[mapserver-commits] r10440 - in trunk/mapserver: . mapscript/csharp
svn at osgeo.org
svn at osgeo.org
Thu Aug 5 07:40:48 EDT 2010
Author: tamas
Date: 2010-08-05 11:40:48 +0000 (Thu, 05 Aug 2010)
New Revision: 10440
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapscript/csharp/Makefile.vc
trunk/mapserver/mapscript/csharp/swig_csharp_extensions.i
Ensure the class is not marked BeforeFieldInit causing memory corruption with C#/CLR4 (#3438)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2010-08-04 20:18:09 UTC (rev 10439)
+++ trunk/mapserver/HISTORY.TXT 2010-08-05 11:40:48 UTC (rev 10440)
@@ -13,6 +13,8 @@
Current Version (SVN trunk):
+- Ensure the class is not marked BeforeFieldInit causing memory corruption with C#/CLR4 (#3438)
- Fixed MSSQL2008 driver returning invalid extent (#3498)
- Added coordinate scaling to shpxy tag via parameters scale, scale_x or scale_y.
Modified: trunk/mapserver/mapscript/csharp/Makefile.vc
--- trunk/mapserver/mapscript/csharp/Makefile.vc 2010-08-04 20:18:09 UTC (rev 10439)
+++ trunk/mapserver/mapscript/csharp/Makefile.vc 2010-08-05 11:40:48 UTC (rev 10440)
@@ -48,7 +48,7 @@
!ENDIF
!IF $(MSVC_VER) >= 1600
-CSC = $(CSC) /define:CLR4 /debug:full
+CSC = $(CSC) /define:CLR4
!ENDIF
#SWIG = swig
Modified: trunk/mapserver/mapscript/csharp/swig_csharp_extensions.i
--- trunk/mapserver/mapscript/csharp/swig_csharp_extensions.i 2010-08-04 20:18:09 UTC (rev 10439)
+++ trunk/mapserver/mapscript/csharp/swig_csharp_extensions.i 2010-08-05 11:40:48 UTC (rev 10440)
@@ -29,6 +29,12 @@
* DEALINGS IN THE SOFTWARE.
+// Ensure the class is not marked BeforeFieldInit causing memory corruption with CLR4
+%pragma(csharp) imclasscode=%{
+ static $imclassname() {
%typemap(csout, excode=SWIGEXCODE) SWIGTYPE {
$&csclassname ret = new $&csclassname($imcall, true, null);$excode
return ret;
More information about the mapserver-commits
