[mapserver-commits] r10227 -
sandbox/sdlime/common-expressions/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Jun 14 00:23:54 EDT 2010
Author: sdlime
Date: 2010-06-14 04:23:53 +0000 (Mon, 14 Jun 2010)
New Revision: 10227
sandbox/sdlime/common-expressions/mapserver/Makefile.in
sandbox/sdlime/common-expressions/mapserver/maplayer.c
sandbox/sdlime/common-expressions/mapserver/maplexer.c
sandbox/sdlime/common-expressions/mapserver/maplexer.l
sandbox/sdlime/common-expressions/mapserver/mapparser.c
sandbox/sdlime/common-expressions/mapserver/mapparser.h
sandbox/sdlime/common-expressions/mapserver/mapparser.y
sandbox/sdlime/common-expressions/mapserver/mapserver.h
sandbox/sdlime/common-expressions/mapserver/maputil.c
More change...
Modified: sandbox/sdlime/common-expressions/mapserver/Makefile.in
--- sandbox/sdlime/common-expressions/mapserver/Makefile.in 2010-06-12 18:11:09 UTC (rev 10226)
+++ sandbox/sdlime/common-expressions/mapserver/Makefile.in 2010-06-14 04:23:53 UTC (rev 10227)
@@ -325,7 +325,8 @@
mapparser.o: mapparser.c mapserver.h
mapparser.c: mapparser.y
- $(YACC) -p mseyy -d -omapparser.c mapparser.y
+ # $(YACC) -p mseyy -d -omapparser.c mapparser.y
+ $(YACC) -d -omapparser.c mapparser.y
lib: $(LIBMAP_STATIC)
libmapserver: $(LIBMAP_STATIC)
Modified: sandbox/sdlime/common-expressions/mapserver/maplayer.c
--- sandbox/sdlime/common-expressions/mapserver/maplayer.c 2010-06-12 18:11:09 UTC (rev 10226)
+++ sandbox/sdlime/common-expressions/mapserver/maplayer.c 2010-06-14 04:23:53 UTC (rev 10227)
@@ -352,7 +352,7 @@
switch(token) {
case MS_NUMBER:
- expression->tokens[n].token = token;
+ expression->tokens[n].token = NUMBER;
expression->tokens[n].tokenval.dblval = msyynumber;
break;
case STRING:
@@ -362,7 +362,7 @@
expression->tokens[n].tokenval.strval = strdup(msyytext);
break;
- case MS_TIME:
+ case TIME:
msTimeInit(&(expression->tokens[n].tokenval.tmval));
if(msParseTime(msyytext, &(expression->tokens[n].tokenval.tmval)) != MS_TRUE) {
@@ -373,6 +373,7 @@
case SHAPE:
expression->tokens[n].tokenval.shpval = msShapeFromWKT(msyytext);
+ // set scope
if(!expression->tokens[n].tokenval.shpval) {
msSetError(MS_PARSEERR, "Parsing time value failed.", "tokenizeExression()");
goto parse_error;
Modified: sandbox/sdlime/common-expressions/mapserver/maplexer.c
--- sandbox/sdlime/common-expressions/mapserver/maplexer.c 2010-06-12 18:11:09 UTC (rev 10226)
+++ sandbox/sdlime/common-expressions/mapserver/maplexer.c 2010-06-14 04:23:53 UTC (rev 10227)
@@ -3336,7 +3336,7 @@
msyytext++;
msyytext[strlen(msyytext)-1] = '\0';
- return(MS_TIME);
+ return(TIME);
YY_BREAK
case 285:
Modified: sandbox/sdlime/common-expressions/mapserver/maplexer.l
--- sandbox/sdlime/common-expressions/mapserver/maplexer.l 2010-06-12 18:11:09 UTC (rev 10226)
+++ sandbox/sdlime/common-expressions/mapserver/maplexer.l 2010-06-14 04:23:53 UTC (rev 10227)
@@ -456,7 +456,7 @@
<EXPRESSION_STRING>\`[^\`]*\` {
msyytext++;
- return(MS_TIME);
+ return(TIME);
<INITIAL,URL_STRING>\/[^\/]*\/i {
Modified: sandbox/sdlime/common-expressions/mapserver/mapparser.c
--- sandbox/sdlime/common-expressions/mapserver/mapparser.c 2010-06-12 18:11:09 UTC (rev 10226)
