[mapserver-commits] r10249 - trunk/msautotest/renderers
Fri Jun 25 13:31:57 EDT 2010
Author: tbonfort
Date: 2010-06-25 17:31:57 +0000 (Fri, 25 Jun 2010)
New Revision: 10249
Added:
   trunk/msautotest/renderers/force_palette.map
   trunk/msautotest/renderers/force_palette_rgba.map
   trunk/msautotest/renderers/force_pc256.map
   trunk/msautotest/renderers/force_pc256_rgba.map
   trunk/msautotest/renderers/labels-bitmap.map
   trunk/msautotest/renderers/palette.txt
   trunk/msautotest/renderers/palette_rgba.txt
add tests
Added: trunk/msautotest/renderers/force_palette.map
--- trunk/msautotest/renderers/force_palette.map	                        (rev 0)
+++ trunk/msautotest/renderers/force_palette.map	2010-06-25 17:31:57 UTC (rev 10249)
@@ -0,0 +1,63 @@
+# Tests the quantization option allowing conversion of
+# RGB or RGBA images to 8bit just before saving to PNG.
+# See http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1690
+MAP
+NAME TEST
+STATUS ON
+SIZE 400 300
+EXTENT 0.5 0.5 399.5 299.5
+IMAGECOLOR 255 255 0
+SHAPEPATH "../gdal"
+IMAGETYPE png24
+OUTPUTFORMAT
+  NAME png24
+  DRIVER "AGG/PNG"
+  EXTENSION "png"
+  MIMETYPE "image/png"
+  IMAGEMODE RGBA
+  TRANSPARENT OFF
+  FORMATOPTION "PALETTE_FORCE=ON"
+  FORMATOPTION "PALETTE=palette.txt"
+END
+OUTPUTFORMAT
+  NAME cairopng
+  DRIVER "CAIRO/PNG"
+  EXTENSION "png"
+  IMAGEMODE RGBA
+  TRANSPARENT OFF
+END
+OUTPUTFORMAT
+  NAME png
+  DRIVER "GD/PNG"
+  EXTENSION "png"
+  IMAGEMODE PC256
+  TRANSPARENT OFF
+END
+LAYER
+  NAME grey
+  TYPE raster
+  STATUS default
+  DATA data/grey.tif
+END
+LAYER
+  NAME grid1
+  TYPE raster
+  STATUS default
+  DATA data/grid.gif
+END
+END # of map file
Added: trunk/msautotest/renderers/force_palette_rgba.map
--- trunk/msautotest/renderers/force_palette_rgba.map	                        (rev 0)
+++ trunk/msautotest/renderers/force_palette_rgba.map	2010-06-25 17:31:57 UTC (rev 10249)
@@ -0,0 +1,63 @@
+MAP
+NAME TEST
+STATUS ON
+SIZE 400 300
+IMAGETYPE png24
+OUTPUTFORMAT
+  NAME png24
+  DRIVER "AGG/PNG"
+  EXTENSION "png"
+  IMAGEMODE RGBA
+  TRANSPARENT ON
+  FORMATOPTION "PALETTE=palette_rgba.txt"
+END
+OUTPUTFORMAT
+  NAME cairopng
+  EXTENSION "png"
+  IMAGEMODE RGBA
+  TRANSPARENT ON
+END
+OUTPUTFORMAT
+  NAME png
+  DRIVER "GD/PNG"
+  EXTENSION "png"
+  IMAGEMODE PC256
+  TRANSPARENT ON
+END
+LAYER
+  NAME grey
+  TYPE raster
+  STATUS default
+  DATA data/rgba.tif
+END
+LAYER
+  NAME grid1
+  TYPE raster
+  STATUS default
+END
+END # of map file
Added: trunk/msautotest/renderers/force_pc256.map
--- trunk/msautotest/renderers/force_pc256.map	                        (rev 0)
+++ trunk/msautotest/renderers/force_pc256.map	2010-06-25 17:31:57 UTC (rev 10249)
@@ -0,0 +1,68 @@
+MAP
+NAME TEST
+STATUS ON
+SIZE 400 300
+IMAGETYPE png24
+OUTPUTFORMAT
+  NAME png24
+  DRIVER "AGG/PNG"
