[mapserver-commits] r9695 - in trunk/mapserver: . mapscript/php3
Fri Jan 15 12:02:29 EST 2010
Author: aboudreault
Date: 2010-01-15 12:02:28 -0500 (Fri, 15 Jan 2010)
New Revision: 9695
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/MIGRATION_GUIDE.TXT
   trunk/mapserver/mapscript/php3/README
   trunk/mapserver/mapscript/php3/php_mapscript.c
PHP/MapScript: removed deprecated class properties (#2170)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-01-15 15:41:36 UTC (rev 9694)
+++ trunk/mapserver/HISTORY.TXT	2010-01-15 17:02:28 UTC (rev 9695)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- PHP/MapScript: removed deprecated class properties (#2170)
 - Fixed OGR datasource double free (#3261)
 - Fix compilation warnings around use of strcasestr (#3257)
Modified: trunk/mapserver/MIGRATION_GUIDE.TXT
--- trunk/mapserver/MIGRATION_GUIDE.TXT	2010-01-15 15:41:36 UTC (rev 9694)
+++ trunk/mapserver/MIGRATION_GUIDE.TXT	2010-01-15 17:02:28 UTC (rev 9695)
@@ -1,4 +1,20 @@
+MapServer 5.6 to 6.0 Migration Guide
+This section documents the changes that must be made to MapServer
+applications when migrating from version 5.6.x (or earlier versions)
+to 6.0 (i.e. backwards incompatibilities), as well as information
+on some of the new features.
+PHP MapScript
+* All deprecated class properties have been removed.
+  See mapscript/php3/README for the list.
 MapServer 5.4 to 5.6 Migration Guide
Modified: trunk/mapserver/mapscript/php3/README
--- trunk/mapserver/mapscript/php3/README	2010-01-15 15:41:36 UTC (rev 9694)
+++ trunk/mapserver/mapscript/php3/README	2010-01-15 17:02:28 UTC (rev 9695)
@@ -1,2 +1,42 @@
 Please see the PHP MapScript documentation at:
 http://www.mapserver.org/mapscript/php/index.html
+In MapServer 6.0, the following class properties have been removed
+mapObj
+ imagequality
+ interlace
+ scale
+ transparent
+classObj
+ maxscale
+ minscale
+layerObj
+ labelmaxscale
+ labelminscale
+ maxscale
+ minscale
+ symbolscale
+ transparency
+legendObj
+ interlace
+ transparent
+scalebarObj
+ interlace
+ transparent
+symbolObj
+ gap
+ stylelength
\ No newline at end of file
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c	2010-01-15 15:41:36 UTC (rev 9694)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c	2010-01-15 17:02:28 UTC (rev 9695)
@@ -1589,10 +1589,7 @@
     add_property_long(return_value,  "width",     pMap->width);
     add_property_long(return_value,  "height",    pMap->height);
     add_property_long(return_value,  "maxsize",   pMap->maxsize);
-    add_property_long(return_value,  "transparent", pMap->transparent);
-    add_property_long(return_value,  "interlace", pMap->interlace);
     PHPMS_ADD_PROP_STR(return_value,  "imagetype", pMap->imagetype);
-    add_property_long(return_value,  "imagequality", pMap->imagequality);
     MAKE_STD_ZVAL(new_obj_ptr);  /* Alloc and Init a ZVAL for new object */
     _phpms_build_rect_object(&(pMap->extent), PHPMS_GLOBAL(le_msrect_ref),
@@ -1603,8 +1600,6 @@
     add_property_long(return_value,  "units",     pMap->units);
     add_property_double(return_value,"scaledenom",pMap->scaledenom);
-    /* TODO: scale deprecated in v5.0 remove in future release */
-    add_property_double(return_value,"scale",     pMap->scaledenom);
     add_property_double(return_value,"resolution",pMap->resolution);
     add_property_double(return_value,"defresolution",pMap->defresolution);
@@ -1895,14 +1890,9 @@
     else IF_SET_LONG(  "width",       self->width)
     else IF_SET_LONG(  "height",      self->height)
     else IF_SET_LONG(  "maxsize",     self->maxsize)