+++ sandbox/sdlime/common-expressions/mapserver/mapparser.c 2010-06-14 04:23:53 UTC (rev 10227)
@@ -45,14 +45,6 @@
/* Using locations. */
#define YYLSP_NEEDED 0
-/* Substitute the variable and function names. */
-#define yyparse mseyyparse
-#define yylex mseyylex
-#define yyerror mseyyerror
-#define yylval mseyylval
-#define yychar mseyychar
-#define yydebug mseyydebug
-#define yynerrs mseyynerrs
/* Tokens. */
@@ -129,12 +121,21 @@
#include "maptime.h" /* for time comparison routines */
#include "mapprimitive.h" /* for shapeObj */
-extern int msyylex(void); /* lexer globals */
-extern int msyyerror(const char *);
+// extern int msyylex(void); /* lexer globals */
+// extern int msyyerror(const char *);
-int msyyresult;
+shapeObj *yyshape;
+layerObj *yylayer;
+expressionObj *yyexpr;
+typedef union {
+ int intval;
+ char *strval;
+ shapeObj *shpval;
+} parseResultObj;
+parseResultObj yyresult;
/* Enabling traces. */
#ifndef YYDEBUG
# define YYDEBUG 0
@@ -149,7 +150,7 @@
#endif
#if ! defined (YYSTYPE) && ! defined (YYSTYPE_IS_DECLARED)
-#line 25 "mapparser.y"
+#line 34 "mapparser.y"
typedef union YYSTYPE {
double dblval;
int intval;
@@ -158,7 +159,7 @@
shapeObj *shpval;
} YYSTYPE;
/* Line 185 of yacc.c. */
-#line 162 "mapparser.c"
+#line 163 "mapparser.c"
# define yystype YYSTYPE /* obsolescent; will be withdrawn */
# define YYSTYPE_IS_DECLARED 1
# define YYSTYPE_IS_TRIVIAL 1
@@ -170,7 +171,7 @@
/* Line 213 of yacc.c. */
-#line 174 "mapparser.c"
+#line 175 "mapparser.c"
#if ! defined (yyoverflow) || YYERROR_VERBOSE
@@ -369,13 +370,13 @@
/* YYRLINE[YYN] -- source line where rule number YYN was defined. */
static const unsigned short int yyrline[] =
- 0, 63, 63, 64, 65, 73, 76, 84, 93, 101,
- 110, 118, 127, 135, 144, 145, 146, 159, 165, 171,
- 177, 183, 189, 195, 196, 204, 212, 221, 229, 237,
- 245, 251, 257, 263, 269, 275, 281, 302, 323, 329,
- 337, 343, 356, 357, 358, 359, 360, 361, 362, 369,
- 370, 371, 372, 382, 383, 384, 396, 397, 398, 401,
- 402
+ 0, 72, 72, 73, 74, 82, 85, 93, 102, 110,
+ 119, 127, 136, 144, 153, 154, 155, 168, 174, 180,
+ 186, 192, 198, 204, 205, 213, 221, 230, 238, 246,
+ 254, 260, 266, 272, 278, 284, 290, 311, 332, 338,
+ 346, 352, 365, 366, 367, 368, 369, 370, 371, 378,
+ 379, 380, 381, 391, 392, 393, 405, 406, 407, 410,
+ 411
#endif
@@ -1201,22 +1202,22 @@
switch (yyn)
case 3:
-#line 64 "mapparser.y"
- { msyyresult = (yyvsp[0].intval); }
+#line 73 "mapparser.y"
+ { yyresult.intval = (yyvsp[0].intval); }
break;
case 4:
-#line 65 "mapparser.y"
+#line 74 "mapparser.y"
if((yyvsp[0].dblval) != 0)
- msyyresult = MS_TRUE;
+ yyresult.intval = MS_TRUE;
else
- msyyresult = MS_FALSE;
+ yyresult.intval = MS_FALSE;
break;
case 6:
-#line 76 "mapparser.y"
+#line 85 "mapparser.y"
if((yyvsp[-2].intval) == MS_TRUE)
(yyval.intval) = MS_TRUE;
@@ -1228,7 +1229,7 @@
break;
case 7:
-#line 84 "mapparser.y"
+#line 93 "mapparser.y"
if((yyvsp[-2].intval) == MS_TRUE) {
if((yyvsp[0].intval) == MS_TRUE)
@@ -1241,7 +1242,7 @@
break;
case 8:
-#line 93 "mapparser.y"
+#line 102 "mapparser.y"
@@ -1253,7 +1254,7 @@
break;
case 9:
-#line 101 "mapparser.y"
+#line 110 "mapparser.y"
