[mapserver-commits] r10121 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Apr 26 16:24:30 EDT 2010
Author: sdlime
Date: 2010-04-26 16:24:29 -0400 (Mon, 26 Apr 2010)
New Revision: 10121
trunk/mapserver/mapfile.c
Checked and updated writeLegend().
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c 2010-04-26 03:46:00 UTC (rev 10120)
+++ trunk/mapserver/mapfile.c 2010-04-26 20:24:29 UTC (rev 10121)
@@ -467,8 +467,6 @@
j++;
va_end(argp);
- fprintf(stream, "# value %d for %s does not map to a keyword\n", value, name);
static void writeDimension(FILE *stream, const char *tab, const char *name, int width, int height) {
@@ -486,7 +484,7 @@
fprintf(stream, "%s%s %g\n", tab, name, number);
-static void writeString(FILE *stream, char *tab, char *name, char *string) {
+static void writeString(FILE *stream, const char *tab, char *name, char *string) {
if(!string) return; /* don't output default (e.g empty string) */
if(strchr(string, '\"') != NULL)
fprintf(stream, "%s%s '%s'\n", tab, name, string);
@@ -494,7 +492,7 @@
fprintf(stream, "%s%s \"%s\"\n", tab, name, string);
-static void writeColor(colorObj *color, FILE *stream, char *name, char *tab) {
+static void writeColor(colorObj *color, FILE *stream, char *name, const char *tab) {
if(MS_VALID_COLOR(*color))
fprintf(stream, "%s%s %d %d %d\n", tab, name, color->red, color->green, color->blue);
@@ -506,7 +504,7 @@
#if ALPHACOLOR_ENABLED
-static void writeColorWithAlpha(colorObj *color, FILE *stream, char *name, char *tab) {
+static void writeColorWithAlpha(colorObj *color, FILE *stream, char *name, const char *tab) {
fprintf(stream, "%s%s %d %d %d %d\n", tab, name, color->red, color->green, color->blue, color->alpha);
@@ -1712,7 +1710,7 @@
return MS_SUCCESS;
-static void writeLabel(labelObj *label, FILE *stream, char *tab)
+static void writeLabel(labelObj *label, FILE *stream, const char *tab)
if(label->size == -1) return; /* there is no default label anymore */
@@ -4186,21 +4184,22 @@
static void writeLegend(legendObj *legend, FILE *stream)
- fprintf(stream, " LEGEND\n");
- writeColor(&(legend->imagecolor), stream, "IMAGECOLOR", " ");
- if( legend->interlace != MS_NOOVERRIDE )
- fprintf(stream, " INTERLACE %s\n", msTrueFalse[legend->interlace]);
- fprintf(stream, " KEYSIZE %d %d\n", legend->keysizex, legend->keysizey);
- fprintf(stream, " KEYSPACING %d %d\n", legend->keyspacingx, legend->keyspacingy);
- writeLabel(&(legend->label), stream, " ");
- writeColor(&(legend->outlinecolor), stream, "OUTLINECOLOR", " ");
- fprintf(stream, " POSITION %s\n", msPositionsText[legend->position - MS_UL]);
- if(legend->postlabelcache) fprintf(stream, " POSTLABELCACHE TRUE\n");
- fprintf(stream, " STATUS %s\n", msStatus[legend->status]);
- if( legend->transparent != MS_NOOVERRIDE )
- fprintf(stream, " TRANSPARENT %s\n", msTrueFalse[legend->transparent]);
- if (legend->template) fprintf(stream, " TEMPLATE \"%s\"\n", legend->template);
- fprintf(stream, " END\n\n");
+ const char *tab1 = " ", *tab2 = " ";
+ writeBlockBegin(stream, tab1, "LEGEND");
+ writeColor(&(legend->imagecolor), stream, "IMAGECOLOR", tab2);
+ writeKeyword(stream, tab2, "INTERLACE", -1, legend->interlace, 2, MS_TRUE, "TRUE", MS_FALSE, "FALSE");
+ writeDimension(stream, tab2, "KEYSIZE", legend->keysizex, legend->keysizey);
+ writeDimension(stream, tab2, "KEYSPACING", legend->keyspacingx, legend->keyspacingy);
+ writeLabel(&(legend->label), stream, tab2);
+ writeColor(&(legend->outlinecolor), stream, "OUTLINECOLOR", tab2);
+ if(legend->status == MS_EMBED) writeKeyword(stream, tab2, "POSITION", -1, legend->position, 6, MS_LL, "LL", MS_UL, "UL", MS_UR, "UR", MS_LR, "LR", MS_UC, "UC", MS_LC, "LC");
+ writeKeyword(stream, tab2, "POSTLABELCACHE", MS_FALSE, legend->postlabelcache, 1, MS_TRUE, "TRUE");
+ writeKeyword(stream, tab2, "STATUS", -1, legend->status, 3, MS_ON, "ON", MS_OFF, "OFF", MS_EMBED, "EMBED");
+ writeKeyword(stream, tab2, "TRANSPARENT", -1, legend->transparent, 2, MS_TRUE, "TRUE", MS_FALSE, "FALSE");
+ writeString(stream, tab2, "TEMPLATE", legend->template);
+ writeBlockEnd(stream, tab1, "LEGEND");
+ writeLineFeed(stream);
More information about the mapserver-commits
