-                    one of the fields of the record)*/
-                    else
+                      /*this is the case where procedure_item is used. Needs more management since
+                        the same data on a layer contains different procedures (procedures are
+                        one of the fields of the record)*/
+                      else
-                            pszResult = msSOSReturnMemberResult((GET_LAYER(map, i)), j, &pszProcedureValue);
-                            if (!pszProcedureValue || !pszResult)
-                              continue;
-                            for (k=0; k<nDiffrentProc; k++)
-                                if (strcasecmp(paDiffrentProc[k].pszProcedure, pszProcedureValue) == 0)
-                                    if (pszBlockSep)
-                                      xmlNodeAddContent(paDiffrentProc[k].psResultNode, BAD_CAST pszBlockSep);
-                                    else
-                                      xmlNodeAddContent(paDiffrentProc[k].psResultNode, BAD_CAST "\n");
-                                    xmlNodeAddContent(paDiffrentProc[k].psResultNode, BAD_CAST pszResult);
-                                    break;
-                            if (k == nDiffrentProc) /*a new procedure*/
-                                nDiffrentProc++;
-                                if (paDiffrentProc == NULL)
-                                  paDiffrentProc = (SOSProcedureNode *)malloc(sizeof(SOSProcedureNode));
-                                else
-                                  paDiffrentProc = (SOSProcedureNode *)realloc(paDiffrentProc,
-        sizeof(SOSProcedureNode)
-        *nDiffrentProc);
+                                  pszResult = msSOSReturnMemberResult((GET_LAYER(map, i)), j, &pszProcedureValue);
+                                  if (!pszProcedureValue || !pszResult)
+                                    continue;
+                                  for (k=0; k<nDiffrentProc; k++)
+                                        if (strcasecmp(paDiffrentProc[k].pszProcedure, pszProcedureValue) == 0)
+                                              if (pszBlockSep)
+                                                xmlNodeAddContent(paDiffrentProc[k].psResultNode, BAD_CAST pszBlockSep);
+                                              else
+                                                xmlNodeAddContent(paDiffrentProc[k].psResultNode, BAD_CAST "\n");
+                                              xmlNodeAddContent(paDiffrentProc[k].psResultNode, BAD_CAST pszResult);
+                                              break;
+                                  if (k == nDiffrentProc) /*a new procedure*/
+                                        nDiffrentProc++;
+                                        if (paDiffrentProc == NULL)
+                                          paDiffrentProc = (SOSProcedureNode *)malloc(sizeof(SOSProcedureNode));
+                                        else
+                                          paDiffrentProc = (SOSProcedureNode *)realloc(paDiffrentProc,
+        sizeof(SOSProcedureNode)
+        *nDiffrentProc);
-                                paDiffrentProc[nDiffrentProc-1].pszProcedure = strdup(pszProcedureValue);
-        (GET_LAYER(map, i)),
-        pszProcedureValue);
-                                msFree(pszProcedureValue);
+                                        paDiffrentProc[nDiffrentProc-1].pszProcedure = strdup(pszProcedureValue);
+        (GET_LAYER(map, i)),
+        pszProcedureValue);
+                                        msFree(pszProcedureValue);
-                                paDiffrentProc[nDiffrentProc-1].psResultNode =
-                                  xmlNewChild(psObservationNode, NULL, BAD_CAST "result", NULL);
+                                        paDiffrentProc[nDiffrentProc-1].psResultNode =
+                                          xmlNewChild(psObservationNode, NULL, BAD_CAST "result", NULL);
-                                xmlNodeAddContent(paDiffrentProc[nDiffrentProc-1].psResultNode, BAD_CAST pszResult);
+                                        xmlNodeAddContent(paDiffrentProc[nDiffrentProc-1].psResultNode, BAD_CAST pszResult);
+                            if (paDiffrentProc)
+                                    msFree(paDiffrentProc[k].pszProcedure);
+                                  free(paDiffrentProc);
-                        if (paDiffrentProc)
-                              msFree(paDiffrentProc[k].pszProcedure);
-                            free(paDiffrentProc);
-             msLayerClose((GET_LAYER(map, i)));
@@ -2686,7 +2679,6 @@
         map->query.rect = map->extent;
         msQueryByRect(map);
-        msLayerOpen(lp);
         msLayerGetItems(lp);
         if (lp->resultcache && lp->resultcache->numresults > 0) {
@@ -2726,7 +2718,6 @@
-        msLayerClose(lp);
