[mapserver-commits] r9357 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Sep 30 16:18:10 EDT 2009
Author: sdlime
Date: 2009-09-30 16:18:09 -0400 (Wed, 30 Sep 2009)
New Revision: 9357
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapdraw.c
Fixed query maps under the new single pass query process (#3069)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-09-29 21:34:13 UTC (rev 9356)
+++ trunk/mapserver/HISTORY.TXT 2009-09-30 20:18:09 UTC (rev 9357)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- Fixed query maps under the new single pass query process (#3069)
- WFS Client seg fault (OGR layer not opened) (#3136)
- Reduce use of sqrt() calls when determining distances (#3134)
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c 2009-09-29 21:34:13 UTC (rev 9356)
+++ trunk/mapserver/mapdraw.c 2009-09-30 20:18:09 UTC (rev 9357)
@@ -318,7 +318,6 @@
if(querymap) { /* use queryMapObj image dimensions */
if(map->querymap.width != -1) map->width = map->querymap.width;
if(map->querymap.height != -1) map->height = map->querymap.height;
- if(map->querymap.style == MS_NORMAL) querymap = MS_FALSE; /* draw as normal */
msApplyMapConfigOptions(map);
@@ -1106,7 +1105,7 @@
-** Function to draw a layer IF it already has a result cache associated with it. Called by msDrawQueryMap and via MapScript.
+** Function to draw a layer IF it already has a result cache associated with it. Called by msDrawMap and via MapScript.
int msDrawQueryLayer(mapObj *map, layerObj *layer, imageObj *image)
@@ -1120,40 +1119,52 @@
colorObj *colorbuffer = NULL;
int *mindistancebuffer = NULL;
- if(!layer->resultcache || map->querymap.style == MS_NORMAL)
- return(msDrawLayer(map, layer, image)); /* FIX ME! */
+ if(!layer->resultcache) return(msDrawLayer(map, layer, image));
- if(!layer->data && !layer->tileindex && !layer->connection && !layer->features)
- return(MS_SUCCESS); /* no data associated with this layer, not an error since layer may be used as a template from MapScript */
+ if(!msLayerIsVisible(map, layer)) return(MS_SUCCESS); /* not an error, just nothing to do */
- if(layer->type == MS_LAYER_QUERY || layer->type == MS_LAYER_TILEINDEX) return(MS_SUCCESS); /* query and tileindex layers simply can't be drawn, not an error */
if( layer->type == MS_LAYER_RASTER ) {
- msSetError( MS_QUERYERR, "Unable to draw raster layers (such as %s) as part of a query result.", "msDrawQueryLayer()", layer->name );
- return MS_FAILURE;
+ msSetError( MS_QUERYERR, "Unable to draw raster layers (such as %s) as part of a query result.", "msDrawQueryLayer()", layer->name );
+ return MS_FAILURE;
- if(map->querymap.style == MS_HILITE) { /* first, draw normally, but don't return (FIX ME!) */
- status = msDrawLayer(map, layer, image);
- if(status != MS_SUCCESS) return(MS_FAILURE); /* oops */
- if((layer->status != MS_ON) && (layer->status != MS_DEFAULT)) return(MS_SUCCESS);
- if(msEvalContext(map, layer, layer->requires) == MS_FALSE) return(MS_SUCCESS);
+ /* set annotation status */
annotate = msEvalContext(map, layer, layer->labelrequires);
if(map->scaledenom > 0) {
- if((layer->maxscaledenom > 0) && (map->scaledenom > layer->maxscaledenom)) return(MS_SUCCESS);
- if((layer->minscaledenom > 0) && (map->scaledenom <= layer->minscaledenom)) return(MS_SUCCESS);
if((layer->labelmaxscaledenom != -1) && (map->scaledenom >= layer->labelmaxscaledenom)) annotate = MS_FALSE;
if((layer->labelminscaledenom != -1) && (map->scaledenom < layer->labelminscaledenom)) annotate = MS_FALSE;
- if (layer->maxscaledenom <= 0 && layer->minscaledenom <= 0) {
- if((layer->maxgeowidth > 0) && ((map->extent.maxx - map->extent.minx) > layer->maxgeowidth)) return(MS_SUCCESS);
- if((layer->mingeowidth > 0) && ((map->extent.maxx - map->extent.minx) < layer->mingeowidth)) return(MS_SUCCESS);
+ ** Certain query map styles require us to render all features only (MS_NORMAL) or first (MS_HILITE). With
+ ** single-pass queries we have to make a copy of the layer and work from it instead.
+ if(map->querymap.style == MS_NORMAL || map->querymap.style == MS_HILITE) {
+ char *tmp_name=NULL;
+ layerObj *tmp_layer=NULL;
+ tmp_name = (char *) malloc((strlen(layer->name)+5+1)*sizeof(char));
+ sprintf(tmp_name, "%s_copy", layer->name);
+ i = msGetLayerIndex(map, tmp_name);
+ if(i == -1) {
+ if(msGrowMapLayers(map) == NULL) return(MS_FAILURE);
+ i = map->numlayers;
+ map->layerorder[i] = i; /* important! */
+ map->numlayers++;
+ if(initLayer((GET_LAYER(map, i)), map) == -1) return(MS_FAILURE);
+ tmp_layer = GET_LAYER(map, i);
+ msCopyLayer(tmp_layer, layer);
+ tmp_layer->index = i;
+ if(tmp_layer->name) free(tmp_layer->name); /* avoid leak */
+ tmp_layer->name = strdup(tmp_name);
+ status = msDrawLayer(map, tmp_layer, image);
+ tmp_layer->status = MS_DELETE; /* so we don't write the copy or draw it again */
+ if(map->querymap.style == MS_NORMAL || status != MS_SUCCESS) return(status);
/* reset layer pen values just in case the map has been previously processed */
More information about the mapserver-commits
