[mapserver-commits] r10373 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sat Jul 17 10:38:41 EDT 2010
Author: warmerdam
Date: 2010-07-17 14:38:41 +0000 (Sat, 17 Jul 2010)
New Revision: 10373
trunk/mapserver/mapogcfilter.c
trunk/mapserver/mapogcsld.c
ensure that errors in sld filter evaluation, like failed proj lookup, are propogated (#3495)
Modified: trunk/mapserver/mapogcfilter.c
--- trunk/mapserver/mapogcfilter.c 2010-07-17 14:04:22 UTC (rev 10372)
+++ trunk/mapserver/mapogcfilter.c 2010-07-17 14:38:41 UTC (rev 10373)
@@ -403,10 +403,15 @@
&& psQueryShape->line[0].numpoints > 0)
/*reproject shape if epsg was set*/
- if (psNode->pszSRS && map->projection.numargs > 0 &&
- FTLParseEpsgString(psNode->pszSRS, &sProjTmp))
- msProjectShape(&sProjTmp, &map->projection, psQueryShape);
+ if (psNode->pszSRS && map->projection.numargs > 0 )
+ if( !FTLParseEpsgString(psNode->pszSRS, &sProjTmp) )
+ return MS_FAILURE;
+ status = msProjectShape(&sProjTmp, &map->projection, psQueryShape);
+ if( status != MS_SUCCESS )
+ return status;
if (bUseGeos)
Modified: trunk/mapserver/mapogcsld.c
--- trunk/mapserver/mapogcsld.c 2010-07-17 14:04:22 UTC (rev 10372)
+++ trunk/mapserver/mapogcsld.c 2010-07-17 14:38:41 UTC (rev 10373)
@@ -148,6 +148,7 @@
const char *pszTmp = NULL;
int bFreeTemplate = 0;
int nLayerStatus = 0;
+ int nStatus = MS_SUCCESS;
/*const char *pszSLDNotSupported = NULL;*/
char *tmpfilename = NULL;
const char *pszFullName = NULL;
@@ -359,12 +360,11 @@
nLayerStatus = GET_LAYER(map, i)->status;
GET_LAYER(map, i)->status = MS_ON;
+ nStatus =
+ FLTApplyFilterToLayer(psNode, map,
+ GET_LAYER(map, i)->index,
+ !FLTIsSimpleFilter(psNode));
- FLTApplyFilterToLayer(psNode, map,
- GET_LAYER(map, i)->index,
- !FLTIsSimpleFilter(psNode));
GET_LAYER(map, i)->status = nLayerStatus;
FLTFreeFilterEncodingNode(psNode);
@@ -373,6 +373,9 @@
free(GET_LAYER(map, i)->template);
GET_LAYER(map, i)->template = NULL;
+ if( nStatus != MS_SUCCESS )
+ return nStatus;
else
More information about the mapserver-commits
