[mapserver-commits] r9744 - in trunk/mapserver: . mapscript/php3
Mon Jan 25 11:51:11 EST 2010
Author: aboudreault
Date: 2010-01-25 11:51:10 -0500 (Mon, 25 Jan 2010)
New Revision: 9744
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapscript/php3/mapscript_i.c
   trunk/mapserver/mapscript/php3/php_mapscript.c
   trunk/mapserver/mapscript/php3/php_mapscript.h
PHP/Mapscript: added labelCacheMember object and mapObj::getLabel() method (#1794)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-01-25 16:46:03 UTC (rev 9743)
+++ trunk/mapserver/HISTORY.TXT	2010-01-25 16:51:10 UTC (rev 9744)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- PHP/Mapscript: added labelCacheMember object and mapObj::getLabel() method (#1794)
 - Add shplabel tag support in templates (#3241)
 - Bumped GEOS requirement to version 3.0+ (#3215)
Modified: trunk/mapserver/mapscript/php3/mapscript_i.c
--- trunk/mapserver/mapscript/php3/mapscript_i.c	2010-01-25 16:46:03 UTC (rev 9743)
+++ trunk/mapserver/mapscript/php3/mapscript_i.c	2010-01-25 16:51:10 UTC (rev 9744)
@@ -154,6 +154,11 @@
     return msDrawLabelCache(img, self);
+labelCacheMemberObj* mapObj_getLabel(mapObj* self, int i)
+    return msGetLabelCacheMember(&(self->labelcache), i);
 int mapObj_queryByPoint(mapObj* self, pointObj *point, int mode, double buffer) {
     msInitQuery(&(self->query));
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c	2010-01-25 16:46:03 UTC (rev 9743)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c	2010-01-25 16:51:10 UTC (rev 9744)
@@ -120,7 +120,7 @@
 DLEXPORT void php3_ms_map_getAllGroupNames(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_map_prepareImage(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_map_prepareQuery(INTERNAL_FUNCTION_PARAMETERS);
-DLEXPORT void php3_ms_map_nextLabel(INTERNAL_FUNCTION_PARAMETERS);
+DLEXPORT void php3_ms_map_getLabel(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_map_getColorByIndex(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_map_queryByPoint(INTERNAL_FUNCTION_PARAMETERS);
@@ -454,6 +454,10 @@
                                            HashTable *list,
                                            pval *return_value TSRMLS_DC);
+static long _phpms_build_labelcachemember_object(labelCacheMemberObj *plabelcachemember,
+                                           HashTable *list,
+                                           pval *return_value TSRMLS_DC);
 static long _phpms_build_symbol_object(symbolObj *psSymbol,
                                        int parent_map_id,
                                        HashTable *list,
@@ -519,6 +523,7 @@
 static int le_msgrid;
 static int le_mserror_ref;
 static int le_mslabelcache;
+static int le_mslabelcachemember;
 static int le_mssymbol;
 static int le_msquerymap;
 static int le_mscgirequest;
@@ -587,6 +592,7 @@
 static zend_class_entry *grid_class_entry_ptr;
 static zend_class_entry *error_class_entry_ptr;
 static zend_class_entry *labelcache_class_entry_ptr;
+static zend_class_entry *labelcachemember_class_entry_ptr;
 static zend_class_entry *symbol_class_entry_ptr;
 static zend_class_entry *querymap_class_entry_ptr;
 static zend_class_entry *cgirequest_class_entry_ptr;
@@ -698,6 +704,7 @@
     {"getalllayernames",php3_ms_map_getAllLayerNames,   NULL},
     {"getallgroupnames",php3_ms_map_getAllGroupNames,   NULL},
     {"getcolorbyindex", php3_ms_map_getColorByIndex,    NULL},
+    {"getLabel",        php3_ms_map_getLabel,           NULL},
     {"setextent",       php3_ms_map_setExtent,          NULL},
     {"setrotation",     php3_ms_map_setRotation,        NULL},
     {"setsize",         php3_ms_map_setSize,            NULL},
@@ -989,6 +996,10 @@
     {NULL, NULL, NULL}
+static zend_function_entry php_labelcachemember_class_functions[] = {
+    {NULL, NULL, NULL}
 function_entry php_symbol_class_functions[] = {
     {"set",             php3_ms_symbol_setProperty,     NULL},
     {"setpoints",       php3_ms_symbol_setPoints,       NULL},
@@ -1134,6 +1145,9 @@
     PHPMS_GLOBAL(le_mslabelcache)= register_list_destructors(php3_ms_free_stub,
                                                              NULL);
+    PHPMS_GLOBAL(le_mslabelcachemember)= register_list_destructors(php3_ms_free_stub,
+                                                             NULL);
     PHPMS_GLOBAL(le_msquerymap)= register_list_destructors(php3_ms_free_stub,
                                                            NULL);
@@ -1427,6 +1441,10 @@
                       php_labelcache_class_functions);
      labelcache_class_entry_ptr = zend_register_internal_class(&tmp_class_entry TSRMLS_CC);
+     INIT_CLASS_ENTRY(tmp_class_entry, "ms_labelcachemember_obj",
+                      php_labelcachemember_class_functions);
+     labelcachemember_class_entry_ptr = zend_register_internal_class(&tmp_class_entry TSRMLS_CC);
      INIT_CLASS_ENTRY(tmp_class_entry, "ms_symbol_obj",
                       php_symbol_class_functions);
      symbol_class_entry_ptr = zend_register_internal_class(&tmp_class_entry TSRMLS_CC);
@@ -3415,7 +3433,7 @@
                                         self->extent.maxy,
                                         E_ERROR TSRMLS_CC);
          _phpms_build_img_object(im, &(self->web), list, return_value TSRMLS_CC);
@@ -3937,6 +3955,46 @@
+ *                        map->getLabel()
+ * Return the next label from the map’s labelcache, allowing iteration
+ * over labels. Return NULL when the labelcache is empty.