@@ -1266,7 +1267,7 @@
break;
case 10:
-#line 110 "mapparser.y"
+#line 119 "mapparser.y"
if((yyvsp[-2].dblval) != 0)
@@ -1278,7 +1279,7 @@
break;
case 11:
-#line 118 "mapparser.y"
+#line 127 "mapparser.y"
if((yyvsp[-2].dblval) != 0) {
@@ -1291,7 +1292,7 @@
break;
case 12:
-#line 127 "mapparser.y"
+#line 136 "mapparser.y"
@@ -1303,7 +1304,7 @@
break;
case 13:
-#line 135 "mapparser.y"
+#line 144 "mapparser.y"
@@ -1316,17 +1317,17 @@
break;
case 14:
-#line 144 "mapparser.y"
+#line 153 "mapparser.y"
{ (yyval.intval) = !(yyvsp[0].intval); }
break;
case 15:
-#line 145 "mapparser.y"
+#line 154 "mapparser.y"
{ (yyval.intval) = !(yyvsp[0].dblval); }
break;
case 16:
-#line 146 "mapparser.y"
+#line 155 "mapparser.y"
ms_regex_t re;
@@ -1343,7 +1344,7 @@
break;
case 17:
-#line 159 "mapparser.y"
+#line 168 "mapparser.y"
if((yyvsp[-2].dblval) == (yyvsp[0].dblval))
@@ -1353,7 +1354,7 @@
break;
case 18:
-#line 165 "mapparser.y"
+#line 174 "mapparser.y"
if((yyvsp[-2].dblval) != (yyvsp[0].dblval))
@@ -1363,7 +1364,7 @@
break;
case 19:
-#line 171 "mapparser.y"
+#line 180 "mapparser.y"
if((yyvsp[-2].dblval) > (yyvsp[0].dblval))
@@ -1373,7 +1374,7 @@
break;
case 20:
-#line 177 "mapparser.y"
+#line 186 "mapparser.y"
if((yyvsp[-2].dblval) < (yyvsp[0].dblval))
@@ -1383,7 +1384,7 @@
break;
case 21:
-#line 183 "mapparser.y"
+#line 192 "mapparser.y"
if((yyvsp[-2].dblval) >= (yyvsp[0].dblval))
@@ -1393,7 +1394,7 @@
break;
case 22:
-#line 189 "mapparser.y"
+#line 198 "mapparser.y"
if((yyvsp[-2].dblval) <= (yyvsp[0].dblval))
@@ -1403,12 +1404,12 @@
break;
case 23:
-#line 195 "mapparser.y"
+#line 204 "mapparser.y"
{ (yyval.intval) = (yyvsp[-1].intval); }
break;
case 24:
-#line 196 "mapparser.y"
+#line 205 "mapparser.y"
if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) == 0)
@@ -1420,7 +1421,7 @@
break;
case 25:
-#line 204 "mapparser.y"
+#line 213 "mapparser.y"
if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) != 0)
@@ -1432,7 +1433,7 @@
break;
case 26:
-#line 212 "mapparser.y"
+#line 221 "mapparser.y"
if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) > 0)
@@ -1445,7 +1446,7 @@
break;
case 27:
-#line 221 "mapparser.y"
+#line 230 "mapparser.y"
if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) < 0)
@@ -1457,7 +1458,7 @@
break;
case 28:
-#line 229 "mapparser.y"
+#line 238 "mapparser.y"
if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) >= 0)
@@ -1469,7 +1470,7 @@
break;
case 29:
-#line 237 "mapparser.y"
+#line 246 "mapparser.y"
if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) <= 0)
@@ -1481,7 +1482,7 @@
break;
case 30:
-#line 245 "mapparser.y"
+#line 254 "mapparser.y"
if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) == 0)
@@ -1491,7 +1492,7 @@
break;
case 31:
-#line 251 "mapparser.y"
+#line 260 "mapparser.y"
if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) != 0)
@@ -1501,7 +1502,7 @@
break;
case 32:
-#line 257 "mapparser.y"
+#line 266 "mapparser.y"
if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) > 0)
@@ -1511,7 +1512,7 @@
break;
case 33:
-#line 263 "mapparser.y"
+#line 272 "mapparser.y"
if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) < 0)
@@ -1521,7 +1522,7 @@
