[mapserver-commits] r10775 -
sandbox/sdlime/common-expressions/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Dec 1 23:57:11 EST 2010
Author: sdlime
Date: 2010-12-01 20:57:11 -0800 (Wed, 01 Dec 2010)
New Revision: 10775
sandbox/sdlime/common-expressions/mapserver/mapparser.c
sandbox/sdlime/common-expressions/mapserver/mapparser.h
sandbox/sdlime/common-expressions/mapserver/mapparser.y
Include mapparser.h in mapparser.y to avoid warnings with yylex() function prototype.
Modified: sandbox/sdlime/common-expressions/mapserver/mapparser.c
--- sandbox/sdlime/common-expressions/mapserver/mapparser.c 2010-12-01 18:39:49 UTC (rev 10774)
+++ sandbox/sdlime/common-expressions/mapserver/mapparser.c 2010-12-02 04:57:11 UTC (rev 10775)
@@ -139,13 +139,12 @@
#include "maptime.h" /* for time comparison routines */
#include "mapprimitive.h" /* for shapeObj */
-** Probably need to move yylex() and yyerror() to a separate file to avoid parse errors with YYSTYP and/or compiler warnings...
-// int yylex(YYSTYPE *, parseObj *); /* prototype functions, defined after the grammar */
-// int yyerror(parseObj *, const char *);
+#include "mapparser.h" /* for YYSTYPE in the function prototype for yylex() */
+int yylex(YYSTYPE *, parseObj *); /* prototype functions, defined after the grammar */
+int yyerror(parseObj *, const char *);
/* Enabling traces. */
#ifndef YYDEBUG
# define YYDEBUG 0
@@ -160,7 +159,7 @@
#endif
#if ! defined (YYSTYPE) && ! defined (YYSTYPE_IS_DECLARED)
-#line 31 "mapparser.y"
+#line 30 "mapparser.y"
typedef union YYSTYPE {
double dblval;
int intval;
@@ -169,7 +168,7 @@
shapeObj *shpval;
} YYSTYPE;
/* Line 185 of yacc.c. */
-#line 173 "mapparser.c"
+#line 172 "mapparser.c"
# define yystype YYSTYPE /* obsolescent; will be withdrawn */
# define YYSTYPE_IS_DECLARED 1
# define YYSTYPE_IS_TRIVIAL 1
@@ -181,7 +180,7 @@
/* Line 213 of yacc.c. */
-#line 185 "mapparser.c"
+#line 184 "mapparser.c"
#if ! defined (yyoverflow) || YYERROR_VERBOSE
@@ -388,14 +387,14 @@
/* YYRLINE[YYN] -- source line where rule number YYN was defined. */
static const unsigned short int yyrline[] =
- 0, 66, 66, 67, 80, 94, 107, 118, 126, 135,
- 143, 152, 160, 169, 177, 186, 187, 188, 201, 214,
- 220, 226, 232, 238, 244, 250, 251, 259, 267, 276,
- 284, 292, 300, 306, 312, 318, 324, 330, 336, 357,
- 378, 384, 392, 399, 410, 421, 432, 443, 454, 465,
- 476, 487, 497, 509, 510, 511, 512, 513, 514, 515,
- 522, 523, 524, 525, 533, 536, 537, 538, 550, 551,
- 552, 556, 560, 566, 567
+ 0, 65, 65, 66, 79, 93, 106, 117, 125, 134,
+ 142, 151, 159, 168, 176, 185, 186, 187, 200, 213,
+ 219, 225, 231, 237, 243, 249, 250, 258, 266, 275,
+ 283, 291, 299, 305, 311, 317, 323, 329, 335, 356,
+ 377, 383, 391, 398, 409, 420, 431, 442, 453, 464,
+ 475, 486, 496, 508, 509, 510, 511, 512, 513, 514,
+ 521, 522, 523, 524, 532, 535, 536, 537, 549, 550,
+ 551, 555, 559, 565, 566
#endif
@@ -1255,7 +1254,7 @@
switch (yyn)
case 3:
-#line 67 "mapparser.y"
+#line 66 "mapparser.y"
switch(p->type) {
case(MS_PARSE_TYPE_BOOLEAN):
@@ -1272,7 +1271,7 @@
break;
case 4:
-#line 80 "mapparser.y"
+#line 79 "mapparser.y"
switch(p->type) {
@@ -1290,7 +1289,7 @@
break;
case 5:
-#line 94 "mapparser.y"
+#line 93 "mapparser.y"
switch(p->type) {
@@ -1307,7 +1306,7 @@
break;
case 6:
