[mapserver-commits] r10241 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Wed Jun 23 13:16:40 EDT 2010
Author: aboudreault
Date: 2010-06-23 17:16:40 +0000 (Wed, 23 Jun 2010)
New Revision: 10241
trunk/mapserver/HISTORY.TXT
trunk/mapserver/configure
trunk/mapserver/configure.in
Fixed configure does not detect libGD version dependencies (#3478)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2010-06-23 10:03:45 UTC (rev 10240)
+++ trunk/mapserver/HISTORY.TXT 2010-06-23 17:16:40 UTC (rev 10241)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
+- Fixed configure does not detect libGD version dependencies (#3478)
- Fixed Drawing inline text not working (bitmap) (#3475)
- ensure well formed XML when msWCSGetCapabilities_CoverageOfferingBrief
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure 2010-06-23 10:03:45 UTC (rev 10240)
+++ trunk/mapserver/configure 2010-06-23 17:16:40 UTC (rev 10241)
@@ -309,7 +309,7 @@
# include <unistd.h>
#endif"
-ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT CXX CXXFLAGS ac_ct_CXX RANLIB ac_ct_RANLIB LEX LEXLIB LEX_OUTPUT_ROOT YACC XTRALIBS CPP EGREP C_PIC STRINGS MS_VERSION PKG_CONFIG FT_BIN ZLIB_ENABLED ZLIB_INC ZLIB_LIB JPEG_ENABLED JPEG_INC JPEG_LIB ICONV_ENABLED ICONV_INC ICONV_LIB GD_DEF GD_INC GD_LIB GD_STATIC MAKE_GD MAKE_GD_CLEAN PDF_ENABLED PDF_INC PDF_LIB FTGL_ENABLED FTGL_INC FTGL_LIB OGL_ENABLED OGL_INC OGL_LIB AGG_ENABLED AGG_INC AGG_OBJ AGG_LIB RGBA_PNG_ENABLED PNG_INC PNG_LIB PROJ_ENABLED PROJ_INC PROJ_LIBS THREAD_FLAG THREAD_LIB SDE_ENABLED SDE_INC SDE_LIB GEOS_CONFIG GEOS_ENABLED GEOS_INC GEOS_LIB GDAL_CONFIG GDAL_ENABLED OG
R_ENABLED GDAL_INC GDAL_LIB PG_CONFIG POSTGIS_ENABLED POSTGIS_INC POSTGIS_LIB MY_CONFIG MYGIS_ENABLED MYGIS_INC MYGIS_LIB ORACLESPATIAL_ENABLED ORACLESPATIAL_INC ORACLESPATIAL_LIB MING_ENABLED MING_INC MING_LIB WMS_SVR_ENABLED WFS_SVR_ENABLED WCS_SVR_ENABLED LIBCURL_CONFIG CURL_INC CURL_LIB LIBXML2_CONFIG XML2_INC XML2_LIB WMS_LYR_ENABLED WFS_LYR_ENABLED SOS_SVR_ENABLED KML_ENABLED XSLT_ENABLED XSLT_INC XSLT_LIB EXSLT_ENABLED EXSLT_INC EXSLT_LIB FRIBIDI_CONFIG FRIBIDI_ENABLED FRIBIDI_INC FRIBIDI_LIB CAIRO_ENABLED CAIRO_INC CAIRO_LIB FASTCGI_ENABLED FASTCGI_INC FASTCGI_LIB HTTPD MS_INC MS_LIB IGNORE_MISSING_DATA USE_POINT_Z_M USE_NINT DEBUG_FLAGS LD_SHARED SO_EXT SO_COMMAND_NAME PHP_LD_SHARED PHP_VERSION_FLAG PHP_SRC_DIR PHP_CC PHP_LD PHP_REGEX_INC PHP_REGEX_OBJ USE_PHP_REGEX MAKE_PHPMS MAKE_PHPMS_CLEAN APACHE_INC OS_INCLUDE_DIR ALL_ENABLED ALL_INC ALL_LIB ALL_STATIC_LIB RPATHS LIBOBJS LTLIBOBJS'
+ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT CXX CXXFLAGS ac_ct_CXX RANLIB ac_ct_RANLIB LEX LEXLIB LEX_OUTPUT_ROOT YACC XTRALIBS CPP EGREP C_PIC STRINGS MS_VERSION PKG_CONFIG FT_BIN ZLIB_ENABLED ZLIB_INC ZLIB_LIB JPEG_ENABLED JPEG_INC JPEG_LIB ICONV_ENABLED ICONV_INC ICONV_LIB GD_DEF GD_INC GD_LIB GD_STATIC MAKE_GD MAKE_GD_CLEAN PDF_ENABLED PDF_INC PDF_LIB FTGL_ENABLED FTGL_INC FTGL_LIB OGL_ENABLED OGL_INC OGL_LIB AGG_ENABLED AGG_INC AGG_OBJ AGG_LIB RGBA_PNG_ENABLED PNG_INC PNG_LIB PROJ_ENABLED PROJ_INC PROJ_LIBS THREAD_FLAG THREAD_LIB SDE_ENABLED SDE_INC SDE_LIB GEOS_CONFIG GEOS_ENABLED GEOS_INC GEOS_LIB GDAL_CONFIG GDAL_ENABLED OG
R_ENABLED GDAL_INC GDAL_LIB PG_CONFIG POSTGIS_ENABLED POSTGIS_INC POSTGIS_LIB MY_CONFIG MYGIS_ENABLED MYGIS_INC MYGIS_LIB ORACLESPATIAL_ENABLED ORACLESPATIAL_INC ORACLESPATIAL_LIB MING_ENABLED MING_INC MING_LIB WMS_SVR_ENABLED WFS_SVR_ENABLED WCS_SVR_ENABLED LIBCURL_CONFIG CURL_INC CURL_LIB LIBXML2_CONFIG XML2_INC XML2_LIB WMS_LYR_ENABLED WFS_LYR_ENABLED SOS_SVR_ENABLED XSLT_ENABLED XSLT_INC XSLT_LIB EXSLT_ENABLED EXSLT_INC EXSLT_LIB FRIBIDI_CONFIG FRIBIDI_ENABLED FRIBIDI_INC FRIBIDI_LIB CAIRO_ENABLED CAIRO_INC CAIRO_LIB FASTCGI_ENABLED FASTCGI_INC FASTCGI_LIB HTTPD MS_INC MS_LIB IGNORE_MISSING_DATA USE_POINT_Z_M USE_NINT DEBUG_FLAGS LD_SHARED SO_EXT SO_COMMAND_NAME PHP_LD_SHARED PHP_VERSION_FLAG PHP_SRC_DIR PHP_CC PHP_LD PHP_REGEX_INC PHP_REGEX_OBJ USE_PHP_REGEX MAKE_PHPMS MAKE_PHPMS_CLEAN APACHE_INC OS_INCLUDE_DIR ALL_ENABLED ALL_INC ALL_LIB ALL_STATIC_LIB RPATHS LIBOBJS LTLIBOBJS'
ac_subst_files=''
# Initialize some variables set by options.
@@ -925,7 +925,6 @@
to xslt install dir).
--with-exslt=DIR Include exslt Support (ARG=yes/path to
to exslt install dir).
- --with-kml Include support for KML output
--with-fribidi-config[=ARG]
Include FriBidi Support (ARG=yes/path to
fribidi-config or fribidi.pc)