break;
case 34:
-#line 269 "mapparser.y"
+#line 278 "mapparser.y"
if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) >= 0)
@@ -1531,7 +1532,7 @@
break;
case 35:
-#line 275 "mapparser.y"
+#line 284 "mapparser.y"
if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) <= 0)
@@ -1541,7 +1542,7 @@
break;
case 36:
-#line 281 "mapparser.y"
+#line 290 "mapparser.y"
char *delim,*bufferp;
@@ -1566,7 +1567,7 @@
break;
case 37:
-#line 302 "mapparser.y"
+#line 311 "mapparser.y"
@@ -1591,7 +1592,7 @@
break;
case 38:
-#line 323 "mapparser.y"
+#line 332 "mapparser.y"
@@ -1601,7 +1602,7 @@
break;
case 39:
-#line 329 "mapparser.y"
+#line 338 "mapparser.y"
if(strcasecmp((yyvsp[-2].strval), (yyvsp[0].strval)) == 0)
@@ -1613,7 +1614,7 @@
break;
case 40:
-#line 337 "mapparser.y"
+#line 346 "mapparser.y"
@@ -1623,7 +1624,7 @@
break;
case 41:
-#line 343 "mapparser.y"
+#line 352 "mapparser.y"
int rval;
rval = msGEOSIntersects((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1638,32 +1639,32 @@
break;
case 43:
-#line 357 "mapparser.y"
+#line 366 "mapparser.y"
{ (yyval.dblval) = (yyvsp[-1].dblval); }
break;
case 44:
-#line 358 "mapparser.y"
+#line 367 "mapparser.y"
{ (yyval.dblval) = (yyvsp[-2].dblval) + (yyvsp[0].dblval); }
break;
case 45:
-#line 359 "mapparser.y"
+#line 368 "mapparser.y"
{ (yyval.dblval) = (yyvsp[-2].dblval) - (yyvsp[0].dblval); }
break;
case 46:
-#line 360 "mapparser.y"
+#line 369 "mapparser.y"
{ (yyval.dblval) = (yyvsp[-2].dblval) * (yyvsp[0].dblval); }
break;
case 47:
-#line 361 "mapparser.y"
+#line 370 "mapparser.y"
{ (yyval.dblval) = (int)(yyvsp[-2].dblval) % (int)(yyvsp[0].dblval); }
break;
case 48:
-#line 362 "mapparser.y"
+#line 371 "mapparser.y"
if((yyvsp[0].dblval) == 0.0) {
msyyerror("Division by zero.");
@@ -1674,22 +1675,22 @@
break;
case 49:
-#line 369 "mapparser.y"
+#line 378 "mapparser.y"
{ (yyval.dblval) = (yyvsp[0].dblval); }
break;
case 50:
-#line 370 "mapparser.y"
+#line 379 "mapparser.y"
{ (yyval.dblval) = pow((yyvsp[-2].dblval), (yyvsp[0].dblval)); }
break;
case 51:
-#line 371 "mapparser.y"
+#line 380 "mapparser.y"
{ (yyval.dblval) = strlen((yyvsp[-1].strval)); }
break;
case 52:
-#line 372 "mapparser.y"
+#line 381 "mapparser.y"
if((yyvsp[-1].shpval)->type != MS_SHAPE_POLYGON) {
msyyerror("Area can only be computed for polygon shapes.");
@@ -1701,12 +1702,12 @@
break;
case 54:
-#line 383 "mapparser.y"
+#line 392 "mapparser.y"
{ (yyval.shpval) = (yyvsp[-1].shpval); }
break;
case 55:
-#line 384 "mapparser.y"
+#line 393 "mapparser.y"
shapeObj *s;
s = msShapeFromWKT((yyvsp[-1].strval));
@@ -1720,17 +1721,17 @@
break;
case 57:
-#line 397 "mapparser.y"
+#line 406 "mapparser.y"
{ (yyval.strval) = (yyvsp[-1].strval); free((yyvsp[-1].strval)); }
break;
case 58:
-#line 398 "mapparser.y"
+#line 407 "mapparser.y"
{ sprintf((yyval.strval), "%s%s", (yyvsp[-2].strval), (yyvsp[0].strval)); free((yyvsp[-2].strval)); free((yyvsp[0].strval)); }
break;
case 60:
-#line 402 "mapparser.y"
+#line 411 "mapparser.y"
{ (yyval.tmval) = (yyvsp[-1].tmval); }
break;
@@ -1738,7 +1739,7 @@
/* Line 1037 of yacc.c. */
-#line 1742 "mapparser.c"
+#line 1743 "mapparser.c"
yyvsp -= yylen;
