[mapserver-commits] r9333 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Sep 23 19:46:25 EDT 2009
Author: dmorissette
Date: 2009-09-23 19:46:24 -0400 (Wed, 23 Sep 2009)
New Revision: 9333
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapserver.h
Prepare for 5.6.0-beta1 release
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-09-23 13:33:15 UTC (rev 9332)
+++ trunk/mapserver/HISTORY.TXT 2009-09-23 23:46:24 UTC (rev 9333)
@@ -14,6 +14,9 @@
Current Version (SVN trunk):
+Version 5.6.0-beta1 (2009-09-23):
- WMS 1.3.0 expects a CRS parameter instead of SRS (#2979)
- Allow users to set wms getmap and getlegendgraphic image format list (#455)
@@ -60,7 +63,8 @@
- Avoid double free with postgresql joins. (#2936)
-- Don't attempt to project layers given in pixel coordinates (layer->transform != MS_TRUE) (#3096)
+- Don't attempt to project layers given in pixel coordinates
+ (layer->transform != MS_TRUE) (#3096)
- Modify loading imagery from GDAL to load all bands at once to avoid multiple
passes through pixel interleaved data (mapdrawgdal.c). This is just an
@@ -83,7 +87,8 @@
- Add MS_DEBUGLEVEL and MS_ERRORFILE commandline switches for mapserv.c.
-- Exposed msMapOffsetExtent, msMapScaleExtent and msMapSetCenter methods in PHP/Mapscript (#2460)
+- Exposed msMapOffsetExtent, msMapScaleExtent and msMapSetCenter methods
+ in PHP/Mapscript (#2460)
- Removed ZEND_DEBUG define in PHP/Mapscript (#2717)
@@ -97,7 +102,8 @@
- make WFS numberOfFeatures match maxFeatures if passed (#2907)
-- Add logging in layer visibility tests to help users find why layers don't draw (#3054)
+- Add logging in layer visibility tests to help users find why layers
+ don't draw (#3054)
- include PNG libs first (#3046)
@@ -124,16 +130,19 @@
- Fixed a memory leak when unescaping quotes in logical expressions (#2938)
-- Fixed template code for item, shpxy and extent tags to properly initialize tag arguments in cases
- where there are mutiple tags in one chunk of template (#2990)
+- Fixed template code for item, shpxy and extent tags to properly initialize
+ tag arguments in cases where there are mutiple tags in one chunk of
+ template (#2990)
-- Fix mapogcfilter.c not to cause syntax error if PROJ.4 is not compiled in (#2987)
+- Fix mapogcfilter.c not to cause syntax error if PROJ.4 is not compiled
+ in (#2987)
- Rework Python MapScript's setup.py to be more like Python's to fix
a number of issues including (#2637) and to use mapserver-config
and ditch the old mapscriptvars approach
-- Prevent from changing the connection type to MS_RASTER when setConnectionType(MS_WMS) is used (#2908)
+- Prevent from changing the connection type to MS_RASTER when
+ setConnectionType(MS_WMS) is used (#2908)
- Improve rounding logic for computing the src_xoff/yoff (#2976)
@@ -142,7 +151,8 @@
- Improved security relative to untrusted directories and mapfiles (RFC 56)
-- Fixed several security issues found in an audit of the CGI application (#2939, #2941, #2942, #2943, #2944)
+- Fixed several security issues found in an audit of the CGI
+ application (#2939, #2941, #2942, #2943, #2944)
- setConnectionType(MS_WMS) doesn't work with mapscript (#2908)
@@ -185,6 +195,7 @@
- fix MIME type support (#3020)
Version 5.4.0-beta3 (2009-3-5):
@@ -192,9 +203,11 @@
- Added Java MapScript WIN64 support (#2250)
-- Fixed a problem with long running processes, embedded scalebars/legends and AGG. (#2887)
+- Fixed a problem with long running processes, embedded scalebars/legends
+ and AGG. (#2887)
-- Applied patch to deal with a couple of WCS issues (time ranges, #2487) and PostGIS tileindex-based time filters (#1856)
+- Applied patch to deal with a couple of WCS issues (time ranges, #2487)
+ and PostGIS tileindex-based time filters (#1856)
- Adding -DUSE_GENERIC_MS_NINT to the WIN64 MapScript builds (#2250)
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2009-09-23 13:33:15 UTC (rev 9332)
+++ trunk/mapserver/mapserver.h 2009-09-23 23:46:24 UTC (rev 9333)
@@ -33,10 +33,10 @@
** MapServer version - to be updated for every release
-#define MS_VERSION "5.5.0"
+#define MS_VERSION "5.6.0-beta1"
#define MS_VERSION_MAJOR 5
-#define MS_VERSION_MINOR 5
+#define MS_VERSION_MINOR 6
#define MS_VERSION_REV 0
#define MS_VERSION_NUM (MS_VERSION_MAJOR*10000+MS_VERSION_MINOR*100+MS_VERSION_REV)
More information about the mapserver-commits
