[mapserver-commits] r10229 - trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Tue Jun 15 21:56:59 EDT 2010
Author: hobu
Date: 2010-06-16 01:56:59 +0000 (Wed, 16 Jun 2010)
New Revision: 10229
trunk/docs/en/mapfile/class.txt
typo
Modified: trunk/docs/en/mapfile/class.txt
--- trunk/docs/en/mapfile/class.txt 2010-06-16 01:56:07 UTC (rev 10228)
+++ trunk/docs/en/mapfile/class.txt 2010-06-16 01:56:59 UTC (rev 10229)
@@ -196,7 +196,7 @@
TEXT [string]
Static text to label features in this class with. This overrides values obtained
- from the LABELTIEM. The string may be given as an expression delimited using
+ from the LABELITEM. The string may be given as an expression delimited using
the ()'s. This allows you to concatenate multiple attributes into a single
label. For example: ([FIRSTNAME],[LASTNAME]).
More information about the mapserver-commits