yyssp -= yylen;
@@ -1966,6 +1967,30 @@
-#line 405 "mapparser.y"
+#line 414 "mapparser.y"
+** Any extra C functions
+int yylex(void)
+ int token;
+ if(yyexpr->curtoken == yyexpr->numtokens) return(0); /* done */
+ token = msyyexpr->tokens[msyyexpr->curtoken];
+ msyyexpr->curtoken++;
+ return(token);
+int yywrap() /* override */
+ return(1);
+int yyerror(char *s) {
+ msSetError(MS_PARSEERR, s, "yyparse()");
+ return(0);
Modified: sandbox/sdlime/common-expressions/mapserver/mapparser.h
--- sandbox/sdlime/common-expressions/mapserver/mapparser.h 2010-06-12 18:11:09 UTC (rev 10226)
+++ sandbox/sdlime/common-expressions/mapserver/mapparser.h 2010-06-14 04:23:53 UTC (rev 10227)
@@ -84,7 +84,7 @@
double dblval;
int intval;
@@ -99,7 +99,7 @@
#endif
-extern YYSTYPE mseyylval;
+extern YYSTYPE yylval;
Modified: sandbox/sdlime/common-expressions/mapserver/mapparser.y
--- sandbox/sdlime/common-expressions/mapserver/mapparser.y 2010-06-12 18:11:09 UTC (rev 10226)
+++ sandbox/sdlime/common-expressions/mapserver/mapparser.y 2010-06-14 04:23:53 UTC (rev 10227)
@@ -14,10 +14,19 @@
-int msyyresult;
+shapeObj *yyshape;
+layerObj *yylayer;
+typedef union {
+ int intval;
+ char *strval;
+ shapeObj *shpval;
+} parseResultObj;
/* Bison/Yacc declarations */
@@ -61,12 +70,12 @@
input: /* empty string */
- | logical_exp { msyyresult = $1; }
+ | logical_exp { yyresult.intval = $1; }
| math_exp {
if($1 != 0)
else
@@ -346,7 +355,7 @@
if($1->scope == 1) msFreeShape($1);
if($3->scope == 1) msFreeShape($3);
if(rval == -1) {
- msyyerror("Intersects operator failed.");
+ yyerror("Intersects operator failed.");
return(-1);
} else
$$ = rval;
@@ -361,7 +370,7 @@
| math_exp '%' math_exp { $$ = (int)$1 % (int)$3; }
| math_exp '/' math_exp {
if($3 == 0.0) {
- msyyerror("Division by zero.");
+ yyerror("Division by zero.");
return(-1);
} else
$$ = $1 / $3;
@@ -371,7 +380,7 @@
| LENGTH '(' string_exp ')' { $$ = strlen($3); }
| AREA '(' shape_exp ')' {
if($3->type != MS_SHAPE_POLYGON) {
- msyyerror("Area can only be computed for polygon shapes.");
+ yyerror("Area can only be computed for polygon shapes.");
return(-1);
$$ = msGetPolygonArea($3);
@@ -385,7 +394,7 @@
shapeObj *s;
s = msShapeFromWKT($3);
if(!s) {
- msyyerror("Parsing WKT text failed.");
+ yyerror("Parsing WKT text failed.");
return(-1);
s->scope = 1;
@@ -403,3 +412,63 @@
+int yylex(void)
+ int token, i=yyexpr->curtoken;
+ token = yyexpr->tokens[i].token; /* may override if a binding token */
+ switch(yyexpr->tokens[i].token) {
+ case NUMBER:
+ yylval.dblval = yyexpr->tokens[i].tokenval.dblval;
+ break;
+ case STRING:
+ case ISTRING:
+ yylval.strval = strdup(yyexpr->tokens[i].tokenval.strval);
+ break;
+ case REGEX:
+ case IREGEX:
+ yylval.strval = yyexpr->tokens[i].tokenval.strval;
+ break;
+ case TIME:
+ yylval.tmval = yyexpr->tokens[i].tokenval.tmval;
+ break;
+ case MS_TOKEN_BINDING_DOUBLE:
+ case MS_TOKEN_BINDING_INTEGER:
+ token = NUMBER;
+ yylval.dblval = atof(yyshape->values[yyexpr->tokens[i].tokenval.bindval.index]);
+ break;
+ case MS_TOKEN_BINDING_STRING:
+ token = STRING;
+ yylval.strval = strdup(yyshape->values[yyexpr->tokens[i].tokenval.bindval.index]);
+ break;
