[mapserver-commits] r9733 - trunk/mapserver/mapscript/php3
svn at osgeo.org
svn at osgeo.org
Fri Jan 22 11:43:53 EST 2010
Author: aboudreault
Date: 2010-01-22 11:43:52 -0500 (Fri, 22 Jan 2010)
New Revision: 9733
trunk/mapserver/mapscript/php3/php_mapscript.c
php/mapscript: Removed use of the depracated scale property
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c 2010-01-22 15:27:37 UTC (rev 9732)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c 2010-01-22 16:43:52 UTC (rev 9733)
@@ -1963,8 +1963,6 @@
_phpms_set_property_double(pThis,"cellsize", self->cellsize, E_ERROR TSRMLS_CC);
_phpms_set_property_double(pThis,"scaledenom", self->scaledenom, E_ERROR TSRMLS_CC);
- /* TODO: scale deprecated in v5.0 remove in future release */
- _phpms_set_property_double(pThis,"scale", self->scaledenom, E_ERROR TSRMLS_CC);
if (zend_hash_find(Z_OBJPROP_P(pThis), "extent", sizeof("extent"),
(void *)&pExtent) == SUCCESS)
@@ -2068,7 +2066,6 @@
_phpms_set_property_double(pThis, "cellsize", self->cellsize, E_ERROR TSRMLS_CC);
_phpms_set_property_double(pThis, "scaledenom",self->scaledenom,E_ERROR TSRMLS_CC);
_phpms_set_property_double(pThis, "scale", self->scaledenom,E_ERROR TSRMLS_CC);
_phpms_set_property_double(pThis, "width", self->width, E_ERROR TSRMLS_CC);
_phpms_set_property_double(pThis, "height", self->height, E_ERROR TSRMLS_CC);
@@ -2160,8 +2157,6 @@
_phpms_set_property_long(pThis,"units", self->units, E_ERROR TSRMLS_CC);
@@ -2608,8 +2603,6 @@
@@ -2879,8 +2872,6 @@
@@ -3198,8 +3189,6 @@
@@ -3343,7 +3332,7 @@
/* {{{ proto int map.prepareQuery()
- Calculate the scale of the map and assign it to the map->scale */
+ Calculate the scale of the map and assign it to the map->scaledenom */
DLEXPORT void php3_ms_map_prepareQuery(INTERNAL_FUNCTION_PARAMETERS)
@@ -3367,8 +3356,6 @@
E_ERROR TSRMLS_CC);
@@ -3411,8 +3398,6 @@
E_ERROR TSRMLS_CC);
sizeof("extent"), (void *)&pExtent) == SUCCESS)
@@ -3474,8 +3459,6 @@
E_ERROR TSRMLS_CC);
@@ -5401,8 +5384,6 @@
_phpms_set_property_long(pThis, "units", self->units, E_ERROR TSRMLS_CC);
_phpms_set_property_double(pThis,"scaledenom",self->scaledenom, E_ERROR TSRMLS_CC);
_phpms_set_property_double(pThis, "resolution",self->resolution, E_ERROR TSRMLS_CC);
_phpms_set_property_double(pThis, "defresolution",self->defresolution, E_ERROR TSRMLS_CC);
if(self->shapepath)
More information about the mapserver-commits