-#line 107 "mapparser.y"
+#line 106 "mapparser.y"
switch(p->type) {
case(MS_PARSE_TYPE_SHAPE):
@@ -1319,7 +1318,7 @@
break;
case 7:
-#line 118 "mapparser.y"
+#line 117 "mapparser.y"
if((yyvsp[-2].intval) == MS_TRUE)
(yyval.intval) = MS_TRUE;
@@ -1331,7 +1330,7 @@
break;
case 8:
-#line 126 "mapparser.y"
+#line 125 "mapparser.y"
if((yyvsp[-2].intval) == MS_TRUE) {
if((yyvsp[0].intval) == MS_TRUE)
@@ -1344,7 +1343,7 @@
break;
case 9:
-#line 135 "mapparser.y"
+#line 134 "mapparser.y"
@@ -1356,7 +1355,7 @@
break;
case 10:
-#line 143 "mapparser.y"
+#line 142 "mapparser.y"
if((yyvsp[0].dblval) != 0)
@@ -1369,7 +1368,7 @@
break;
case 11:
-#line 152 "mapparser.y"
+#line 151 "mapparser.y"
if((yyvsp[-2].dblval) != 0)
@@ -1381,7 +1380,7 @@
break;
case 12:
-#line 160 "mapparser.y"
+#line 159 "mapparser.y"
if((yyvsp[-2].dblval) != 0) {
@@ -1394,7 +1393,7 @@
break;
case 13:
-#line 169 "mapparser.y"
+#line 168 "mapparser.y"
@@ -1406,7 +1405,7 @@
break;
case 14:
-#line 177 "mapparser.y"
+#line 176 "mapparser.y"
@@ -1419,17 +1418,17 @@
break;
case 15:
-#line 186 "mapparser.y"
+#line 185 "mapparser.y"
{ (yyval.intval) = !(yyvsp[0].intval); }
break;
case 16:
-#line 187 "mapparser.y"
+#line 186 "mapparser.y"
{ (yyval.intval) = !(yyvsp[0].dblval); }
break;
case 17:
-#line 188 "mapparser.y"
+#line 187 "mapparser.y"
ms_regex_t re;
@@ -1446,7 +1445,7 @@
break;
case 18:
-#line 201 "mapparser.y"
+#line 200 "mapparser.y"
ms_regex_t re;
@@ -1463,7 +1462,7 @@
break;
case 19:
-#line 214 "mapparser.y"
+#line 213 "mapparser.y"
if((yyvsp[-2].dblval) == (yyvsp[0].dblval))
@@ -1473,7 +1472,7 @@
break;
case 20:
-#line 220 "mapparser.y"
+#line 219 "mapparser.y"
if((yyvsp[-2].dblval) != (yyvsp[0].dblval))
@@ -1483,7 +1482,7 @@
break;
case 21:
-#line 226 "mapparser.y"
+#line 225 "mapparser.y"
if((yyvsp[-2].dblval) > (yyvsp[0].dblval))
@@ -1493,7 +1492,7 @@
break;
case 22:
-#line 232 "mapparser.y"
+#line 231 "mapparser.y"
if((yyvsp[-2].dblval) < (yyvsp[0].dblval))
@@ -1503,7 +1502,7 @@
break;
case 23:
-#line 238 "mapparser.y"
+#line 237 "mapparser.y"
if((yyvsp[-2].dblval) >= (yyvsp[0].dblval))
@@ -1513,7 +1512,7 @@
break;
case 24:
-#line 244 "mapparser.y"
+#line 243 "mapparser.y"
if((yyvsp[-2].dblval) <= (yyvsp[0].dblval))
@@ -1523,12 +1522,12 @@
break;
case 25:
-#line 250 "mapparser.y"
+#line 249 "mapparser.y"
{ (yyval.intval) = (yyvsp[-1].intval); }
break;
case 26:
-#line 251 "mapparser.y"
+#line 250 "mapparser.y"
if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) == 0)
@@ -1540,7 +1539,7 @@
break;
case 27:
-#line 259 "mapparser.y"
+#line 258 "mapparser.y"
if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) != 0)
@@ -1552,7 +1551,7 @@
break;
case 28:
-#line 267 "mapparser.y"
+#line 266 "mapparser.y"
if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) > 0)
@@ -1565,7 +1564,7 @@
break;
case 29:
-#line 276 "mapparser.y"
+#line 275 "mapparser.y"
if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) < 0)
@@ -1577,7 +1576,7 @@
break;
case 30:
-#line 284 "mapparser.y"
+#line 283 "mapparser.y"
if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) >= 0)
@@ -1589,7 +1588,7 @@
break;
case 31:
-#line 292 "mapparser.y"
+#line 291 "mapparser.y"
if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) <= 0)
@@ -1601,7 +1600,7 @@
break;
