[mapserver-commits] r10039 - in trunk/mapserver/xmlmapfile: . tests
svn at osgeo.org
svn at osgeo.org
Thu Apr 1 11:36:44 EDT 2010
Author: aboudreault
Date: 2010-04-01 11:36:44 -0400 (Thu, 01 Apr 2010)
New Revision: 10039
trunk/mapserver/xmlmapfile/mapfile.xsl
trunk/mapserver/xmlmapfile/tests/mapfile-test.xml
Fixed XSL transformation of formatOption tags
Modified: trunk/mapserver/xmlmapfile/mapfile.xsl
--- trunk/mapserver/xmlmapfile/mapfile.xsl 2010-04-01 15:21:30 UTC (rev 10038)
+++ trunk/mapserver/xmlmapfile/mapfile.xsl 2010-04-01 15:36:44 UTC (rev 10039)
@@ -436,13 +436,14 @@
<xsl:with-param name="node" select="'ms:extension'"/>
<xsl:with-param name="quote" select="1"/>
</xsl:call-template>
+ <xsl:for-each select="ms:formatOption">
+ <xsl:call-template name="print">
+ <xsl:with-param name="indent" select="$indent"/>
+ <xsl:with-param name="text" select="concat('FORMATOPTION ','"',.,'"')"/>
+ </xsl:call-template>
+ </xsl:for-each>
- <xsl:with-param name="node" select="'ms:formatOption'"/>
- <xsl:with-param name="quote" select="1"/>
- </xsl:call-template>
- <xsl:call-template name="print">
- <xsl:with-param name="indent" select="$indent"/>
<xsl:with-param name="node" select="'ms:imageMode'"/>
Modified: trunk/mapserver/xmlmapfile/tests/mapfile-test.xml
--- trunk/mapserver/xmlmapfile/tests/mapfile-test.xml 2010-04-01 15:21:30 UTC (rev 10038)
+++ trunk/mapserver/xmlmapfile/tests/mapfile-test.xml 2010-04-01 15:36:44 UTC (rev 10039)
@@ -56,6 +56,7 @@
<driver>GDAL/GTIFF</driver>
<extension>tiff</extension>
<formatOption>TILED=YES</formatOption>
+ <formatOption>TRANSPARENCY=TRUE</formatOption>
<imageMode>FLOAT32</imageMode>
<mimeType>image/tiff</mimeType>
<transparent>OFF</transparent>
More information about the mapserver-commits