@@ -6083,10 +6082,10 @@
unset ac_cv_lib_c_gdImageStringFT
unset ac_cv_lib_c_gdImageGifPtr
unset ac_cv_lib_c_gdFontGetTiny
-unset ac_cv_lib_gd_gdFontCacheSetup
+unset ac_cv_lib_gd_gdImageCreatePaletteFromTrueColor
-{ echo "$as_me:$LINENO: checking for GD 2.0.16 or higher..." >&5
-echo "$as_me: checking for GD 2.0.16 or higher..." >&6;}
+{ echo "$as_me:$LINENO: checking for GD 2.0.28 or higher..." >&5
+echo "$as_me: checking for GD 2.0.28 or higher..." >&6;}
# Check whether --with-gd or --without-gd was given.
if test "${with_gd+set}" = set; then
@@ -6131,9 +6130,9 @@
test -f $GD_DIR/_libs/libgd.so -o -f $GD_DIR/_libs/libgd.sl -o -f $GD_DIR/_libs/libgd.dylib && GD_LIBDIR="$GD_DIR/_libs"
test -f $GD_DIR/libgd.so -o -f $GD_DIR/libgd.sl -o -f $GD_DIR/libgd.dylib && GD_LIBDIR="$GD_DIR"
- echo "$as_me:$LINENO: checking for gdFontCacheSetup in -lgd" >&5
-echo $ECHO_N "checking for gdFontCacheSetup in -lgd... $ECHO_C" >&6
-if test "${ac_cv_lib_gd_gdFontCacheSetup+set}" = set; then
+ echo "$as_me:$LINENO: checking for gdImageCreatePaletteFromTrueColor in -lgd" >&5
+echo $ECHO_N "checking for gdImageCreatePaletteFromTrueColor in -lgd... $ECHO_C" >&6
+if test "${ac_cv_lib_gd_gdImageCreatePaletteFromTrueColor+set}" = set; then
echo $ECHO_N "(cached) $ECHO_C" >&6
else
ac_check_lib_save_LIBS=$LIBS
@@ -6151,11 +6150,11 @@
#endif
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
-char gdFontCacheSetup ();
+char gdImageCreatePaletteFromTrueColor ();
int
main ()
-gdFontCacheSetup ();
+gdImageCreatePaletteFromTrueColor ();
return 0;
@@ -6182,31 +6181,31 @@
ac_status=$?
echo "$as_me:$LINENO: \$? = $ac_status" >&5
(exit $ac_status); }; }; then
- ac_cv_lib_gd_gdFontCacheSetup=yes
+ ac_cv_lib_gd_gdImageCreatePaletteFromTrueColor=yes
else
echo "$as_me: failed program was:" >&5
sed 's/^/| /' conftest.$ac_ext >&5
-ac_cv_lib_gd_gdFontCacheSetup=no
+ac_cv_lib_gd_gdImageCreatePaletteFromTrueColor=no
fi
rm -f conftest.err conftest.$ac_objext \
conftest$ac_exeext conftest.$ac_ext
LIBS=$ac_check_lib_save_LIBS
fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_gd_gdFontCacheSetup" >&5
-echo "${ECHO_T}$ac_cv_lib_gd_gdFontCacheSetup" >&6
-if test $ac_cv_lib_gd_gdFontCacheSetup = yes; then
+echo "$as_me:$LINENO: result: $ac_cv_lib_gd_gdImageCreatePaletteFromTrueColor" >&5
+echo "${ECHO_T}$ac_cv_lib_gd_gdImageCreatePaletteFromTrueColor" >&6
+if test $ac_cv_lib_gd_gdImageCreatePaletteFromTrueColor = yes; then
IS_GD2="true"
fi
if test "$IS_GD2" = "false" -a -n "$ICONV_LIB"; then
- unset ac_cv_lib_gd_gdFontCacheSetup
+ unset ac_cv_lib_gd_gdImageCreatePaletteFromTrueColor
{ echo "$as_me:$LINENO: checking whether GD needs libiconv..." >&5
echo "$as_me: checking whether GD needs libiconv..." >&6;}
else
@@ -6224,11 +6223,11 @@
#endif
int
main ()
return 0;
@@ -6255,20 +6254,20 @@
ac_status=$?
else
fi
fi
IS_GD2="true"
fi
@@ -6279,8 +6278,8 @@
GD_INC=-I$GD_INCLUDE
GD_LIB="-L$GD_LIBDIR -lgd"
GD_XTRA_LIBS="$GD_XTRA_LIBS $GD_NEED_ICONV_LIB"
- echo "$as_me:$LINENO: result: using libgd 2.0.16 (or higher) from $GD_LIB $GD_XTRA_LIBS" >&5
-echo "${ECHO_T} using libgd 2.0.16 (or higher) from $GD_LIB $GD_XTRA_LIBS" >&6
+ echo "$as_me:$LINENO: result: using libgd 2.0.28 (or higher) from $GD_LIB $GD_XTRA_LIBS" >&5
+echo "${ECHO_T} using libgd 2.0.28 (or higher) from $GD_LIB $GD_XTRA_LIBS" >&6
if test ""$GD_LIBDIR"" != "/usr/lib"; then
@@ -6304,8 +6303,8 @@
fi
else
- { { echo "$as_me:$LINENO: error: Could not find gd.h or libgd.a/libgd.so in $GD_DIR. Make sure GD 2.0.16 or higher is compiled before calling configure. You may also get this error if you didn't specify the appropriate location for one of GD's dependencies (freetype, libpng, libjpeg or libiconv)." >&5
-echo "$as_me: error: Could not find gd.h or libgd.a/libgd.so in $GD_DIR. Make sure GD 2.0.16 or higher is compiled before calling configure. You may also get this error if you didn't specify the appropriate location for one of GD's dependencies (freetype, libpng, libjpeg or libiconv)." >&2;}
+ { { echo "$as_me:$LINENO: error: Could not find gd.h or libgd.a/libgd.so in $GD_DIR. Make sure GD 2.0.28 or higher is compiled before calling configure. You may also get this error if you didn't specify the appropriate location for one of GD's dependencies (freetype, libpng, libjpeg or libiconv)." >&5
+echo "$as_me: error: Could not find gd.h or libgd.a/libgd.so in $GD_DIR. Make sure GD 2.0.28 or higher is compiled before calling configure. You may also get this error if you didn't specify the appropriate location for one of GD's dependencies (freetype, libpng, libjpeg or libiconv)." >&2;}
{ (exit 1); exit 1; }; }
fi
else
@@ -6318,9 +6317,9 @@
test -f $GD_DIR/lib/libgd.so -o -f $GD_DIR/lib/libgd.sl -o -f $GD_DIR/lib/libgd.dylib && GD_LIBDIR="$GD_DIR/lib"
test -f $GD_DIR/lib64/libgd.so -o -f $GD_DIR/lib/libgd.sl && GD_LIBDIR="$GD_DIR/lib64"
else
@@ -6338,11 +6337,11 @@
#endif
int
main ()
return 0;
@@ -6369,20 +6368,20 @@
ac_status=$?