-    else IF_SET_LONG(  "transparent", self->transparent)
-    else IF_SET_LONG(  "interlace",   self->interlace)
-    else IF_SET_LONG(  "imagequality",self->imagequality)
     else IF_SET_DOUBLE("cellsize",    self->cellsize)
     else IF_SET_LONG(  "units",       self->units)
     else IF_SET_DOUBLE("scaledenom",  self->scaledenom)
-    else IF_SET_DOUBLE("scale",       self->scaledenom)
     else IF_SET_DOUBLE("resolution",  self->resolution)
     else IF_SET_DOUBLE("defresolution",  self->defresolution)
     else IF_SET_STRING("shapepath",   self->shapepath)
@@ -6779,12 +6769,6 @@
     add_property_double(return_value, "labelminscaledenom",player->labelminscaledenom);
     add_property_double(return_value, "labelmaxscaledenom",player->labelmaxscaledenom);
-    /* TODO: *scale deprecated in v5.0. Remove in future release */
-    add_property_double(return_value, "symbolscale",player->symbolscaledenom);
-    add_property_double(return_value, "minscale",   player->minscaledenom);
-    add_property_double(return_value, "maxscale",   player->maxscaledenom);
-    add_property_double(return_value, "labelminscale",player->labelminscaledenom);
-    add_property_double(return_value, "labelmaxscale",player->labelmaxscaledenom);
     add_property_long(return_value,   "maxfeatures",player->maxfeatures);
     add_property_long(return_value,   "transform",  player->transform);
@@ -6800,8 +6784,7 @@
     PHPMS_ADD_PROP_STR(return_value,  "filteritem", player->filteritem);
     PHPMS_ADD_PROP_STR(return_value,  "template", player->template);
     add_property_long(return_value,   "opacity", player->opacity);
-    /* TODO: transparency deprecated in v5.0. Remove in future release */
-    add_property_long(return_value,   "transparency", player->opacity);
     PHPMS_ADD_PROP_STR(return_value,  "styleitem",  player->styleitem);
     add_property_long(return_value,   "num_processing",player->numprocessing);
     PHPMS_ADD_PROP_STR(return_value,  "requires",   player->requires);
@@ -6994,13 +6977,6 @@
     else IF_SET_DOUBLE("maxscaledenom",   self->maxscaledenom)
     else IF_SET_DOUBLE("labelminscaledenom",self->labelminscaledenom)
     else IF_SET_DOUBLE("labelmaxscaledenom",self->labelmaxscaledenom)
-    else IF_SET_DOUBLE("symbolscale",self->symbolscaledenom)
-    else IF_SET_DOUBLE("minscale",   self->minscaledenom)
-    else IF_SET_DOUBLE("maxscale",   self->maxscaledenom)
-    else IF_SET_DOUBLE("labelminscale",self->labelminscaledenom)
-    else IF_SET_DOUBLE("labelmaxscale",self->labelmaxscaledenom)
     else IF_SET_LONG(  "maxfeatures",self->maxfeatures)
     else IF_SET_LONG(  "transform",  self->transform)
     else IF_SET_LONG(  "labelcache", self->labelcache)
@@ -7014,8 +6990,6 @@
     else IF_SET_STRING("filteritem", self->filteritem)
     else IF_SET_STRING("template",   self->template)
     else IF_SET_LONG(  "opacity", self->opacity)
-    else IF_SET_LONG(  "transparency",self->opacity)
     else IF_SET_STRING("styleitem",  self->styleitem)
     else IF_SET_STRING("requires",   self->requires)
     else IF_SET_STRING("labelrequires",   self->labelrequires)
@@ -9506,9 +9480,6 @@
     add_property_double(return_value,  "minscaledenom", pclass->minscaledenom);
     add_property_double(return_value,  "maxscaledenom", pclass->maxscaledenom);
-    add_property_double(return_value,  "minscale", pclass->minscaledenom);
-    add_property_double(return_value,  "maxscale", pclass->maxscaledenom);
     PHPMS_ADD_PROP_STR(return_value,   "keyimage",  pclass->keyimage);
@@ -9680,10 +9651,6 @@
