[mapserver-commits] r10097 - trunk/msautotest/pymod
svn at osgeo.org
svn at osgeo.org
Mon Apr 12 11:38:47 EDT 2010
Author: warmerdam
Date: 2010-04-12 11:38:45 -0400 (Mon, 12 Apr 2010)
New Revision: 10097
trunk/msautotest/pymod/mstestlib.py
produce a more strident message about tests that produce no result as they may be crashes (#2157)
Modified: trunk/msautotest/pymod/mstestlib.py
--- trunk/msautotest/pymod/mstestlib.py 2010-04-11 03:40:46 UTC (rev 10096)
+++ trunk/msautotest/pymod/mstestlib.py 2010-04-12 15:38:45 UTC (rev 10097)
@@ -213,6 +213,7 @@
fail_count = 0
succeed_count = 0
init_count = 0
+ noresult_count = 0
keep_pass = 0
valgrind = 0
shp2img = 'shp2img'
@@ -295,6 +296,7 @@
command = command.strip()
command = 'valgrind --tool=memcheck --leak-check=full %s 2>result/%s.txt'%(command, out_file+".vgrind.txt")
os.system( command )
if demime:
demime_file( 'result/'+out_file )
if deversion:
@@ -325,6 +327,7 @@
print '* results dont match, TEST FAILED.'
elif cmp == 'noresult':
fail_count = fail_count + 1
+ noresult_count += 1
print '* no result file generated, TEST FAILED.'
elif cmp == 'noexpected':
print ' no expected file exists, accepting result as expected.'
@@ -340,3 +343,6 @@
print '%d tests succeeded' % succeed_count
print '%d tests failed' %fail_count
print '%d test results initialized' % init_count
+ if noresult_count > 0:
+ print '%d of failed tests produced *no* result! Serious Failure!' % noresult_count
More information about the mapserver-commits
