[mapserver-commits] r10446 -
sandbox/sdlime/common-expressions/mapserver
svn at osgeo.org
svn at osgeo.org
Sun Aug 8 01:05:17 EDT 2010
Author: sdlime
Date: 2010-08-08 05:05:17 +0000 (Sun, 08 Aug 2010)
New Revision: 10446
sandbox/sdlime/common-expressions/mapserver/mapogr.cpp
Updated OGR driver to use new msEvalExpression() function signature.
Modified: sandbox/sdlime/common-expressions/mapserver/mapogr.cpp
--- sandbox/sdlime/common-expressions/mapserver/mapogr.cpp 2010-08-06 12:44:12 UTC (rev 10445)
+++ sandbox/sdlime/common-expressions/mapserver/mapogr.cpp 2010-08-08 05:05:17 UTC (rev 10446)
@@ -1777,8 +1777,7 @@
// Check the expression unless it is a WHERE clause already
// handled by OGR.
if( (layer->filter.string && EQUALN(layer->filter.string,"WHERE ",6))
- || msEvalExpression(&(layer->filter), layer->filteritemindex,
- shape->values, layer->numitems) == MS_TRUE)
+ || msEvalExpression(layer, shape, &(layer->filter), layer->filteritemindex) == MS_TRUE)
// Feature matched filter expression... process geometry
// shape->type will be set if geom is compatible with layer type
More information about the mapserver-commits