case 32:
-#line 300 "mapparser.y"
+#line 299 "mapparser.y"
if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) == 0)
@@ -1611,7 +1610,7 @@
break;
case 33:
-#line 306 "mapparser.y"
+#line 305 "mapparser.y"
if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) != 0)
@@ -1621,7 +1620,7 @@
break;
case 34:
-#line 312 "mapparser.y"
+#line 311 "mapparser.y"
if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) > 0)
@@ -1631,7 +1630,7 @@
break;
case 35:
-#line 318 "mapparser.y"
+#line 317 "mapparser.y"
if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) < 0)
@@ -1641,7 +1640,7 @@
break;
case 36:
-#line 324 "mapparser.y"
+#line 323 "mapparser.y"
if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) >= 0)
@@ -1651,7 +1650,7 @@
break;
case 37:
-#line 330 "mapparser.y"
+#line 329 "mapparser.y"
if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) <= 0)
@@ -1661,7 +1660,7 @@
break;
case 38:
-#line 336 "mapparser.y"
+#line 335 "mapparser.y"
char *delim,*bufferp;
@@ -1686,7 +1685,7 @@
break;
case 39:
-#line 357 "mapparser.y"
+#line 356 "mapparser.y"
@@ -1711,7 +1710,7 @@
break;
case 40:
-#line 378 "mapparser.y"
+#line 377 "mapparser.y"
@@ -1721,7 +1720,7 @@
break;
case 41:
-#line 384 "mapparser.y"
+#line 383 "mapparser.y"
if(strcasecmp((yyvsp[-2].strval), (yyvsp[0].strval)) == 0)
@@ -1733,7 +1732,7 @@
break;
case 42:
-#line 392 "mapparser.y"
+#line 391 "mapparser.y"
@@ -1743,7 +1742,7 @@
break;
case 43:
-#line 399 "mapparser.y"
+#line 398 "mapparser.y"
int rval;
rval = msGEOSEquals((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1758,7 +1757,7 @@
break;
case 44:
-#line 410 "mapparser.y"
+#line 409 "mapparser.y"
int rval;
rval = msGEOSIntersects((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1773,7 +1772,7 @@
break;
case 45:
-#line 421 "mapparser.y"
+#line 420 "mapparser.y"
int rval;
rval = msGEOSDisjoint((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1788,7 +1787,7 @@
break;
case 46:
-#line 432 "mapparser.y"
+#line 431 "mapparser.y"
int rval;
rval = msGEOSTouches((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1803,7 +1802,7 @@
break;
case 47:
-#line 443 "mapparser.y"
+#line 442 "mapparser.y"
int rval;
rval = msGEOSOverlaps((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1818,7 +1817,7 @@
break;
case 48:
-#line 454 "mapparser.y"
+#line 453 "mapparser.y"
int rval;
rval = msGEOSCrosses((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1833,7 +1832,7 @@
break;
case 49:
-#line 465 "mapparser.y"
+#line 464 "mapparser.y"
int rval;
rval = msGEOSWithin((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1848,7 +1847,7 @@
break;
case 50:
-#line 476 "mapparser.y"
+#line 475 "mapparser.y"
int rval;
@@ -1863,7 +1862,7 @@
break;
case 51:
-#line 487 "mapparser.y"
+#line 486 "mapparser.y"
double d;
d = msGEOSDistance((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1877,7 +1876,7 @@
break;
case 52:
-#line 497 "mapparser.y"
+#line 496 "mapparser.y"
double d;
@@ -1891,32 +1890,32 @@
break;
case 54:
-#line 510 "mapparser.y"
+#line 509 "mapparser.y"
{ (yyval.dblval) = (yyvsp[-1].dblval); }
break;
case 55:
-#line 511 "mapparser.y"
+#line 510 "mapparser.y"
{ (yyval.dblval) = (yyvsp[-2].dblval) + (yyvsp[0].dblval); }
break;
case 56:
-#line 512 "mapparser.y"
+#line 511 "mapparser.y"