     else IF_SET_LONG(  "status",        self->status)
     else IF_SET_DOUBLE("minscaledenom", self->minscaledenom)
     else IF_SET_STRING("keyimage",      self->keyimage)
     else if (strcmp( "numstyles", pPropertyName->value.str.val) == 0)
@@ -14392,12 +14359,9 @@
     add_property_long(return_value,  "width",           pscalebar->width);
     add_property_long(return_value,  "style",           pscalebar->style);
     add_property_long(return_value,  "intervals",       pscalebar->intervals);
     add_property_long(return_value,  "units",           pscalebar->units);
     add_property_long(return_value,  "status",          pscalebar->status);
     add_property_long(return_value,  "position",        pscalebar->position);
-    add_property_long(return_value,  "transparent",     pscalebar->transparent);
-    add_property_long(return_value,  "interlace",       pscalebar->interlace);
     add_property_long(return_value,  "postlabelcache",
                       pscalebar->postlabelcache);
     add_property_long(return_value,  "align",           pscalebar->align);
@@ -14512,8 +14476,6 @@
     else IF_SET_LONG(  "position",      self->position)
     else IF_SET_LONG(  "postlabelcache",self->postlabelcache)
     else IF_SET_LONG(  "align",         self->align)
     else
@@ -14613,8 +14575,6 @@
     add_property_long(return_value,  "keyspacingy",     plegend->keyspacingy);
     add_property_long(return_value,  "status",          plegend->status);
     add_property_long(return_value,  "position",        plegend->position);
-    add_property_long(return_value,  "transparent",     plegend->transparent);
-    add_property_long(return_value,  "interlace",       plegend->interlace);
                       plegend->postlabelcache);
     PHPMS_ADD_PROP_STR(return_value, "template", plegend->template);
@@ -14733,8 +14693,6 @@
     else IF_SET_LONG(  "keyspacingy",   self->keyspacingy)
     else IF_SET_STRING( "template",     self->template)
     else
@@ -15733,9 +15691,6 @@
     add_property_long(return_value,   "filled",     psSymbol->filled);
     add_property_long(return_value,   "patternlength", psSymbol->patternlength);
-    /* TODO: stylelength deprecated in v5.0. To be removed in a later release*/
-    add_property_long(return_value,   "stylelength", psSymbol->patternlength);
     /* MS_SYMBOL_PIXMAP */
     PHPMS_ADD_PROP_STR(return_value,  "imagepath", psSymbol->imagepath);
     add_property_long(return_value,   "transparent",     psSymbol->transparent);
@@ -15745,7 +15700,6 @@
     PHPMS_ADD_PROP_STR(return_value,  "character",  psSymbol->character);
     add_property_long(return_value,   "antialias",  psSymbol->antialias);
     PHPMS_ADD_PROP_STR(return_value,  "font",       psSymbol->font);
-    add_property_long(return_value,   "gap",        psSymbol->gap);
     add_property_long(return_value,   "position",   psSymbol->position);
     //TODO : true type and cartoline parameters to add.
@@ -15794,11 +15748,9 @@
     else IF_SET_STRING("character",   self->character)
     else IF_SET_LONG(  "antialias",   self->antialias)
     else IF_SET_STRING("font",        self->font)
-    else IF_SET_LONG(  "gap",         self->gap)
     else if (strcmp( "numpoints", pPropertyName->value.str.val) == 0 ||
              strcmp( "patternlength", pPropertyName->value.str.val) == 0 ||
-             strcmp( "stylelength", pPropertyName->value.str.val) == 0 ||
              strcmp( "imagepath", pPropertyName->value.str.val) == 0)
         php3_error(E_ERROR,"Property '%s' is read-only and cannot be set.",
