[mapserver-commits] r10485 -
sandbox/sdlime/common-expressions/mapserver
svn at osgeo.org
svn at osgeo.org
Sun Aug 29 23:50:05 EDT 2010
Author: sdlime
Date: 2010-08-30 03:50:04 +0000 (Mon, 30 Aug 2010)
New Revision: 10485
sandbox/sdlime/common-expressions/mapserver/mapfile.c
Added cleanup for token list to freeExpression()...
Modified: sandbox/sdlime/common-expressions/mapserver/mapfile.c
--- sandbox/sdlime/common-expressions/mapserver/mapfile.c 2010-08-27 04:18:14 UTC (rev 10484)
+++ sandbox/sdlime/common-expressions/mapserver/mapfile.c 2010-08-30 03:50:04 UTC (rev 10485)
@@ -1872,12 +1872,33 @@
void freeExpression(expressionObj *exp)
+ int i=0;
if(!exp) return;
msFree(exp->string);
if((exp->type == MS_REGEX) && exp->compiled) ms_regfree(&(exp->regex));
- /* todo: deal with tokens (case statement) */
+ for(i=0; i<exp->numtokens; i++) {
+ switch(exp->tokens[i].token) {
+ case MS_TOKEN_BINDING_DOUBLE:
+ case MS_TOKEN_BINDING_INTEGER:
+ case MS_TOKEN_BINDING_STRING:
+ case MS_TOKEN_BINDING_TIME:
+ msFree(exp->tokens[i].tokenval.bindval.item);
+ break;
+ case MS_TOKEN_LITERAL_TIME:
+ /* anything to do? */
+ break;
+ case MS_TOKEN_LITERAL_STRING:
+ msFree(exp->tokens[i].tokenval.strval);
+ break;
+ case MS_TOKEN_LITERAL_SHAPE:
+ msFreeShape(exp->tokens[i].tokenval.shpval);
+ free(exp->tokens[i].tokenval.shpval);
+ break;
initExpression(exp); /* re-initialize */
More information about the mapserver-commits
