[mapserver-commits] r9860 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Feb 22 13:33:18 EST 2010
Author: jimk
Date: 2010-02-22 13:33:18 -0500 (Mon, 22 Feb 2010)
New Revision: 9860
trunk/mapserver/maporaclespatial.c
Added msOracleSpatialLayerGetAutoProjection. This code seems to work but needs
further testing once RFC #37 is more completely implemented. (Ticket #3333)
Modified: trunk/mapserver/maporaclespatial.c
--- trunk/mapserver/maporaclespatial.c 2010-02-22 15:06:08 UTC (rev 9859)
+++ trunk/mapserver/maporaclespatial.c 2010-02-22 18:33:18 UTC (rev 9860)
@@ -2450,6 +2450,98 @@
return MS_SUCCESS;
+/* AutoProjection Support for RFC 37 #3333
+ * TODO: Needs testing
+int msOracleSpatialLayerGetAutoProjection( layerObj *layer, projectionObj *projection )
+ char *table_name;
+ char *query_str, geom_column_name[100], unique[100], srid[100];
+ int success;
+ int function = 0;
+ int version = 0;
+ char wktext[4000];
+ OCIDefine *def1p = NULL;
+ OCIBind *bnd1p = NULL, *bnd2p = NULL;
+ msOracleSpatialLayerInfo *layerinfo = (msOracleSpatialLayerInfo *)layer->layerinfo;
+ msOracleSpatialDataHandler *dthand = NULL;
+ msOracleSpatialHandler *hand = NULL;
+ msOracleSpatialStatement *sthand = NULL;
+ if (layer->debug)
+ msDebug("msOracleSpatialLayerGetAutoProjection was called.\n");
+ if (layerinfo == NULL)
+ msSetError( MS_ORACLESPATIALERR, "msOracleSpatialLayerGetAutoProjection called on unopened layer","msOracleSpatialLayerGetAutoProjection()");
+ return MS_FAILURE;
+ else
+ dthand = (msOracleSpatialDataHandler *)layerinfo->oradatahandlers;
+ hand = (msOracleSpatialHandler *)layerinfo->orahandlers;
+ sthand = (msOracleSpatialStatement *) layerinfo->orastmt;
+ table_name = (char *) malloc(sizeof(char) * TABLE_NAME_SIZE);
+ if (!msSplitData( layer->data, geom_column_name, &table_name, unique, srid, &function, &version ))
+ "Error parsing OracleSpatial DATA variable. Must be: "
+ "'geometry_column FROM table_name [USING UNIQUE <column> SRID srid# FUNCTION]' or "
+ "'geometry_column FROM (SELECT stmt) [USING UNIQUE <column> SRID srid# FUNCTION]'. "
+ "If want to set the FUNCTION statement you can use: FILTER, RELATE, GEOMRELATE or NONE. "
+ "Your data statement: %s",
+ "msOracleSpatialLayerGetAutoProjection()", layer->data );
+ free(table_name);
+ query_str = "SELECT wktext FROM mdsys.all_sdo_geom_metadata m, mdsys.cs_srs c WHERE c.srid = m.srid and m.owner||'.'||m.table_name = :table_name and m.column_name = :geo_col_name "
+ "UNION SELECT wktext from mdsys.user_sdo_geom_metadata m, mdsys.cs_srs c WHERE c.srid = m.srid and m.table_name = :table_name and m.column_name = :geo_col_name";
+ if (layer->debug)
+ msDebug("msOracleSpatialLayerGetAutoProjection. Using this Sql to retrieve the projection: %s.\n", query_str);
+ /*Prepare the handlers to the query*/
+ success = TRY( hand, OCIStmtPrepare( sthand->stmthp, hand->errhp, (text *)query_str, (ub4)strlen(query_str), (ub4)OCI_NTV_SYNTAX, (ub4)OCI_DEFAULT ) )
+ && TRY( hand, OCIBindByName( sthand->stmthp, &bnd2p, hand->errhp, (text *) ":table_name", strlen(":table_name"), (ub1*) table_name, strlen(table_name)+1, SQLT_STR, (dvoid *) 0, (ub2 *) 0, (ub2) 0, (ub4) 0, (ub4 *) 0, OCI_DEFAULT ) )
+ && TRY( hand, OCIBindByName( sthand->stmthp, &bnd1p, hand->errhp, (text *) ":geo_col_name", strlen(":geo_col_name"), (ub1*) geom_column_name, strlen(geom_column_name)+1, SQLT_STR, (dvoid *) 0, (ub2 *) 0, (ub2) 0, (ub4) 0, (ub4 *) 0, OCI_DEFAULT ) )
+ && TRY( hand, OCIDefineByPos( sthand->stmthp, &def1p, hand->errhp, (ub4)1, (dvoid *)wktext, (sb4)4000, SQLT_STR, (dvoid *)0, (ub2 *)0, (ub2 *)0, (ub4)OCI_DEFAULT ) )
+ && TRY( hand, OCIStmtExecute( hand->svchp, sthand->stmthp, hand->errhp, (ub4)0, (ub4)0, (OCISnapshot *)NULL, (OCISnapshot *)NULL, (ub4)OCI_DEFAULT ) )
+ && TRY( hand, OCIAttrGet( (dvoid *)sthand->stmthp, (ub4)OCI_HTYPE_STMT, (dvoid *)&sthand->rows_fetched, (ub4 *)0, (ub4)OCI_ATTR_ROWS_FETCHED, hand->errhp ) );
+ if(!success)
+ "Error: %s . "
+ "Query statement: %s . "
+ "Check your data statement.",
+ "msOracleSpatialLayerGetAutoProjection()", hand->last_oci_error, query_str );
+ free(table_name);
+ do {
+ success = TRY( hand, OCIStmtFetch( sthand->stmthp, hand->errhp, (ub4)1, (ub2)OCI_FETCH_NEXT, (ub4)OCI_DEFAULT ) )
+ if (success && sthand->rows_fetched > 0) {
+ if( layer->debug )
+ msDebug("Found WKT projection for table %s: %s\n", table_name, wktext);
+ if(wktext != NULL && projection != NULL)
+ msOGCWKT2ProjectionObj(wktext, projection, layer->debug);
+ } while (sthand->rows_fetched > 0);
+ free(table_name);
+ return MS_SUCCESS;
int msOracleSpatialLayerGetItems( layerObj *layer )
char *rzt = "";
@@ -3261,6 +3353,7 @@
vtable->LayerApplyFilterToLayer = msLayerApplyCondSQLFilterToLayer;
vtable->LayerSetTimeFilter = msLayerMakePlainTimeFilter;
/* layer->vtable->LayerGetNumFeatures, use default */
+ /* layer->vtable->LayerGetAutoProjection = msOracleSpatialLayerGetAutoProjection; Disabled until tested */
return MS_SUCCESS;
@@ -3289,7 +3382,7 @@
layer->vtable->LayerSetTimeFilter = msLayerMakePlainTimeFilter;
/* layer->vtable->LayerCreateItems, use default */
- /* layer->vtable->LayerGetAutoProjection, use defaut*/
return MS_SUCCESS;
More information about the mapserver-commits