else
fi
fi
IS_GD2="true"
fi
@@ -6390,10 +6389,10 @@
else
@@ -6411,11 +6410,11 @@
#endif
int
main ()
return 0;
@@ -6442,20 +6441,20 @@
ac_status=$?
else
fi
fi
IS_GD2="true"
fi
@@ -6466,8 +6465,8 @@
- echo "$as_me:$LINENO: result: using libgd 2.0.16 (or higher) from system libs ($GD_LIB $GD_XTRA_LIBS)." >&5
-echo "${ECHO_T} using libgd 2.0.16 (or higher) from system libs ($GD_LIB $GD_XTRA_LIBS)." >&6
+ echo "$as_me:$LINENO: result: using libgd 2.0.28 (or higher) from system libs ($GD_LIB $GD_XTRA_LIBS)." >&5
+echo "${ECHO_T} using libgd 2.0.28 (or higher) from system libs ($GD_LIB $GD_XTRA_LIBS)." >&6
@@ -6496,8 +6495,8 @@
done
if test "$FOUND_GD" = "false" ; then
fi
fi
@@ -12252,32 +12251,7 @@
ALL_ENABLED="$WMS_LYR_ENABLED $WFS_LYR_ENABLED $SOS_SVR_ENABLED $XML2_ENABLED $CURL_ENABLED $ALL_ENABLED"
-echo "$as_me:$LINENO: checking if KML support requested" >&5
-echo $ECHO_N "checking if KML support requested... $ECHO_C" >&6
-# Check whether --with-kml or --without-kml was given.
-if test "${with_kml+set}" = set; then
- withval="$with_kml"
-fi;
-if test -z "$with_kml" -o "$with_kml" = "no" ; then
- echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6
-else
- if test -z "$XML2_ENABLED" ; then
- { { echo "$as_me:$LINENO: error: libxml2 required - please reconfigure --with-xml2-config." >&5
-echo "$as_me: error: libxml2 required - please reconfigure --with-xml2-config." >&2;}
- { (exit 1); exit 1; }; }
- fi
- KML_ENABLED=-DUSE_KML
-fi
-KML_ENABLED=$KML_ENABLED
-ALL_ENABLED="$KML_ENABLED $ALL_ENABLED"