+  EXTENSION "png"
+  IMAGEMODE RGBA
+  TRANSPARENT OFF
+  FORMATOPTION "QUANTIZE_FORCE=ON"
+  FORMATOPTION "QUANTIZE_DITHER=OFF"
+  FORMATOPTION "QUANTIZE_COLORS=15"
+END
+OUTPUTFORMAT
+  NAME cairopng
+  EXTENSION "png"
+  IMAGEMODE RGBA
+  TRANSPARENT OFF
+END
+OUTPUTFORMAT
+  NAME png
+  DRIVER "GD/PNG"
+  EXTENSION "png"
+  IMAGEMODE PC256
+  TRANSPARENT OFF
+END
+LAYER
+  NAME grey
+  TYPE raster
+  STATUS default
+END
+LAYER
+  NAME grid1
+  TYPE raster
+  STATUS default
+END
+END # of map file
Added: trunk/msautotest/renderers/force_pc256_rgba.map
--- trunk/msautotest/renderers/force_pc256_rgba.map	                        (rev 0)
+++ trunk/msautotest/renderers/force_pc256_rgba.map	2010-06-25 17:31:57 UTC (rev 10249)
@@ -0,0 +1,68 @@
+MAP
+NAME TEST
+STATUS ON
+SIZE 400 300
+IMAGETYPE png24
+OUTPUTFORMAT
+  NAME png24
+  DRIVER "AGG/PNG"
+  EXTENSION "png"
+  IMAGEMODE RGBA
+  TRANSPARENT ON
+  FORMATOPTION "QUANTIZE_COLORS=256"
+END
+OUTPUTFORMAT
+  NAME cairopng
+  EXTENSION "png"
+  IMAGEMODE RGBA
+  TRANSPARENT ON
+END
+OUTPUTFORMAT
+  NAME png
+  DRIVER "GD/PNG"
+  EXTENSION "png"
+  IMAGEMODE PC256
+  TRANSPARENT ON
+END
+LAYER
+  NAME grey
+  TYPE raster
+  STATUS default
+END
+LAYER
+  NAME grid1
+  TYPE raster
+  STATUS default
+END
+END # of map file
Added: trunk/msautotest/renderers/labels-bitmap.map
--- trunk/msautotest/renderers/labels-bitmap.map	                        (rev 0)
+++ trunk/msautotest/renderers/labels-bitmap.map	2010-06-25 17:31:57 UTC (rev 10249)
@@ -0,0 +1,120 @@
+map
+imagetype png
+size 400 300
+extent 0 0 400 300
+shapepath "../misc/data"
+fontset "../misc/fonts.lst"
+symbolset "symbolset"
+layer
+    type point
+    status default
+    name "p1"
+    class
+        style
+            symbol "circle"
+            size 5
+            color 255 0 0
+        end
+        label
+            size tiny
+            backgroundcolor 0 255 0
+            color 0 0 0
+            position cc
+        end
+    end
+    feature
+        points 50 50 end
+        text "TinY"
+    end
+end
+layer
+    type point
+    status default
+    name "p1"
+    class
+        style
+            symbol "circle"
+            size 5
+            color 255 0 0
+        end
+        label
+            size small
+            color 0 0 0
+            position ur
+        end
+    end
+    feature
+        points 50 100 end
+        text "SmalL"
+    end
+end
+layer
+    type point
+    status default
+    name "p1"
+    class
+        style
+            symbol "circle"
+            size 5
+            color 255 0 0
+        end
+        label
+            size medium
+            color 0 0 0
+            position uc
+        end
+    end
+    feature
+        points 50 150 end
+        text "MediuM"
+    end
+end
+layer
+    type point
+    status default
+    name "p1"
