[mapserver-commits] r10209 - in trunk/mapserver: . mapscript/php
svn at osgeo.org
svn at osgeo.org
Mon Jun 7 13:43:48 EDT 2010
Author: aboudreault
Date: 2010-06-07 13:43:46 -0400 (Mon, 07 Jun 2010)
New Revision: 10209
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapscript/php/layer.c
trunk/mapserver/mapscript/php/map.c
trunk/mapserver/maptemplate.c
Fixed MapScript processTemplate and processQueryTemplate seg fault (#3468)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2010-06-07 14:32:43 UTC (rev 10208)
+++ trunk/mapserver/HISTORY.TXT 2010-06-07 17:43:46 UTC (rev 10209)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- Fixed MapScript processTemplate and processQueryTemplate seg fault (#3468)
- Fixed shapeObj->toWkt() returns single point for multipoint geometry (#2762)
- Fixed Internal server error when Oracle returns ora-28002 code (#3457)
Modified: trunk/mapserver/mapscript/php/layer.c
--- trunk/mapserver/mapscript/php/layer.c 2010-06-07 14:32:43 UTC (rev 10208)
+++ trunk/mapserver/mapscript/php/layer.c 2010-06-07 17:43:46 UTC (rev 10209)
@@ -1554,7 +1554,7 @@
else
mapscript_report_mapserver_error(E_WARNING TSRMLS_CC);
- RETURN_STRING("", 0);
+ RETURN_STRING("", 1);
Modified: trunk/mapserver/mapscript/php/map.c
--- trunk/mapserver/mapscript/php/map.c 2010-06-07 14:32:43 UTC (rev 10208)
+++ trunk/mapserver/mapscript/php/map.c 2010-06-07 17:43:46 UTC (rev 10209)
@@ -2602,7 +2602,7 @@
// Failed for some reason
mapscript_report_php_error(E_WARNING, "processTemplate: failed reading array" TSRMLS_CC);
efree(papszNameValue);
@@ -2620,7 +2620,7 @@
else
@@ -2682,7 +2682,7 @@
mapscript_report_php_error(E_WARNING, "processQueryTemplate: failed reading array" TSRMLS_CC);
@@ -2701,7 +2701,7 @@
else
@@ -2762,7 +2762,7 @@
mapscript_report_php_error(E_WARNING, "processLegendTemplate: failed reading array" TSRMLS_CC);
@@ -2781,7 +2781,7 @@
else
@@ -3062,7 +3062,7 @@
else
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c 2010-06-07 14:32:43 UTC (rev 10208)
+++ trunk/mapserver/maptemplate.c 2010-06-07 17:43:46 UTC (rev 10209)
@@ -3863,6 +3863,11 @@
ms_regex_t re; /* compiled regular expression to be matched */
char szPath[MS_MAXPATHLEN];
+ if(!html) {
+ msSetError(MS_WEBERR, "No template specified", "msReturnPage()");
+ return MS_FAILURE;
if(ms_regcomp(&re, MS_TEMPLATE_EXPR, MS_REG_EXTENDED|MS_REG_NOSUB) != 0) {
msSetError(MS_REGEXERR, NULL, "msReturnPage()");
return MS_FAILURE;
@@ -4405,8 +4410,8 @@
** TODO : use web minscaledenom/maxscaledenom depending on the scale.
if(msReturnPage(mapserv, mapserv->map->web.template, BROWSE, &pszBuffer) != MS_SUCCESS) {
- msFree(pszBuffer);
- pszBuffer = NULL;
+ msFree(pszBuffer);
+ pszBuffer = NULL;
/* Don't free the map and names and values arrays since they were passed by reference. */
More information about the mapserver-commits
