[mapserver-commits] r10469 - sandbox/sdlime/common-expressions/mapserver/mapscript/swiginc
Tue Aug 24 23:52:05 EDT 2010
Author: sdlime
Date: 2010-08-25 03:52:05 +0000 (Wed, 25 Aug 2010)
New Revision: 10469
   sandbox/sdlime/common-expressions/mapserver/mapscript/swiginc/layer.i
   sandbox/sdlime/common-expressions/mapserver/mapscript/swiginc/map.i
Added Swig-based MapScript wrappers for msQueryByFilter().
Modified: sandbox/sdlime/common-expressions/mapserver/mapscript/swiginc/layer.i
--- sandbox/sdlime/common-expressions/mapserver/mapscript/swiginc/layer.i	2010-08-25 03:23:21 UTC (rev 10468)
+++ sandbox/sdlime/common-expressions/mapserver/mapscript/swiginc/layer.i	2010-08-25 03:52:05 UTC (rev 10469)
@@ -268,7 +268,30 @@
     /* For querying, we switch layer status ON and then back to original
        value before returning. */
+    int queryByFilter(mapObj *map, char *string)
+        int status;
+        int retval;
+        msInitQuery(&(map->query));
+        map->query.type = MS_QUERY_BY_FILTER;
+        map->query.filter = (expressionObj *) malloc(sizeof(expressionObj));
+        map->query.filter->string = strdup(string);
+        map->query.filter->type = 2000; /* MS_EXPRESSION: lot's of conflicts in mapfile.h */
+        map->query.layer = self->index;
+        map->query.rect = map->extent;
+     	status = self->status;
+        self->status = MS_ON;
+        retval = msQueryByFilter(map);
+        self->status = status;
+        return retval;
     int queryByAttributes(mapObj *map, char *qitem, char *qstring, int mode)
         int status;
Modified: sandbox/sdlime/common-expressions/mapserver/mapscript/swiginc/map.i
--- sandbox/sdlime/common-expressions/mapserver/mapscript/swiginc/map.i	2010-08-25 03:23:21 UTC (rev 10468)
+++ sandbox/sdlime/common-expressions/mapserver/mapscript/swiginc/map.i	2010-08-25 03:52:05 UTC (rev 10469)
@@ -240,6 +240,18 @@
       return NULL;
+  int queryByFilter(char *string) {
+    msInitQuery(&(self->query));
+    self->query.type = MS_QUERY_BY_FILTER;
+    self->query.filter = (expressionObj *) malloc(sizeof(expressionObj));
+    self->query.filter->string = strdup(string);
+    self->query.filter->type = 2000; /* MS_EXPRESSION: lot's of conflicts in mapfile.h */
+    return msQueryByFilter(self);
   int queryByPoint(pointObj *point, int mode, double buffer) {
