[mapserver-commits] r10427 - trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Fri Jul 30 13:43:04 EDT 2010
Author: jmckenna
Date: 2010-07-30 17:43:04 +0000 (Fri, 30 Jul 2010)
New Revision: 10427
trunk/docs/en/mapfile/outputformat.txt
add note on RGBA_PNG/transparency from tbonfort
Modified: trunk/docs/en/mapfile/outputformat.txt
--- trunk/docs/en/mapfile/outputformat.txt 2010-07-30 17:41:43 UTC (rev 10426)
+++ trunk/docs/en/mapfile/outputformat.txt 2010-07-30 17:43:04 UTC (rev 10427)
@@ -172,3 +172,9 @@
and want to use transparency with a palette, it is important to have these
two colors in the palette file: 0,0,0,0 and 255,255,255,255.
+ .. NOTE::
+ 0,0,0,0 is important if you have fully transparent areas.
+ 255,255,255,255 is opaque white.
+ The important colors to have in your palette really depend on your
+ actual map, although 0,0,0,0 , 0,0,0,255 , and 255,255,255,255 are
+ very likely to show up most of the time.
More information about the mapserver-commits