+ case MS_TOKEN_BINDING_TIME:
+ token = TIME;
+ msTimeInit(&(yylval.tmval));
+ if(msParseTime(yyshape->values[yyexpr->tokens[i].tokenval.bindval.index], &(yylval.tmval)) != MS_TRUE) {
+ yyerror("Parsing time value failed.", "yylex()");
+ return(-1);
+ break;
+ case MS_TOKEN_BINDING_SHAPE:
+ token = SHAPE;
+ yylval.shpval = yyshape;
+ break;
+ default:
+ break;
+ yyexpr->curtoken++;
+ return(token);
+ return(0);
Modified: sandbox/sdlime/common-expressions/mapserver/mapserver.h
--- sandbox/sdlime/common-expressions/mapserver/mapserver.h 2010-06-12 18:11:09 UTC (rev 10226)
+++ sandbox/sdlime/common-expressions/mapserver/mapserver.h 2010-06-14 04:23:53 UTC (rev 10227)
@@ -441,12 +441,12 @@
typedef struct _FilterNode
- FilterNodeType eType;
- char *pszValue;
- void *pOther;
- char *pszSRS;
- struct _FilterNode *psLeftNode;
- struct _FilterNode *psRightNode;
+ FilterNodeType eType;
+ char *pszValue;
+ void *pOther;
+ char *pszSRS;
+ struct _FilterNode *psLeftNode;
+ struct _FilterNode *psRightNode;
} FilterEncodingNode;
/* Define supported bindings here (only covers existing bindings at first). Not accessible directly using MapScript. */
@@ -488,17 +488,17 @@
typedef struct {
#ifdef SWIG
- %immutable;
+%immutable;
#endif
- char *filename;
- int numfonts;
- hashTableObj fonts;
+ char *filename;
+ int numfonts;
+ hashTableObj fonts;
#ifdef SWIG
- %mutable;
+%mutable;
#endif
#ifndef SWIG
- struct map_obj *map;
+ struct map_obj *map;
#endif
} fontSetObj;
@@ -509,9 +509,9 @@
#ifndef SWIG
typedef struct listNode {
- shapeObj shape;
- struct listNode *next;
- struct listNode *tailifhead; /* this is the tail node in the list, if this is the head element, otherwise NULL */
+ shapeObj shape;
+ struct listNode *next;
+ struct listNode *tailifhead; /* this is the tail node in the list, if this is the head element, otherwise NULL */
} featureListNodeObj;
typedef featureListNodeObj * featureListNodeObjPtr;
@@ -524,9 +524,9 @@
#ifndef SWIG
typedef struct {
- colorObj colors[MS_MAXCOLORS-1];
- int colorvalue[MS_MAXCOLORS-1];
- int numcolors;
+ colorObj colors[MS_MAXCOLORS-1];
+ int colorvalue[MS_MAXCOLORS-1];
+ int numcolors;
} paletteObj;
#endif
@@ -550,19 +550,20 @@
} tokenObj;
typedef struct {
- char *string;
- int type;
- /* container for expression options such as case-insensitiveness */
- /* This is a boolean container. */
- int flags;
+ char *string;
+ int type;
+ /* container for expression options such as case-insensitiveness */
+ /* This is a boolean container. */
+ int flags;
- /* logical expression options */
- tokenObj tokens[100];
- int numtokens;
- /* regular expression options */
- ms_regex_t regex; /* compiled regular expression to be matched */
- int compiled;
+ /* logical expression options */
+ tokenObj tokens[100];
+ int numtokens;
+ int curtoken;
+ /* regular expression options */
+ ms_regex_t regex; /* compiled regular expression to be matched */
+ int compiled;
} expressionObj;
#endif
@@ -575,25 +576,24 @@
#ifndef SWIG
typedef struct {
- char *name;
- char **items, **values; /* items/values (process 1 record at a time) */
- int numitems;
+ char *name;
