[mapserver-commits] r10417 - trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Thu Jul 29 15:45:43 EDT 2010
Author: jmckenna
Date: 2010-07-29 19:45:43 +0000 (Thu, 29 Jul 2010)
New Revision: 10417
trunk/docs/en/mapfile/layer.txt
add PLUGIN parameter (ticket:3135)
Modified: trunk/docs/en/mapfile/layer.txt
--- trunk/docs/en/mapfile/layer.txt 2010-07-29 19:43:27 UTC (rev 10416)
+++ trunk/docs/en/mapfile/layer.txt 2010-07-29 19:45:43 UTC (rev 10417)
@@ -42,7 +42,7 @@
See :ref:`vector` for specific connection information for various
data sources.
-CONNECTIONTYPE [local|sde|ogr|postgis|oraclespatial|wms]
+CONNECTIONTYPE [local|sde|ogr|postgis|oraclespatial|wms|plugin]
Type of connection. Default is local. See additional documentation for
any other type.
@@ -374,7 +374,19 @@
This is only needed in the case of RGB output formats, and should be used
only when necessary as it is expensive to render transparent pixmap
symbols onto an RGB map image.
+PLUGIN [filename]
+ Additional library to load by MapServer, for this layer. This is commonly
+ used to load specific support for SDE and Microsoft SQL Server layers,
+ such as:
+ .. code-block:: mapfile
+ CONNECTIONTYPE PLUGIN
+ CONNECTION "hostname,port:xxx,database,username,password"
+ PLUGIN "C:/ms4w/Apache/specialplugins/msplugin_sde_92.dll"
+ DATA "layername,geometrycolumn,SDE.DEFAULT"
POSTLABELCACHE [true|false]
Tells MapServer to render this layer after all labels in the cache have
been drawn. Useful for adding neatlines and similar elements.
More information about the mapserver-commits