+/* {{{ proto int map.getLabel(). */
+    pval   *pThis;
+    mapObj *self=NULL;
+    labelCacheMemberObj* pLabelCacheMember = NULL;
+    HashTable   *list=NULL;
+    int i;
+    pThis = getThis();
+    if (pThis == NULL ||
+        (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "l", &i) == FAILURE))
+        WRONG_PARAM_COUNT;
+    self = (mapObj *)_phpms_fetch_handle(pThis, PHPMS_GLOBAL(le_msmap),
+                                         list TSRMLS_CC);
+    if (self)
+        pLabelCacheMember=mapObj_getLabel(self, i);
+    if (pLabelCacheMember==NULL)
+        RETURN_NULL();
+       /* Return labelCacheMember object */
+    _phpms_build_labelcachemember_object(pLabelCacheMember, list, return_value TSRMLS_CC);
 /*                         map->getColorByIndex                         */
@@ -14839,7 +14897,40 @@
      RETURN_TRUE;
+ *                 PHP function wrappers - labelcachemember class
+ *                     _phpms_build_labelcachemember_object()
+                                           HashTable *list,
+    int         labelcachemember_id;
+    if (plabelcachemember == NULL)
+        return 0;
+    labelcachemember_id =
+      php3_list_insert(plabelcachemember, PHPMS_GLOBAL(le_mslabelcachemember));
+    _phpms_object_init(return_value, labelcachemember_id,
+                       php_labelcachemember_class_functions,
+                       PHP4_CLASS_ENTRY(labelcachemember_class_entry_ptr) TSRMLS_CC);
+    add_property_long(return_value,   "classindex",   plabelcachemember->classindex);
+    add_property_long(return_value,   "featuresize",  plabelcachemember->featuresize);
+    add_property_long(return_value,   "layerindex",   plabelcachemember->layerindex);
+    add_property_long(return_value,   "numstyles",    plabelcachemember->numstyles);
+    add_property_long(return_value,   "shapeindex",   plabelcachemember->shapeindex);
+    add_property_long(return_value,   "status",       plabelcachemember->status);
+    PHPMS_ADD_PROP_STR(return_value,  "text",         plabelcachemember->text);
+    add_property_long(return_value,   "tileindex",    plabelcachemember->tileindex);
+    return labelcachemember_id;
  *                 PHP function wrappers - symbol object
Modified: trunk/mapserver/mapscript/php3/php_mapscript.h
--- trunk/mapserver/mapscript/php3/php_mapscript.h	2010-01-25 16:46:03 UTC (rev 9743)
+++ trunk/mapserver/mapscript/php3/php_mapscript.h	2010-01-25 16:51:10 UTC (rev 9744)
@@ -78,7 +78,7 @@
 int             mapObj_embedScalebar(mapObj* self, imageObj *img);
 int             mapObj_embedLegend(mapObj* self, imageObj *img);
 int             mapObj_drawLabelCache(mapObj* self, imageObj *img);
-labelCacheMemberObj *mapObj_nextLabel(mapObj* self);
+labelCacheMemberObj *mapObj_getLabel(mapObj* self, int i);
                                     int mode, double buffer);
 int             mapObj_queryByRect(mapObj* self, rectObj rect);
