[mapserver-commits] r10489 - in trunk/mapserver: . xmlmapfile
xmlmapfile/tests
svn at osgeo.org
svn at osgeo.org
Tue Aug 31 14:31:14 EDT 2010
Author: aboudreault
Date: 2010-08-31 18:31:14 +0000 (Tue, 31 Aug 2010)
New Revision: 10489
trunk/mapserver/HISTORY.TXT
trunk/mapserver/xmlmapfile/mapfile.xsd
trunk/mapserver/xmlmapfile/mapfile.xsl
trunk/mapserver/xmlmapfile/tests/mapfile-test.xml
Fixed multiple include tags not supported in xml mapfiles (#3530)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2010-08-31 01:12:33 UTC (rev 10488)
+++ trunk/mapserver/HISTORY.TXT 2010-08-31 18:31:14 UTC (rev 10489)
@@ -13,6 +13,9 @@
Current Version (SVN trunk):
+- Fixed multiple include tags not supported in xml mapfiles (#3530)
- Support reading .dbf files between 2GB and 4GB (#3514)
- Avoid warnings about ms_cvsid being unused with gcc.
Modified: trunk/mapserver/xmlmapfile/mapfile.xsd
--- trunk/mapserver/xmlmapfile/mapfile.xsd 2010-08-31 01:12:33 UTC (rev 10488)
+++ trunk/mapserver/xmlmapfile/mapfile.xsd 2010-08-31 18:31:14 UTC (rev 10489)
@@ -742,7 +742,7 @@
<xs:element name="fontSet" type="xs:string" minOccurs="0"/>
<xs:element name="imageColor" type="ms:rgbColorType" minOccurs="0"/>
<xs:element name="imageType" type="xs:string" minOccurs="0"/>
- <xs:element name="include" type="xs:string" minOccurs="0"/>
+ <xs:element name="include" type="xs:string" minOccurs="0" maxOccurs="unbounded"/>
<xs:element name="Layer" type="ms:Layer" minOccurs="0" maxOccurs="unbounded"/>
<xs:element name="Legend" type="ms:Legend" minOccurs="0"/>
<xs:element name="maxSize" type="xs:positiveInteger" minOccurs="0"/>
Modified: trunk/mapserver/xmlmapfile/mapfile.xsl
--- trunk/mapserver/xmlmapfile/mapfile.xsl 2010-08-31 01:12:33 UTC (rev 10488)
+++ trunk/mapserver/xmlmapfile/mapfile.xsl 2010-08-31 18:31:14 UTC (rev 10489)
@@ -1423,13 +1423,16 @@
<xsl:with-param name="node" select="'ms:imageType'"/>
<xsl:with-param name="quote" select="1"/>
</xsl:call-template>
+ <xsl:for-each select="ms:include">
+ <xsl:call-template name="print">
+ <xsl:with-param name="indent" select="$indent"/>
+ <xsl:with-param name="text">
+ <xsl:value-of select="concat('INCLUDE ','"',.,'"')"/>
+ </xsl:with-param>
+ </xsl:call-template>
+ </xsl:for-each>
- <xsl:with-param name="node" select="'ms:include'"/>
- <xsl:with-param name="quote" select="1"/>
- </xsl:call-template>
- <xsl:call-template name="print">
- <xsl:with-param name="indent" select="$indent"/>
<xsl:with-param name="node" select="'ms:maxSize'"/>
<xsl:apply-templates select="ms:projection">
Modified: trunk/mapserver/xmlmapfile/tests/mapfile-test.xml
--- trunk/mapserver/xmlmapfile/tests/mapfile-test.xml 2010-08-31 01:12:33 UTC (rev 10488)
+++ trunk/mapserver/xmlmapfile/tests/mapfile-test.xml 2010-08-31 18:31:14 UTC (rev 10489)
@@ -14,6 +14,7 @@
<imageColor red="0" green="255" blue="255"/>
<imageType>png</imageType>
<include>/tmp/myLayerSet.map</include>
+ <include>/tmp/AnotherLayerSet.map</include>
<Legend status="ON">
<imageColor red="255" green="255" blue="255"/>
<keySize x="20" y="10"/>
More information about the mapserver-commits