+    class
+        style
+            symbol "circle"
+            size 5
+            color 255 0 0
+        end
+        label
+            size large
+            color 0 0 0
+            position ul
+        end
+    end
+    feature
+        points 50 200 end
+        text "LargE"
+    end
+end
+layer
+    type point
+    status default
+    name "p1"
+    class
+        style
+            symbol "circle"
+            size 5
+            color 255 0 0
+        end
+        label
+            size giant
+            color 0 0 0
+            position cr
+        end
+    end
+    feature
+        points 50 250 end
+        text "GianT"
+    end
+end
+end
Added: trunk/msautotest/renderers/palette.txt
--- trunk/msautotest/renderers/palette.txt	                        (rev 0)
+++ trunk/msautotest/renderers/palette.txt	2010-06-25 17:31:57 UTC (rev 10249)
@@ -0,0 +1,15 @@
+165,165,165
+ 81, 81, 81
+173,173,173
+156,156,156
+188,188,188
+255,255,255
+220,220,220
+ 96, 32, 32
+148,148,148
+140,140,140
+ 99, 99, 99
+107,107,107
+132,132,132
+123,123,123
+115,115,115
Added: trunk/msautotest/renderers/palette_rgba.txt
--- trunk/msautotest/renderers/palette_rgba.txt	                        (rev 0)
+++ trunk/msautotest/renderers/palette_rgba.txt	2010-06-25 17:31:57 UTC (rev 10249)
@@ -0,0 +1,256 @@
+  0,  0,  0,  0
+ 20,232,  0, 89
+  0,242,  0, 20
+ 38,213,  0,160
+ 55,198,  0,226
+ 47,206,  0,194
+  9,236,  0, 54
+ 30,222,  0,126
+103,151,  0,252
+ 90,166,  0,255
+109,147,  0,255
+ 70,186,  0,255
+141,115,  0,255
+ 81,175,  0,255
+120,136,  0,255
+127,129,  0,255
+116,140,  0,255
+ 79,177,  0,255
+139,117,  0,255
+ 68,188,  0,255
+107,149,  0,255
+ 88,168,  0,255
+ 85,171,  0,255
+104,152,  0,255
+148,108,  0,255
+154,102,  0,255
+131,125,  0,255
+118,138,  0,255
+160, 96,  0,255
+150,106,  0,255
+145,111,  0,255
+ 99,157,  0,255
+134,122,  0,255
+ 94,162,  0,255
+113,143,  0,255
+ 74,182,  0,255
+143,113,  0,255
+ 83,173,  0,255
+122,134,  0,255
+ 78,178,  0,255
+102,154,  0,255
+ 77,179,  0,255
+ 66,190,  0,255
+129,127,  0,255
+103,153,  0,255
+ 91,165,  0,255
+123,133,  0,255
+ 86,170,  0,255
+146,110,  0,255
+ 75,181,  0,255
+114,142,  0,255
+ 95,161,  0,255
+135,121,  0,255
+100,156,  0,255
+158, 98,  0,255
+157, 99,  0,255
+101,155,  0,255
+ 71,185,  0,255
+121,135,  0,255
+ 82,174,  0,255
+142,114,  0,255
+ 73,183,  0,255
+110,146,  0,255
+ 93,163,  0,255
+133,123,  0,255
+ 96,160,  0,255
+138,118,  0,255
+ 97,159,  0,255
+159, 97,  0,255
+112,144,  0,255
+124,132,  0,255
+153,103,  0,255
+147,109,  0,255
+ 98,158,  0,255
+ 72,184,  0,255
+ 87,169,  0,255
+106,150,  0,255
+ 67,189,  0,255
+136,120,  0,255
+ 76,180,  0,255
+115,141,  0,255
+126,130,  0,255
+119,137,  0,255
+ 80,176,  0,255
+140,116,  0,255
+ 69,187,  0,255
+108,148,  0,255
+ 89,167,  0,255
+ 32,224,  0,255
+ 33,223,  0,255