+ char **items, **values; /* items/values (process 1 record at a time) */
+ int numitems;
+ char *table;
+ char *from, *to; /* item names */
- char *table;
- char *from, *to; /* item names */
- void *joininfo; /* vendor specific (i.e. XBase, MySQL, etc.) stuff to allow for persistant access */
- char *header, *footer;
+ void *joininfo; /* vendor specific (i.e. XBase, MySQL, etc.) stuff to allow for persistant access */
+ char *header, *footer;
#ifndef __cplusplus
- char *template;
+ char *template;
#else
- char *_template;
+ char *_template;
#endif
- enum MS_JOIN_TYPE type;
- char *connection;
- enum MS_JOIN_CONNECTION_TYPE connectiontype;
+ enum MS_JOIN_TYPE type;
+ char *connection;
+ enum MS_JOIN_CONNECTION_TYPE connectiontype;
} joinObj;
#endif
@@ -604,19 +604,19 @@
typedef struct {
- char *name;
- char *mimetype;
- char *driver;
- char *extension;
- int renderer; /* MS_RENDER_WITH_* */
- int imagemode; /* MS_IMAGEMODE_* value. */
- int transparent;
- int bands;
- int numformatoptions;
- char **formatoptions;
- int refcount;
- int inmapfile; /* boolean value for writing */
- rendererVTableObj *vtable;
+ char *name;
+ char *mimetype;
+ char *driver;
+ char *extension;
+ int renderer; /* MS_RENDER_WITH_* */
+ int imagemode; /* MS_IMAGEMODE_* value. */
+ int transparent;
+ int bands;
+ int numformatoptions;
+ char **formatoptions;
+ int refcount;
+ int inmapfile; /* boolean value for writing */
+ rendererVTableObj *vtable;
} outputFormatObj;
/* The following is used for "don't care" values in transparent, interlace and
@@ -661,10 +661,10 @@
/* used to visualize query results */
typedef struct {
- int height, width;
- int status;
- int style; /* HILITE, SELECTED or NORMAL */
- colorObj color;
+ int height, width;
+ int status;
+ int style; /* HILITE, SELECTED or NORMAL */
+ colorObj color;
} queryMapObj;
Modified: sandbox/sdlime/common-expressions/mapserver/maputil.c
--- sandbox/sdlime/common-expressions/mapserver/maputil.c 2010-06-12 18:11:09 UTC (rev 10226)
+++ sandbox/sdlime/common-expressions/mapserver/maputil.c 2010-06-14 04:23:53 UTC (rev 10227)
@@ -52,15 +52,15 @@
MS_CVSID("$Id$")
-extern int msyyparse(void);
extern int msyylex_destroy(void);
-extern char *msyytext;
-extern int msyyresult; /* result of parsing, true/false */
-extern int msyystate;
-extern char *msyystring;
+extern int yyparse(void);
+extern parseResultObj yyresult; /* result of parsing, true/false */
+extern shapeObj *yyshape; /* globals to hold the active shape/layer/expression */
+extern layerObj *yylayer;
+extern expressionObj *yyexpr;
** Helper functions to convert from strings to other types or objects.
@@ -378,14 +378,11 @@
case(MS_EXPRESSION):
msAcquireLock( TLOCK_PARSER );
- msyystate = MS_TOKENIZE_EXPRESSION;
+ yyshape = shape;
+ yylayer = layer;
+ yyexpr = expression;
- // msyyshape = shape;
- // msyylayer = layer;
- msyystring = expression->string;
- status = msyyparse();
- expresult = msyyresult;
+ status = yyparse();
msReleaseLock( TLOCK_PARSER );
if (status != 0) {
@@ -393,7 +390,7 @@
return MS_FALSE;
- return expresult;
+ return yyresult.intval;
break;
case(MS_REGEX):
if(itemindex == -1) {
More information about the mapserver-commits