{ (yyval.dblval) = (yyvsp[-2].dblval) - (yyvsp[0].dblval); }
break;
case 57:
-#line 513 "mapparser.y"
+#line 512 "mapparser.y"
{ (yyval.dblval) = (yyvsp[-2].dblval) * (yyvsp[0].dblval); }
break;
case 58:
-#line 514 "mapparser.y"
+#line 513 "mapparser.y"
{ (yyval.dblval) = (int)(yyvsp[-2].dblval) % (int)(yyvsp[0].dblval); }
break;
case 59:
-#line 515 "mapparser.y"
+#line 514 "mapparser.y"
if((yyvsp[0].dblval) == 0.0) {
yyerror(p, "Division by zero.");
@@ -1927,22 +1926,22 @@
break;
case 60:
-#line 522 "mapparser.y"
+#line 521 "mapparser.y"
{ (yyval.dblval) = (yyvsp[0].dblval); }
break;
case 61:
-#line 523 "mapparser.y"
+#line 522 "mapparser.y"
{ (yyval.dblval) = pow((yyvsp[-2].dblval), (yyvsp[0].dblval)); }
break;
case 62:
-#line 524 "mapparser.y"
+#line 523 "mapparser.y"
{ (yyval.dblval) = strlen((yyvsp[-1].strval)); }
break;
case 63:
-#line 525 "mapparser.y"
+#line 524 "mapparser.y"
if((yyvsp[-1].shpval)->type != MS_SHAPE_POLYGON) {
yyerror(p, "Area can only be computed for polygon shapes.");
@@ -1954,17 +1953,17 @@
break;
case 64:
-#line 533 "mapparser.y"
+#line 532 "mapparser.y"
{ (yyval.dblval) = (MS_NINT((yyvsp[-3].dblval)/(yyvsp[-1].dblval)))*(yyvsp[-1].dblval); }
break;
case 66:
-#line 537 "mapparser.y"
+#line 536 "mapparser.y"
{ (yyval.shpval) = (yyvsp[-1].shpval); }
break;
case 67:
-#line 538 "mapparser.y"
+#line 537 "mapparser.y"
shapeObj *s;
s = msGEOSBuffer((yyvsp[-3].shpval), (yyvsp[-1].dblval));
@@ -1978,12 +1977,12 @@
break;
case 69:
-#line 551 "mapparser.y"
+#line 550 "mapparser.y"
{ (yyval.strval) = (yyvsp[-1].strval); }
break;
case 70:
-#line 552 "mapparser.y"
+#line 551 "mapparser.y"
(yyval.strval) = (char *)malloc(strlen((yyvsp[-2].strval)) + strlen((yyvsp[0].strval)) + 1);
sprintf((yyval.strval), "%s%s", (yyvsp[-2].strval), (yyvsp[0].strval)); free((yyvsp[-2].strval)); free((yyvsp[0].strval));
@@ -1991,7 +1990,7 @@
break;
case 71:
-#line 556 "mapparser.y"
+#line 555 "mapparser.y"
(yyval.strval) = (char *) malloc(strlen((yyvsp[-1].strval)) + 64); /* Plenty big? Should use snprintf below... */
sprintf((yyval.strval), (yyvsp[-1].strval), (yyvsp[-3].dblval));
@@ -1999,7 +1998,7 @@
break;
case 72:
-#line 560 "mapparser.y"
+#line 559 "mapparser.y"
(yyvsp[-1].strval) = msCommifyString((yyvsp[-1].strval));
@@ -2007,7 +2006,7 @@
break;
case 74:
-#line 567 "mapparser.y"
+#line 566 "mapparser.y"
{ (yyval.tmval) = (yyvsp[-1].tmval); }
break;
@@ -2015,7 +2014,7 @@
/* Line 1037 of yacc.c. */
-#line 2019 "mapparser.c"
+#line 2018 "mapparser.c"
yyvsp -= yylen;
yyssp -= yylen;
@@ -2243,7 +2242,7 @@
-#line 570 "mapparser.y"
+#line 569 "mapparser.y"
Modified: sandbox/sdlime/common-expressions/mapserver/mapparser.h
--- sandbox/sdlime/common-expressions/mapserver/mapparser.h 2010-12-01 18:39:49 UTC (rev 10774)
+++ sandbox/sdlime/common-expressions/mapserver/mapparser.h 2010-12-02 04:57:11 UTC (rev 10775)
@@ -102,7 +102,7 @@
double dblval;
int intval;
Modified: sandbox/sdlime/common-expressions/mapserver/mapparser.y
--- sandbox/sdlime/common-expressions/mapserver/mapparser.y 2010-12-01 18:39:49 UTC (rev 10774)
+++ sandbox/sdlime/common-expressions/mapserver/mapparser.y 2010-12-02 04:57:11 UTC (rev 10775)
@@ -14,11 +14,10 @@
/* Bison/Yacc declarations */
More information about the mapserver-commits