+ 12,244,  0,255
+ 37,219,  0,255
+ 58,198,  0,255
+ 52,204,  0,255
+ 61,195,  0,255
+ 28,228,  0,255
+ 10,246,  0,255
+ 43,213,  0,255
+ 35,221,  0,255
+  2,254,  0,255
+ 11,245,  0,255
+ 20,236,  0,255
+ 53,203,  0,255
+ 56,200,  0,255
+ 23,233,  0,255
+ 38,218,  0,255
+  7,249,  0,255
+ 40,216,  0,255
+ 48,208,  0,255
+ 15,241,  0,255
+ 16,240,  0,255
+ 49,207,  0,255
+ 41,215,  0,255
+  8,248,  0,255
+ 44,212,  0,255
+ 26,230,  0,255
+ 59,197,  0,255
+ 54,202,  0,255
+ 21,235,  0,255
+ 18,238,  0,255
+  3,253,  0,255
+ 36,220,  0,255
+ 46,210,  0,255
+ 13,243,  0,255
+ 29,227,  0,255
+ 62,194,  0,255
+ 14,242,  0,255
+ 47,209,  0,255
+ 39,217,  0,255
+  6,250,  0,255
+ 31,225,  0,255
+ 22,234,  0,255
+ 55,201,  0,255
+ 50,206,  0,255
+ 19,237,  0,255
+  4,252,  0,255
+  1,255,  0,255
+ 34,222,  0,255
+ 42,214,  0,255
+  9,247,  0,255
+ 27,229,  0,255
+ 60,196,  0,255
+ 45,211,  0,255
+ 51,205,  0,255
+ 17,239,  0,255
+  5,251,  0,255
+ 30,226,  0,255
+ 25,231,  0,255
+ 63,193,  0,255
+ 57,199,  0,255
+164, 92,  0,255
+206, 50,  0,255
+251,  5,  0,255
+250,  6,  0,255
+163, 93,  0,255
+184, 72,  0,255
+234, 22,  0,255
+179, 77,  0,255
+220, 36,  0,255
+193, 63,  0,255
+248,  8,  0,255
+245, 11,  0,255
+241, 15,  0,255
+186, 70,  0,255
+213, 43,  0,255
+172, 84,  0,255
+227, 29,  0,255
+224, 32,  0,255
+200, 56,  0,255
+255,  1,  0,255
+210, 46,  0,255
+237, 19,  0,255
+202, 54,  0,255
+229, 27,  0,255
+174, 82,  0,255
+215, 41,  0,255
+188, 68,  0,255
+243, 13,  0,255
+218, 38,  0,255
+236, 20,  0,255
+181, 75,  0,255
+208, 48,  0,255
+167, 89,  0,255
+222, 34,  0,255
+197, 59,  0,255
+195, 61,  0,255
+252,  4,  0,255
+185, 71,  0,255
+170, 86,  0,255
+161, 95,  0,255
+ 65,191,  0,255
+ 64,192,  0,255
+171, 85,  0,255
+198, 58,  0,255
+253,  3,  0,255
+196, 60,  0,255
+211, 45,  0,255
+223, 33,  0,255
+168, 88,  0,255
+209, 47,  0,255
+182, 74,  0,255
+239, 17,  0,255
+225, 31,  0,255
+246, 10,  0,255
+189, 67,  0,255
+216, 40,  0,255
+175, 81,  0,255
+232, 24,  0,255
+165, 91,  0,255
+178, 78,  0,255
+249,  7,  0,255
+194, 62,  0,255
+191, 65,  0,255
+221, 35,  0,255
+166, 90,  0,255
+207, 49,  0,255
+180, 76,  0,255
+235, 21,  0,255
+205, 51,  0,255
+242, 14,  0,255
+187, 69,  0,255
+214, 42,  0,255
+173, 83,  0,255
+228, 28,  0,255
+201, 55,  0,255
+231, 25,  0,255
+190, 66,  0,255
+254,  2,  0,255
+199, 57,  0,255
+217, 39,  0,255
+226, 30,  0,255
+169, 87,  0,255
+212, 44,  0,255
+183, 73,  0,255
+240, 16,  0,255
+238, 18,  0,255
+247,  9,  0,255
+192, 64,  0,255
+219, 37,  0,255
+176, 80,  0,255
+233, 23,  0,255
+177, 79,  0,255
+162, 94,  0,255
+230, 26,  0,255
+244, 12,  0,255
+203, 53,  0,255
+ 65, 65,  0,255
+128,127,  0,255
+144,112,  0,255
+155,100,  0,255
+150,105,  0,255
+114,142,  0,255
+ 98,157,  0,255
+255,255,255,255
+ 96, 32, 32,255
+255,  0,  0,255