# Check whether --with-xml-mapfile or --without-xml-mapfile was given.
if test "${with_xml_mapfile+set}" = set; then
withval="$with_xml_mapfile"
@@ -14468,7 +14442,6 @@
s, at WMS_LYR_ENABLED@,$WMS_LYR_ENABLED,;t t
s, at WFS_LYR_ENABLED@,$WFS_LYR_ENABLED,;t t
s, at SOS_SVR_ENABLED@,$SOS_SVR_ENABLED,;t t
-s, at KML_ENABLED@,$KML_ENABLED,;t t
s, at XSLT_ENABLED@,$XSLT_ENABLED,;t t
s, at XSLT_INC@,$XSLT_INC,;t t
s, at XSLT_LIB@,$XSLT_LIB,;t t
@@ -14816,8 +14789,6 @@
echo "${ECHO_T} AGG support: ${AGG_ENABLED} ${AGG_SVG_SYMBOLS_ENABLED}" >&6
echo "$as_me:$LINENO: result: Cairo (SVG,PDF) support: ${CAIRO_ENABLED}" >&5
echo "${ECHO_T} Cairo (SVG,PDF) support: ${CAIRO_ENABLED}" >&6
-echo "$as_me:$LINENO: result: KML support: ${KML_ENABLED}" >&5
-echo "${ECHO_T} KML support: ${KML_ENABLED}" >&6
echo "$as_me:$LINENO: result: Ming(flash) support: ${MING_ENABLED}" >&5
echo "${ECHO_T} Ming(flash) support: ${MING_ENABLED}" >&6
echo "$as_me:$LINENO: result: PDFLib support: ${PDF_ENABLED}" >&5
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in 2010-06-23 10:03:45 UTC (rev 10240)
+++ trunk/mapserver/configure.in 2010-06-23 17:16:40 UTC (rev 10241)
@@ -520,9 +520,9 @@
-AC_CHECKING(for GD 2.0.16 or higher)
+AC_CHECKING(for GD 2.0.28 or higher)
AC_ARG_WITH(gd,
[ --with-gd[[=[static,]DIR]]
Specify which version of GD to use (DIR is GD's
@@ -552,14 +552,14 @@
- dnl make sure it is GD 2.0.16+ with antialias and gdFontCacheSetup() support
- AC_CHECK_LIB(gd, gdFontCacheSetup,IS_GD2="true",,$GD_XTRA_LIBS -L$GD_LIBDIR)
+ dnl make sure it is GD 2.0.28+ with antialias and gdFontCacheSetup() and gdImageCreatePaletteFromTrueColor support
+ AC_CHECK_LIB(gd, gdImageCreatePaletteFromTrueColor,IS_GD2="true",,$GD_XTRA_LIBS -L$GD_LIBDIR)
dnl try again including libiconv this time
AC_CHECKING(whether GD needs libiconv)
- AC_CHECK_LIB(gd, gdFontCacheSetup,IS_GD2="true",,$GD_XTRA_LIBS -L$GD_LIBDIR $ICONV_LIB)
+ AC_CHECK_LIB(gd, gdImageCreatePaletteFromTrueColor,IS_GD2="true",,$GD_XTRA_LIBS -L$GD_LIBDIR $ICONV_LIB)
GD_NEED_ICONV_LIB="$ICONV_LIB"
fi
@@ -567,10 +567,10 @@
- AC_MSG_RESULT([ using libgd 2.0.16 (or higher) from $GD_LIB $GD_XTRA_LIBS])
+ AC_MSG_RESULT([ using libgd 2.0.28 (or higher) from $GD_LIB $GD_XTRA_LIBS])
AC_ADD_RUNPATH("$GD_LIBDIR")
else
- AC_MSG_ERROR([Could not find gd.h or libgd.a/libgd.so in $GD_DIR. Make sure GD 2.0.16 or higher is compiled before calling configure. You may also get this error if you didn't specify the appropriate location for one of GD's dependencies (freetype, libpng, libjpeg or libiconv).])
+ AC_MSG_ERROR([Could not find gd.h or libgd.a/libgd.so in $GD_DIR. Make sure GD 2.0.28 or higher is compiled before calling configure. You may also get this error if you didn't specify the appropriate location for one of GD's dependencies (freetype, libpng, libjpeg or libiconv).])
fi
else
dnl --with-gd specified without a DIR, look for gd in system dirs /usr or /usr/local
@@ -583,14 +583,14 @@
- dnl make sure it is GD 2.0.16 or higher
- AC_CHECK_LIB(gd, gdFontCacheSetup, IS_GD2="true",,$GD_XTRA_LIBS)
+ dnl make sure it is GD 2.0.28 or higher
+ AC_CHECK_LIB(gd, gdImageCreatePaletteFromTrueColor, IS_GD2="true",,$GD_XTRA_LIBS)
- AC_CHECK_LIB(gd, gdFontCacheSetup,IS_GD2="true",,$GD_XTRA_LIBS $ICONV_LIB)
+ AC_CHECK_LIB(gd, gdImageCreatePaletteFromTrueColor,IS_GD2="true",,$GD_XTRA_LIBS $ICONV_LIB)
fi
@@ -598,7 +598,7 @@
- AC_MSG_RESULT([ using libgd 2.0.16 (or higher) from system libs ($GD_LIB $GD_XTRA_LIBS).])
+ AC_MSG_RESULT([ using libgd 2.0.28 (or higher) from system libs ($GD_LIB $GD_XTRA_LIBS).])
FOUND_GD="true"
break;
@@ -606,7 +606,7 @@
done
fi
fi
More information about the mapserver-commits
